Pages: 1
xFezx
Reged: 11/28/09
Loc: San Antonio, TX (Lackland AFB)
Blinking 4x4 lights
      #1226176 - 10/20/10 03:22 PM
I have read the threads about the lights, but I just want to make sure that it is okay to drive on the highway (over 65) because as I understand it isn't actually trying to lock in, just confused. The lights aren't always blinking, sometimes they don't blink after turning the truck on. Eventually I will replace them with manuals along with a locker. It's good to hear there is a direct go to guy that is brave enough to drag them through the airports.
You can call me Fez
'95 SR 15x8 steel rims w/ 33x12.5 Duratracs, cranked torsion bars, "Baja" lights
'09 Nissan Sentra SR
WigWiggy
Reged: 04/02/09
Loc: Western MD
Re: Blinking 4x4 lights [Re: xFezx]
      #1226179 - 10/20/10 04:20 PM
Just to clear up one thing for you - switching to manual hubs won't solve the problem as the genII system engages at the front diff. Central axle disconnect I think it's called. The hubs don't disconnect like they do in the gen1. Your front wheels are always turning the front axles, even when in 2WD.
As long as your t-case lever is in 2hi, and it doesn't 'feel' like you're in 4WD, and you don't hear any horrible grinding noises, it should be fine to drive at speed. That's been my experience at least.
98 Montero, 184k.
JohnnyBfromPeoria
Reged: 06/10/02
Loc: Phoenix, AZ
Re: Blinking 4x4 lights [Re: WigWiggy]
      #1226204 - 10/20/10 10:47 PM
Kind of off topic, but can't you drive a Gen 2 in AWD/4-hi-unlocked central diff at any speed, on any road surface?
Yes, CAD, or central axle disconnect, is how a Gen 2 goes into 2wd. Adding manual hubs will disconnect the wheels from the axle shafts, perhaps saving a bit of wear and tear and possibly netting a slight MPG gain. And, if you're so inclined, you can engage 4-low-loc with the hubs unlocked and get low-range two wheel drive. You can also forget that you unlocked the hubs, put the transfer case in AWD/4-hi-unlocked center diff and see how effective the combination is at sending torque to the non-functioning front drive axle. Yes, I've done it, and wondered why the truck was revving and not moving so well. Oops.
John B.
4ePikanini
Reged: 05/07/09
Loc: South Africa
Re: Blinking 4x4 lights [Re: JohnnyBfromPeoria]
      #1226211 - 10/21/10 02:25 AM
Gen2 super select
Basically there are three main things that get detected by the transfer case, and front diff actuator sensors, that play a part in the flashing lights system. The sensors detect whether the transfer case is in 2H, 4H or 4HLc (4LLc to the ECU is the same as 4HLc)
When the sensors on the transfer case doesn't correspond with what the sensor on the vacuum actuator detects, then you will have the flashing lights. Either way.
So if the front diff vacuum actuator senses that the right sideshaft is engaged but the transfer case sensor detects that you have selected 2H then the lights will flash.
Also if the front diff vacuum actuator senses that the right sideshaft is disengaged but the transfer case sensor detects anything other than 2H then the lights will flash.
On the Gen2 the centre diff is 100% mechanical. ie. if you select 4H then the front and rear propshafts are connected via VCU. If you select 4HLc or 4LLc you will lock the front and rear propshafts together.
2H
When you select 2H the engine drives the rear propshaft and the front is disconnected inside the transfer case. The front left sideshaft is connected to the front diff. The vacuum actuator disconnects the front ride sideshaft from the front diff. The front propshaft gets driven via the left front wheel through the diff.
4H
The transfer case attaches the front and rear propshafts via a viscous coupling and the front right sideshaft gets engaged via vacuum actuator to the front diff.
4HLc
This the same as 4H but the front and rear propshafts are solidly connected to each other. The middle amber light on the dash illuminates.
4LLc
Same as 4HLLc but low range gears
In a nutshell then the selection on the super select transfer case is all mechanical except for the engagement of the front right sideshaft to the front diff via a vacuum actuator that gets controlled through a small ecu box behind the radio based on sensor inputs on the transfer case.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Re: Blinking 4x4 lights [Re: 4ePikanini]
      #1226217 - 10/21/10 08:37 AM
Archive the afrikaaner's post above please. best description of super select so far - in the tech threads I would think.
JohnnyBfromPeoria
Reged: 06/10/02
Loc: Phoenix, AZ
Re: Blinking 4x4 lights [Re: fasteddy]
      #1226268 - 10/21/10 10:42 PM
Also makes an even greater case for having manual hubs on a Gen 2.
Back to my off-topic leanings, can anyone else confirm that a Gen 2 can be driven in 4-Hi-unlocked/AWD at any speed, on any road surface?
John B.
4ePikanini
Reged: 05/07/09
Loc: South Africa
      #1226278 - 10/22/10 02:20 AM
4H can be driven on any surface at any speed (disclaimer : when safe to do so within legal limits) but must be selected at under 100km/h (60mph). In other words 4H = AWD
4HLc can be driven on anything other than a high grip (concrete, tar, rock etc) surface.
2H - economical RWD
4H - Tar, good gravel (AWD)
4HLc - Snow, Ice, mud, bad gravel
4LLc - heavy stuff
Edited by 4ePikanini (10/22/10 03:13 AM)
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
      #1226293 - 10/22/10 11:12 AM
add to 4LLc, for any creeping except on dry hard surface-center diff binding. I'd like a straight 4lo with the cdiff unlocked, too.
Isn't there a way somebody posted once upon a time about rewiring the switching to add more flexibility like that one?
Pages: 1
12 registered and 70 anonymous users are browsing this forum.
Generated in 0.018 seconds in which 0.006 seconds were spent on a total of 11 queries. Zlib compression enabled.
