Pages: 1 | 2 | 3 | 4 | 5 | 6 | (show all)
GreatWhiteShark
Reged: 11/08/09
Loc: California
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: LRJ4x4]
      #1188558 - 12/04/09 08:32 PM
do the V6 Montero's have a bigger gas tank than the 4 cylinders? The 13 gallon one in the MudRaider is just silly. I swapped a 20 gallon one from a different S-10 into my originally equipped 14 gallon tank S-10, wondering if that is possible or even an option?
Try being out West with a Gen 1 ! That tank is way to small for the MPG it gets.
sorry to hijack....any close ups of that gas can mount?
My Lift is causing my transfer case gears to grind!
0778drz110
Reged: 08/31/08
Loc: Boca Raton, FL
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: GreatWhiteShark]
      #1188560 - 12/04/09 08:39 PM
good luck, he no longer owns that SWB any more
1988 Montero SWB: 2.6L 5spd 38.5x15 TSL Boggers on 15x14 wheels, 2" body lift, 2" suspension lift, cut fenders, roof rack, 6 55w lights, 10,000lb. winch, pintle hitch
1997 GMC Yukon SLT 4x4: Vortec 5.7L, 4L60E auto, NP243, bluetooth, nav, 4 12" subs, LEDs, HIDs, 2 7" LCDs
      #1188591 - 12/04/09 11:49 PM
I think I have one like it sitting on the shelf in the garage, Kris. I'll see if I can get a pic up this weekend.
EDIT: Here's a shot of what I think is the same gas can mount on my old White Monty.
Edited by Oyaji_Jon (12/05/09 12:06 AM)
GreatWhiteShark
Reged: 11/08/09
Loc: California
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: Oyaji_Jon]
      #1188603 - 12/05/09 12:25 AM
Thank You. not quite what i thought i was going to see. but still cool. by the way my name is Ben.
      #1188606 - 12/05/09 12:41 AM
Ok, Ben.
That holder is a clamp of sorts. The little round "eye" on top is a screw that tightens the top plate onto the lip of the gas can as it turns. On the back of the aluminum piece was a piece of U-channel that I thought was cheesy, so I ground it off and welded a piece of one sized pipe to the plate that bolts to the tire mount and a larger size pipe to the plate that mounts to the "clamp" assembly. I then slipped the small pipe into the larger pipe and drilled a hole all the way through so a pin can be put in to make a quick release for the clamp. That made mounting the spare easier and I'm able to put other "attachments" on there with the right size of pipe.
Anyway, more info than you asked for, but there it is...
GreatWhiteShark
Reged: 11/08/09
Loc: California
      #1188664 - 12/05/09 10:36 AM
That is Fantastic! Now i have a idea and i will get on it Sunday. :)
89Montiero
Reged: 10/21/04
Loc: Idaho, USA
      #1188758 - 12/05/09 07:08 PM
Is that a land rover discovery ladder on the back of your white Montero? I saw one the other day and was wondering if it would fit a gen I and it looks like it does. Great! Did you have to modify it to fit at all?
thanks,
1989 Mitsubishi Montero SWB V6. Torsion bar crank, Gen II springs, 31X10.5" BF Goodrich M/T's
2005 Mitsubishi Montero Limited 3.8 V6
2011 Subaru Impreza Outback Sport
0778drz110
Reged: 08/31/08
Loc: Boca Raton, FL
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: 89Montiero]
      #1188759 - 12/05/09 07:15 PM
thanks,
yes it is, do a search for ladders there was some talk a couple weeks ago
MontyMcV
Reged: 06/04/03
Loc: Cleve-burg OH USA
Re: Is there a bigger gast tank for the Gen 1's that is a bolt in? [Re: 0778drz110]
      #1188805 - 12/06/09 01:00 AM
The Disco ladder can be readily made to fit.
Big Truck 1: 95, MT, >Gone<
FSMs: MitsubishiLinks.com
      #1188812 - 12/06/09 02:39 AM
thanks,
I'm glad you know what was on my truck because I can't confirm what it was supposed to be for. It was on there when I bought it.
13 registered and 45 anonymous users are browsing this forum.
Generated in 0.021 seconds in which 0.007 seconds were spent on a total of 11 queries. Zlib compression enabled.
