TainterRacing
Reged: 04/17/08
Loc: Petoskey, Michiagan
Any one every dyno there 4x4?
      #1258706 - 02/03/12 01:14 PM
I know its a dumb question I was just wondering I have seen the ones on rpw's web page just wanted to know if any one on here has done it.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
off-roaderModerator
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
Re: Any one every dyno there 4x4? [Re: TainterRacing]
      #1258709 - 02/03/12 02:21 PM
Never done it but seen a 4wd dyno being used to dyno rides like Subaru's & Audi AWD's, etc.
TOASTY
Reged: 01/17/02
Loc: Gilbert AZ, US.
Re: Any one every dyno there 4x4? [Re: off-roader]
      #1258715 - 02/03/12 03:19 PM
I've thought about it just to see the torque generated by the 3.15's and 4.90's
Az Crew, full fledged member!
Angelo
Reged: 02/21/02
Loc: Charlotte NC
      #1258718 - 02/03/12 03:38 PM
I've used a 4 wheel dyno.... on my 3000GT VR4
99JAOS2"& OME 2"body 4.90s ARB HS9500i Skids&Ladder 16"315BFG JAOSRemote& Rack 3Row Rad IPF back& Searchlite 33TSL StreetLock HID Overhead Console/CB switchPanel FrARB RrLocker TJMSnorkel 160AAlt Sliders 2nd Tranny Cooler QuickAirII& Tank Rear frame/tank Lift
Kevin C
Reged: 05/20/00
Loc: No where in particular
      #1258721 - 02/03/12 04:08 PM
Jason A did a long time ago. I think his 2.6 turbo was putting out 270 hp and some pretty decent tq figures.
That was on a 12A turbo.
Kevin
87 Dodge
TainterRacing
Reged: 04/17/08
Re: Any one every dyno there 4x4? [Re: Kevin C]
      #1258724 - 02/03/12 04:41 PM
As nice as it would be.. a 12a did not make 270hp.. I hope Jason can post on here.
Kevin C
Reged: 05/20/00
      #1258726 - 02/03/12 05:35 PM
You would have to take that up with him, he was the one who had the testing done.
It was a 9 to 1 motor with a ported head and a very well built bottom end. Including the block mod to reduce windage.
Kevin
87 Dodge
TainterRacing
Reged: 04/17/08
      #1258732 - 02/03/12 07:16 PM
I knew your not trying to miss lead any one. I have been working and messing with the turbo 2.6 for 15 years now. And I dont think I have yet seen any one more then 230hp with the 12a and that was myself running it at 28psi. not saying you cant make more then 230 but 270 is a very long way from 270hp
I have run a 2.6 with the stock carb conquest tbi and a MPI intake all N/A. I have run with the tbi turbo and mpi I have personaly run 5 diff turbos over the years.
Edited by TainterRacing (02/03/12 07:40 PM)
FrankR
Reged: 02/01/04
Loc: Columbia, SC
      #1258733 - 02/03/12 07:33 PM
I dyno'd a couple of my 3.0L blower engines on a Mustang eddy current machine. I've forgotten the numbers shown at the wheels, but adding a bit for driveline losses, I figured 225HP/300TQ at the flywheel with ~6psi.
So much of the derived numbers on dynos depend on too many variables to ever take the numbers seriously for anything other than a vehicle-to-vehicle relative comparison (on the same machine with the same settings), or for a same vehicle comparison when making adjustments to engine variables.
Frank
TainterRacing
Reged: 04/17/08
Re: Any one every dyno there 4x4? [Re: FrankR]
      #1258735 - 02/03/12 07:42 PM
What pistonds do you run in your 3.0? I am planing on putting a Turbo on this spring on my 3.0. plan on running 6psi as well.
Edited by TainterRacing (02/03/12 07:44 PM)
6 registered and 29 anonymous users are browsing this forum.
Generated in 0.016 seconds in which 0.006 seconds were spent on a total of 12 queries. Zlib compression enabled.
