Mudraider
Reged: 12/16/07
Loc: Orange Park, FL
do the V6 Montero's have a bigger gas tank than the 4 cylinders? The 13 gallon one in the MudRaider is just silly. I swapped a 20 gallon one from a different S-10 into my originally equipped 14 gallon tank S-10, wondering if that is possible or even an option?
-------------------- 87 Raider,3.5 soon,, 35's w/ a 4" BL,
Edited by PHIL (12/02/09 09:18 PM)
shadowgear
Reged: 12/06/04
Loc: C eh, N eh, D eh
IIRC the V6 tank is a larger unit, but there will be fitment issues from what I have read...I'll let someone more knowledgeable chime in.
-------------------- '88 Raider 2.6L - SW Hubs, Weber 32/36, Off-road Pkg - Rust repair in progress
'88 Monty 2.7L - 5" Lift, Weber 38, 33's, Dual Fans, Dual bouncy (more goodies to install)
'03 Monty Sport - XLS, BFG A/T's
GreatWhiteShark
Reged: 11/08/09
Loc: California
i wish! not without a lot of custom work. Best to just bolt a fuel cell in or leave it alone
-------------------- My Lift is causing my transfer case gears to grind!
TOASTY
Reged: 01/17/02
Loc: Gilbert AZ, US.
search outerlimits4x4.com there is a long range fuel tank setup that those guys use.
MartySoCal
Reged: 05/31/09
Loc: SoCal
I was able to use a YJ 20 gallon plastic tank in my friends' '86 Montero. The old sheet metal tank was down to about 11 gallons after getting smashed numerous times!
I made my own skid plate/carrier in the style of the YJ original, but out of 1/4" plate on the bottom and 1/8" sides. I had to make new mounting tabs for the crossmember behind the rear axle, I cut the old ones off. A ZJ sender unit on the YJ in-tank module with a resistor added works the stock fuel gauge with good accuracy. I had to make some adapters for the fuel filler hoses, but it wasn't too hard to do. I re-routed the tailpipe to come out the right side between the spring and frame, instead of straight out the rear. It's been in there 10 years or so, now.
If I can remember, I'll take some pics of it the next time he brings the truck by my house.
P.S. If I had to do it again, I would build a full custom tank, and get the capacity at about 25 gallons by eliminating the angled front corners of the YJ tank and making it conform closer to the contours of the floor and frame.
Temple
Reged: 10/09/08
Loc: Portsmouth, VA.
IF you can weld.... this is always an option.
How to Make a Gas Tank Contributor By Steve Smith
eHow Contributing Writer Article Rating: (0 Ratings) A gas tank is a necessary part of a car or any other vehicle that uses a combustible engine. Tanks are generally made of metal, but some are also made of fiberglass and high-density plastic. You can make your own gas tank using metal-shaping tools and 12-gauge sheet metal and install it on a car, truck or ATV. You should be familiar with metal working and have a hydraulic press brake before undertaking this project.
Email Print Article Add to Favorites Flag Article Difficulty: Moderately ChallengingInstructionsThings You'll Need: Poster board for a template Sheet metal Metal cutting tools Welding equipment Step 1Create a template for the gas tank by tracing an area 3 feet long by 2 feet wide on a piece of poster board. The area will have straight, 90-degree corners. Place the template on a piece of sheet metal and trace around the edge with a grease pen. This will make one half of the gas tank; the other half will be made with an identical piece. Place the template on another piece of sheet metal and again trace the shape onto the sheet metal.
Step 2Cut out the shapes using a metal saw, carefully guiding the sheet metal through the saw to create a straight, even cut. If you have a saw with a guide, use it to make a better cut.
Step 3Place one of the sheets on a hydraulic metal press---6 inches of the 3 foot side of the sheet metal needs to be past the brake blade (the outer edge of the brake blade will be six inches).
Step 4Bend the metal to a 90-degree angle. Remove the sheet metal, turn it around and repeat step 4 for the other longer side. Repeat steps 4 and 5 on the other sheet. Both pieces of sheet metal will have two bent edges, making two halves of a gas tank.
Step 5Place one of the pieces on a work bench so the flat side is flush with the bench and the bent sides are facing up. Place two C-clamps on each corner of the bent sides.
Step 6Set the second piece onto the first, aligning the corners of both pieces bent sides. Tighten the C-clamps so half of the clamp is holding one side and half holding the other. This secures the two pieces together for your weld.
Step 7Create three tack welds in each side along the seams of the two pieces. With a gas arc welder and #3 filler bar. Make sure the two halves are aligned properly. Finish the weld using a gas welder and #3 filler bar. The welds must be leak-proof. Use extra filler, if necessary. Be careful when making the welds.
Step 8Measure the height and width of the openings on both sides of the gas tank. Trace and cut two matching sections from the sheet metal to build the sides of the tank. Secure the pieces to the tank with by making a tack weld first on the bottom and top edge. Complete the weld using another #3 filler bar.
Step 9Cut a hole for the petcock valve using a 1-inch metal drill bit (or larger if the petcock valve is larger). Cut another hole for the fuel line and fuel pump assembly. Use a 3/8-inch bit or metal saw for this step. Each fuel pump assembly is different; accurately measure yours to find the proper measurements and dimensions.
Step 10Attach mounting brackets. Measure the chassis of the car where the tank is going to be mounted. Cut two or four mounting brackets from 1/4 steel plates or steel channel bar to match these measurements. Weld them to the top of the tank using a gas welder and filler bar. Each fuel tank mounts in a different way to the car; you'll have to make yours custom to your particular vehicle.
-------------------- "No obstacle brute force and ignorance cant overcome"
89 SWB RAIDER (IN PIECES)
06 F250 SuperDuty Axles
Currently saving for F-O-A 18" Coilovers
Cummins 4bt/5r110w/np271
LRJ4x4
Reged: 12/17/01
Loc: Monterey, CA
Try being out West with a Gen 1 ! That tank is way to small for the MPG it gets.
-------------------- 98 Montero with cold weather package
Mudraider
Reged: 12/16/07
Thanks Marty, that's an option. Temple, I can weld but I dunnno about a gas tank. Sometimes it would be nice to be back where I was originally from. A lot of people (wellat least a couple) that could be helpful with that.
So you guys with the LWB 3.0 engines only have a 13 gallon tank? LM off at Mitsubishi's faux pas on that.
OldColt
Reged: 09/19/06
Loc: East Wallyworld Vermont
I will have to get some pictures of the custom tank in my 87. After crushing the tank on bolders and then realizing that when towing car trailers at 9-10 Mpg that Sunday nights coming home from events just sucked. The gas stations up here close early and I could only go 100 miles between fills. I decided to build a tank. The bottom of my tank is 5/16 aluminum and with the baffles in the tank I can jack the vehicle anywhere on the tank itself. The best part, it holds about 35 gallons. I will try and get some pics of it when the weather passes.
-------------------- Cheers, Charlie
If It ain't broke, Modify it!
ffmsd.com
Mudraider
Reged: 12/16/07
That would be appreciated. Thanks.
