Isuzu TrailTalk Forums
Pages: 1 | 2 | (show all)
Wareagle
Reged: 08/08/00
Loc: Knoxville, TN
Re: PRESS RELEASE Independent4x announces the NEW 12 bolt Locker [Re: strawmyers]
      #1069392 - 01/13/08 09:29 AM
Sean is right. You cannot just swap the entire 3rd since the VX has a 4.30 ratio and trooper has a 4.56. You will need to swap the carrier only from an open 3rd into the VX 3rd. Once they are swapped, you will need to check backlash and engagement pattern.
Mark-95Trooper,fr LockRight,rr LSD,5spd,TeraLow,Indy tierods&QD sways,CO2, RS9000Xs,OME912&2.5"spacers,1"BL,ARB w/Warn M8000,OBT rear bumper&sliders. Pics indy4x
Edited by Wareagle (01/13/08 09:30 PM)
matthew
Reged: 01/04/00
Loc: Richmond, VA
Re: PRESS RELEASE Independent4x announces the NEW 12 bolt Locker [Re: Wareagle]
      #1069495 - 01/13/08 09:01 PM
VX uses the same rear axle as the 92-97 trooper
you could also use this as an opportunity to do a gear swap.......you could get an open 4.56 rear 3rd and also swap in a front 4.56 10 bolt 3rd
lots of cool options for hte VX owners
'93 RS 3.2L - DD/trail build
'97 7.3L Powerstroke - tow rig
'71 FJ40 - V-8, nv4500, atlas, D60, 14B - current build
Owner: http://www.INDEPENDENT4x.com
m-f 9am-6pm EST. 804-550-0480
TrooperXS
Reged: 05/11/02
Loc: Columbus, Ohio
Re: PRESS RELEASE Independent4x announces the NEW 12 bolt Locker [Re: matthew]
      #1092070 - 04/18/08 05:56 PM
Matt,
Awsome job i think it's great that you have a 12 bolt locker coming out as well as a 10 bolt and the 3.07 gear set's I'm definetly looking forward to ordering them.
- Jason
2004 GMC
1987 Samurai
Go Army
matthew
Reged: 01/04/00
Loc: Richmond, VA
Re: PRESS RELEASE Independent4x announces the NEW 12 bolt Locker [Re: TrooperXS]
      #1092746 - 04/22/08 10:37 PM
all these products are out and shipping.
thanks for the props.
throwin_roost
Reged: 11/15/06
Loc: Virginia
      #1254027 - 10/25/11 07:10 PM
awesome sounds good.
93 Rodeo 3.2L, 3" body lift, 3" Indy4x lift on 33's, flowmaster50, stainless brakes and clutch lines,
0 registered and 23 anonymous users are browsing this forum.
Generated in 0.018 seconds in which 0.008 seconds were spent on a total of 13 queries. Zlib compression enabled.
