HpyUnBday
Reged: 09/13/07
I turn the key – nothing – no power – no lights – no clock - completely dead. The only way to get it started is to jump it. After it is started it runs fine till I shut it off – then it goes completely dead – flatline No matter if I shut it off for a long time or a short time - same thing. No matter if its hot or cold - same thing- dead.
The battery is good The alternator is good The starter is good Terminals are clean Any ideas?
jaboo5322
Reged: 01/13/08
Loc: Rittman Ohio
Did Someone load test the battery? Or maybe do a volt drop test through the terminals. On my 01, the positive cable has corrosion where the wire goes into the crimp on the ring terminal. Every once in a while, i have to wiggle it to get it to start. But while testing, it all showed good. Good luck.
-------------------- 2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
bombardj1
Reged: 08/25/06
Loc: New Philadelphia, Ohio, USA
remove and clean terminals, clean posts, deep cycle battery or replace it.
-------------------- 2001 5sp. K&N stock filter 215/70/15
DennisThompson
Reged: 03/15/02
Loc: Utah
Your battery can show 12 volts but be very low an amps. If you can jump start it fine it almost has to be in the battery or battery cabels/terminals.
Lou
Reged: 03/15/04
Loc: Chicoutimi,Canada
The battery is good Terminals are clean
Onw of these two must be reconsidered
DamKia
Kia Moderator
Reged: 02/10/03
Loc: Gold Coast, Queensland, Austra...
When you are jumping it, what are you connecting to? Straight across the battery or battery +ve and a good engine earth?
If it is straight across the battery then the battery is cactus (test by keying on the starter and measuring the voltage across the battery). If you are using an engine earth then the -ve to engine earth cable is corroded.
-------------------- 2002 Sporty , Ironman 2.5" spring, 2" body, 15 x 7 ROH wheels, K&N, 15 x 10.5 Simex Centipedes, Powerchip 91.
