jhuroleye
Reged: 08/08/11
Loc: Mansfield, OH
New to the whole 4x4, offroad, trail running scene (sorry if i ramble). Bought my raider off craigslist (had no idea wtf a raider was) last winter as a beater for $700. Sold the car and kind of fell in love with this little beast! Oh and I want to confirm that 31x10.5x15 inch wheels will mount fine on the stock 15x6 alloy rims with plenty of room(i was questioning this and found guys on here had done it). I bought a set of Pro Comp xterrains off craigslist for $225 :). Anyways, I want to fix it up and make it a fun little mud runner/trail runner. Nothing crazy, just something I can play around in. But it's extremely EXTREMELY rusty... should I even bother? Is it possible to pull the motor in this and put in a raider that was originally a 4 cyl auto (found a couple)? I'd list where the rust is but i don't know crap about cars really... i'm a computer technician for a hospital (i have friends that have shops that would help me).. but for an idea, the back part of the frame is so bad, i was told not to even attempt to tow anything for the back end would probably rip off... the body has rust everywhere... front sway bar (i think) isn't attached at one point because the bolt pulled through where it was mounted... I'd post pictures but not sure what's the best and easiest way to do so...
-------------------- 1989 Dodge Raider V6 3.0
89mitsuraider
Reged: 11/27/10
Loc: Hawaii
You're from Mansfield? Small world. I am from Akron originally.
-------------------- Keep On Rockin' In The Free World
88 Dodge Raider 2.6L 5spd, LSD, Bouncy seat
0778drz110
Reged: 08/31/08
Loc: Boca Raton, FL
31s are going to fit fine. Post pictures of the rust I'd like to see because mine is rusting in a few spots also. Thank god nothing on the frame though.
-------------------- 1988 Montero SWB: 2.6L 5spd 38.5x15 TSL Boggers on 15x14 wheels, 2" body lift, 2" suspension lift, cut fenders, roof rack, 6 55w lights, 10,000lb. winch, pintle hitch
1997 GMC Yukon SLT 4x4: Vortec 5.7L, 4L60E auto, NP243, bluetooth, nav, 4 12" subs, LEDs, HIDs, 2 7" LCDs
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Too much rust to fix. No, it won't go into the 4cyl truck easy, but it can be done with sound donor tranny crossmember swap and some work on the motor mounts. Swap the whole front/rear driveline. Have to weld on coil spring perches...
The truck is worth the work...
xFezx
Reged: 11/28/09
Loc: San Antonio, TX (Lackland AFB)
If you were told you shouldn't tow because the frame is rusted then swap, but if it's just the body then it's just cosmetic. Might be the frame, being Ohio, depending how priors took care of it.
-------------------- You can call me Fez
'95 SR 15x8 steel rims w/ 33x12.5 Duratracs, cranked torsion bars, "Baja" lights
'09 Nissan Sentra SR
jhuroleye
Reged: 08/08/11
Loc: Mansfield, OH
yeah the frame has quite a bit of rust :'( when i bought it, the floor boards were basically gone too... lol and i bought it in the dead of winter... by the time i got home my legs were soaked from the snowy mess that splashed up through the holes... lol i ended up laying down aluminium house siding, filling the holes with that expanding foam, and then throwing spare house carpet down for an insulator and noise canceler! hahaha so hillbilly... but umm... how do i post pictures with this forum? do i have to upload to a free picture hosting site and then link them? or does this forum have a picture upload section?
rxinhed
The Mitsubishi Parts Guy
Reged: 02/21/05
Loc: Gerber, CA
Photos must be hosted, like at Photobucket, Imageshack, etc.
off-roader
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
Yes you do.
96SR Build Up Thread
Old web page
jhuroleye
Reged: 08/08/11
Loc: Mansfield, OH
This is my 1989 Raider :)  Picture of the tires I just got.. 4 tires for $225 :)  Under back right bumper frame.  Under back left bumper frame.  This is back left bumper looking into the wheel well This is behind the front passenger wheel. Taken from the front of the car.  This is taken from the front of the bumper. I was showing how the bolt snapped that held the sway arm up against the frame. Drivers side. This is behind the drivers wheel taken from the front. Again you can see how the sway bar is dropped and it's hard to see, but the top left nut on the gear box broke off (or whatever that thing is called).
StockRaider
Reged: 09/23/04
Loc: Williamsport PA
I would tell you to enjoy the time you and it have together until it breaks. I would be calling junkyards and make sure your on a list if a clean one comes in. If the engine and drivetrain are good I would swap it into a clean truck. That, or find a rolled truck and swap frames. I wash my trucks weekly here in PA just for to prevent whats happening to your truck. be thankful mitsu used boxed frames or that truck would of broke in half long ago. also, welcome to the wire!
-------------------- Richard E
xFezx
Reged: 11/28/09
I'd be afraid to drive it. My 95 SR came from MN, and I thought it had bad rust. If your up to it, there are a few Gen 1's here in San Antonio area for sale. And I would bet money they are just as rust free as the day they left the lot.
jhuroleye
Reged: 08/08/11
Loc: Mansfield, OH
:'( guess i'll just run her til she breaks... i'll start looking to see if i can find one around my area first... texas is soooo far.. lol thanks guys!
MI_Mitsu
Reged: 03/24/06
Loc: Romulus, Michigan (Detroit)
I've got an 87 SWB raider originally from FL I'm currently offering as part of my fleet ot Mitsubishi's I'm trying to sell off. Just a stone's throw away in SE Michigan between Ann Arbor and Detroit. Engien is currently out for a rebuild - but have all those parts if you have the time and desire. PM me if interested.
-------------------- 89 Montero LS 3.0L/Auto
91 Montero RS 3.0L/Auto
87 Dodge Raider 2.6L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (identical to my 1st), 88 Conquest SHP
Others: 37 Lincoln
jhuroleye
Reged: 08/08/11
Loc: Mansfield, OH
sorry i'm a n00b... but what's SWB?? and i would love to come get it... but i have no where to store it at the moment... i don't have a garage... or anywhere to put it outside for that matter... i gotta get my own house... ugh
StockRaider
Reged: 09/23/04
SWB (short wheel base) - 2door Montero Sport (gen1 only), Raider LWB (long wheel base) - 4door Montero LS, Montero RS
don
Reged: 05/17/00
Loc: Vancouver, BC, Canada
Wow. I'd worry about the gas tank falling off, and the steering box as well. Please don't put other drivers at risk...
If you do get in an accident, it's possible your frame and body will seperate.
Be careful.
-------------------- Don `87 Mitsu 2dr, Rubicon survivor, GModified.
jhuroleye
Reged: 08/08/11
Loc: Mansfield, OH
well the tank is new last year... guy before me put it in and secured it at other points... but yeah... its bad... lol took it on some logging trails this past weekend... lol it was soooo much fun! i had more fun in this than on quads! granted... i've got much larger holes now! hahaha i just want it to last one more winter... so i probably won't be going on anymore trails...
StockRaider
Reged: 09/23/04
Your close enough to pa? i see fairly decent Raiders pop up on CL for around $600 with a bad timing belt or something. ive never seen a truck that badly rusted before... Cant save yours, but you could use your trucks parts to save a nice one from the crusher...
Va_Stumpy
Reged: 08/26/09
Loc: Southside VA
Around here we call them doners!(as in to donate) Drive with caution & avoid speed bumps at all cost.
-------------------- Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
