Mitsubishi Forums >> Mitsubishi Diesels
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | >> (show all)
JeffatTireBalls
Reged: 09/17/06
Loc: Kentucky
Re: Ranger - Montero Diesel Swap thread [Re: dylanb]
      #1168452 - 07/25/09 09:37 PM
Any updates on this project?
99 Montero SR
Mazda B2600i with 4D56T diesel swap http://www.4x4wire.com/forums/showflat.php?Cat=0&Number=1240274&page=0&vc=1&PHPSESSID=#Post1240274
torquemonster
Reged: 01/12/05
Loc: Red Deer, Alberta
Re: Ranger - Montero Diesel Swap thread [Re: JeffatTireBalls]
      #1168512 - 07/26/09 01:40 PM
I am going to be having some questions once I am under way on my project, a 4D56T into a 2wd Ram 50.
dudly
Reged: 03/08/09
Loc: Chilliwack BC Canada
Re: Ranger - Montero Diesel Swap thread [Re: tony007]
      #1197082 - 02/02/10 11:49 PM
There is a guy in Utah that can get harmonic balancers, I found him when looking for a ranger harmonic. Which is harder to find.
87 Montero, 88 Raider diesel, two 86 Ranger diesels, 99 F350 Super duty Diesel
pmontero
Reged: 07/12/01
Loc: Peachtree City, GA USA
Re: Ranger - Montero Diesel Swap thread [Re: dudly]
      #1206323 - 04/03/10 11:15 PM
Well, I'm back to work on the Montero Diesel Swap from a Ranger. I stopped by a yard today to pick up a skid plate, power steering reservoir and another bouncy seat but only scored the bouncy seat and another spare hazard switch. While my son worked on pulling the front seats and installing the dual bouncy seats, I worked on loosening the oil pan bolts and checked orientation of the Montero oil pan I'll be using on the engine.
Here's a tilted pic of the 4d55 showing the Ford Ranger pan orientation and oil pan bolts.
Here's a pic of the front of the engine. The red arrow indicates a broken fan pulley bolt I'll need to take care of. I have some spare bolts I picked up off of fleabay along with a complete set of oil pan bolts.
Here's a pic of the Montero oil pan and the Felpro heavy paper gasket I purchased for installing the oil pan. Any pointers on the best way to seal the pan? I'm thinking of smearing some clear RTV on both sides of the gasket before installing the pan. Should I do this or just leave it dry?
Here's a shot of the rear of the engine. I need to clean up the caked-on oil and will be replacing the valve cover gasket, valve cover bolt grommets and the rear main seal before installing the engine in the Montero.
Here's a pic of the turbo side of the engine. Both of the oil cooler lines are loose and leaking badly. The whole side of the engine is caked with oily dirt. After cleaning it up, I'm either going to remove the oil cooler lines and plug the holes with correct-sized bolts or fix the leaks and run an oil cooler.
I've still got a bunch to do to the engine to get it ready to drop in.
-Pmontero (better late than never... I started this swap and thread three years ago!)
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
pmontero
Reged: 07/12/01
Re: Ranger - Montero Diesel Swap thread [Re: pmontero]
      #1206342 - 04/04/10 08:35 AM
I was just reading back through the thread to refresh my memory on previous research and realized that I never went back and posted the oil pan gasket part number. (it wouldn't let me edit old posts) Here you go:
2.3 Oil Pan Gasket - NAPA OS30400 A
This is also the standard Felpro part number
I found directions on the back stating that I should apply "adhesive" to the mating surfaces of the gasket. I assumed that was the case. I'll be smearing clear RTV on both sides after everything is scraped clean and wiped with acetone.
Does anyone know where I can source a bottom skid plate for a Montero? Most of the junkyard vehicles are mssing the skid plate so far.
-Pmontero
'87 Montero Diesel
and more...
Greasology
NotPetroleum
Macka
Reged: 05/23/04
Loc: off road in the great white no...
      #1206360 - 04/04/10 12:50 PM
I have em, I have the front and t case. I can get my wife to find out about shipping as I am in Calgary right now. Make me an offer plus shipping and they are yours. I'm going custom on my next project.
suffering from lack o'wheeling
PHILModerator
Reged: 01/09/00
Loc: Airdrie, Alberta
Re: Ranger - Montero Diesel Swap thread [Re: Macka]
      #1206361 - 04/04/10 12:57 PM
Good to see you back Powell. As for this mysterious "Macka" character, you already know him - are you sure you wanna run "Pig" parts on your Montero?
Macka
Reged: 05/23/04
Re: Ranger - Montero Diesel Swap thread [Re: PHIL]
      #1206365 - 04/04/10 01:14 PM
Actually Phil, they aren't PIG parts. They are from the dump in Terrace Bay, where a badly rusted blown engine SWB was sitting. I recovered them and was going to try to find another decent SWB to make into PIG2. Now I think I will have to go another route, starting with a LWB genI donor body a diesel gen3 front cut and of course a sawzall and a MIG. Seeing Erics rig really got my thinking cap heated up.
Mitsulvr
Reged: 03/26/06
Loc: Yellowknife NWT
      #1206384 - 04/04/10 04:33 PM
Sorry about that
The gen3 diesel swap is on my list of dreams aswell. I say do it
Eric Wegerich
89 Montero as chopped as can be. Now with 5.29's
pmontero
Reged: 07/12/01
Re: Ranger - Montero Diesel Swap thread [Re: Mitsulvr]
      #1206424 - 04/04/10 09:52 PM
Thanks folks! It's good to be back. Macka, let me check two local sources and if they don't pan out, I'll shoot you a PM.
-P
'87 Montero Diesel
and more...
Greasology
NotPetroleum
0 registered and 5 anonymous users are browsing this forum.
Moderator:  LandRaider, PHIL
Generated in 0.022 seconds in which 0.009 seconds were spent on a total of 11 queries. Zlib compression enabled.
