Pages: 1 | 2 | >> (show all)
4ePikanini
Reged: 05/07/09
Loc: South Africa
Mitsubishi V6 Lifter Tick Fix
      #1198178 - 02/09/10 03:26 AM
This is an extraction from the Mitsubishi workshop manual
I have also found that there are 2 different lifters.
1 Has a small hole with about a 1mm hole diameter whereas the revised version has a bigger hole of about 3mm diameter. These bigger hole lifters paired with Caltex delo 400 oil makes them virtually 100% silent
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
off-roaderModerator
Mitsubishi Forum Moderator
Reged: 01/16/00
Loc: Bay Area, CA
Re: Mitsubishi V6 Lifter Tick Fix [Re: 4ePikanini]
      #1198201 - 02/09/10 09:55 AM
Stickied.
Off Roader
96SR Build Up Thread
Old web page
89IsMine
Reged: 05/16/05
Loc: San Jose, CA
Re: Mitsubishi V6 Lifter Tick Fix [Re: off-roader]
      #1198214 - 02/09/10 11:33 AM
Stickied.
Really? Maybe I misunderstand what "stickied" means... I thought if it was stickied it would get a little "stick pin" icon and stay at the top of the first page... kind of like the "tech reference" thread. I don't see that with this one
Eric W.
'89 Dodge Raider -- 3.0L V6, MT, SWB
Edited by 89IsMine (02/09/10 11:34 AM)
0778drz110
Reged: 08/31/08
Loc: Boca Raton, FL
Re: Mitsubishi V6 Lifter Tick Fix [Re: 89IsMine]
      #1198223 - 02/09/10 01:00 PM
Stickied.
Eric W.
if you stickied everything, you would have to go to page 3 to find the first thread...When I joined, there were only 3 threads on the first page that weren't stickies
1988 Montero SWB: 2.6L 5spd 38.5x15 TSL Boggers on 15x14 wheels, 2" body lift, 2" suspension lift, cut fenders, roof rack, 6 55w lights, 10,000lb. winch, pintle hitch
1997 GMC Yukon SLT 4x4: Vortec 5.7L, 4L60E auto, NP243, bluetooth, nav, 4 12" subs, LEDs, HIDs, 2 7" LCDs
Grasscat
Reged: 02/04/05
Loc: Livermore, Ca
      #1198258 - 02/09/10 03:55 PM
Stickied.
Eric W.
Here is where the sticky went "Mitsubishi Tech: Reference Threads (please check here for answers before asking questions)"
Michael j
TreadLightly! Trainer
89IsMine
Reged: 05/16/05
Loc: San Jose, CA
Re: Mitsubishi V6 Lifter Tick Fix [Re: Grasscat]
      #1198319 - 02/09/10 11:37 PM
Doh! Silly me Thanks, Michael
Eric W.
sparkem
Reged: 12/12/00
Loc: Ponchatoula, LA
      #1198445 - 02/10/10 09:59 PM
Talking to the guy who rebuilt my heads for my 3.slow, I found out that is not the only reason they tick. He said he rebuilt a ton of the 3.0 heads back in the 90s. He said the rocker arm actually gets worn down where the lifter goes into it.
ES_97Sport
Reged: 07/19/03
Loc: Colorado, US
Re: Mitsubishi V6 Lifter Tick Fix [Re: sparkem]
      #1198793 - 02/12/10 04:32 PM
That's what the techs told me, too.
The 3.0L in the '97 Sport had the small hole. Prone to clogging. In '98 they switched to the larger hole lifter to get away from that problem. Least-wise that's what I was told.
Edward
NP231 B4R doubler/Terra Low231/RP 5.38 228:1
'03 Montero Sport Limited AWD
'97 Montero Sport LS 5-Speed 3-link/SAS project
Angelo
Reged: 02/21/02
Loc: Charlotte NC
Re: Mitsubishi V6 Lifter Tick Fix [Re: ES_97Sport]
      #1198988 - 02/14/10 08:15 AM
Good stuff
99JAOS2"& OME 2"body 4.90s ARB HS9500i Skids&Ladder 16"315BFG JAOSRemote& Rack 3Row Rad IPF back& Searchlite 33TSL StreetLock HID Overhead Console/CB switchPanel FrARB RrLocker TJMSnorkel 160AAlt Sliders 2nd Tranny Cooler QuickAirII& Tank Rear frame/tank Lift
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Re: Mitsubishi V6 Lifter Tick Fix [Re: Angelo]
      #1199014 - 02/14/10 03:02 PM
I have successfull bled the lifters on the truck. I pull the valve covers, ground the coil wire, and crank the truck until the gauge shows pressure. Then, using a fine probe (I use a blunted sewing needle or straight pin) go thru the tiny hole in the lifter end of the rocker and depress the check ball, and while pressing, push down on the lifter to force out the air (if the rocker is under valve spring pressure, you dont have to push the rocker). Repeat the cranking as necessary to keep oil to the lifter oil gallery.
This has cured a cronic lifter tick that the rev/coast/rev cycle would not clear up.
dannytuned
Reged: 10/07/06
Loc: St. John, IN
Re: Mitsubishi V6 Lifter Tick Fix [Re: fasteddy]
      #1199119 - 02/15/10 10:25 AM
I'll have to try this one, good idea.
BTW My 2001 Sport had the small hole version(I think). I had to use welding wire to bench bleed them, none of my picks would fit through the hole.
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
heathdogg
Reged: 03/20/06
Loc: Flagstaff, Az
Re: Mitsubishi V6 Lifter Tick Fix [Re: dannytuned]
      #1199317 - 02/16/10 02:59 PM
When I redid the heads on mine, I had lifters fall apart when I pulled them out of rockers.
Beast: 90 Montero Lwb V6 Base, F&R LSD, Gen II Rear Coils,Front Rotors & Calipers, Load Adjusting Front Shocks, RS70081 coil spacers, Superwinch Hubs, Toyota Alloy Rims, Dual bouncy's.
Beauty: 90 Montero Lwb V6 RS Model, Stock (awaiting modifications)
4 registered and 27 anonymous users are browsing this forum.
Generated in 0.016 seconds in which 0.006 seconds were spent on a total of 11 queries. Zlib compression enabled.
