KrzyDav
Reged: 03/11/03
Loc: SLO County, CA 93453
I'm needing to oval out 4 holes on my axle to change the pinion angle. I don't have a diegrinder or air compressor. I also can't find a proper sized die grind stone around here.
I was looking at carbide deburring bits. Use them in a drill or dremmel and spend a couple days grinding... Maybe I can invent a chuck for my angle grinder.
Your Thoughts please........
-------------------- dave h.
'89 Raider V6 5spd,Aisin Hubs,M.Sport frt. calipers,OME910 coils; Gen2: U.C.arms/T. arms/idler arm/LSD w.disc brakes;2 battery system;relocated ECU;cust.bumpers;J.Baker receiver;Conferr rack.
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
cut the square tang off a round/rat tail file and chuck it in a drill?
drill a set of small holes with elec. drill in the area to be removed to cut down grinding time?
-------------------- "If you turn yourself into a sheep, the wolves will eat you." B. Franklin
95 SR named Ella 120k mi
ForcedAir_Montero
Reged: 04/21/03
Loc: Lynden, Washington
How much material? How thick, and what size hole are you going from, and how "long" are the oval holes needed?
-------------------- -Dave D
Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..."
-Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
TOASTY
Reged: 01/17/02
Loc: Gilbert AZ, US.
carbide bur on a die grinder will do the job in minutes even it you only get a harbour freight cheapie.
-------------------- I need Gen 2 parts! Got any?
KrzyDav
Reged: 03/11/03
I don't know yet how much metal I have to remove. Maybe tomorrow. Right now I'm removing a U joint, I got some problems there.
I'm planning on removing the rear mounting bolt and pulling down on the campanion flange. I think the back bolt holes will be easier to work with, easier to get to to weld, etc. plus the ovaling will be verticle and may hole better untill I can drive 50 miles to the welder. My access and the availability of tools in this rural areas is quite limited. I don't have a lot of confidence in cutting the oval without screwing it up.
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
I would guess the amount of 1/8" thick metal to remove would be a lot less than 1/4", probably just under 1/8".
