jmoser
Reged: 01/02/03
Loc: MI
The power door lock on driver's side is weak - does not always click shut and I often have to push the lever down by hand half way. happens when starting the engine normally but Bigger concern when locking with the remote keyfob - always have to check the handle to be certain.
Is this a solenoid going bad or maybe just need some lube in there?
Don't want to pop off the door panel if I don't know what to look for.
-------------------- Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
BamZipPow
Reged: 02/05/07
Loc: League City, TX
It's probably the motor brushes. The motor can be rebuilt if you have the skills/tools. Seems one can use the carbon brushes they use fer slot cars in the window motors. Give it a shot, take some piccies, and post them up.
-------------------- 1998 T-100 Xtra cab SR5 2WD Auto; Roadmaster Active Suspension; Yokohama Geolander HT-S; lowered air dam; full belly pan; 4° diffuser; 11" side skirts; dual transmission coolers; 67% grill blocked; Auto-RX'd; ScanGauge II/Ultra-Gauge
Greg_Canada
Reged: 08/25/03
Loc: Toronto, Canada
Happened to my 99 4runner, i replaced the door latch/motor asembly with a good used unit...
-------------------- 89 4Runner
kewlynx
Reged: 10/06/02
Loc: Fairbanks, Alaska
Clean your window switches while you have it torn down also.
**ubi apis- ibi salus**
jmoser
Reged: 01/02/03
Loc: MI
Anyone know if the 96 T100 is compatible with other Models for the door lock motor? 4runner maybe?
BamZipPow
Reged: 02/05/07
I would guess the motor is the same...
