4x4Wire.com's Trail Talk Forums: 4WD, 4x4, SUV, Off-Road and Outdoor Recreation Forums
OMIX-ADA Car Parts
APW LARGEST SELECTION OF AUTO PARTS
RUST BULLET AUTOMOTIVE
4x4Wire Portal | Galleries | Offtopic Chat | Garage Sale | Items Wanted | Vendors | Trailrides & Events | 4x4Wire Reader Map
4x4Wire Mitsubishi Section | Mitsubishi Reader's Rides
4x4Wire TrailTalk Mitsubishi Forums: Mitsubishi 4x4 & SUV Tech | Mitsubishi Diesels | Mitsubishi Archives
87monty
Reged: 11/06/08
Loc: Visalia CA, Central Valley
Rear leafs flat as a board.
      #1183912 - 11/02/09 02:40 PM
What is a good Combo? Im not looking for a quick fix really.
Is there any leaf-packs that are pretty much a bolt up but with a good ride still? I plan on towing a small trailer soon as well.
1987 Montero 4speed auto with bfg 33/12.50 15's on black 8 hole 15x8 steelies, custom roof rack. Weber carb and a LSD Out back, Soon to Install starion turbo2.6L thats on the stand waiting!!
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Re: Rear leafs flat as a board. [Re: 87monty]
      #1183913 - 11/02/09 02:42 PM
Find a truck spring shop and get the old ones re-arched and add a leaf. They retemper the steel, too, in most cases. Not very expensive at all...
"If you turn yourself into a sheep, the wolves will eat you." B. Franklin
95 SR named Ella 120k mi
87monty
Reged: 11/06/08
Re: Rear leafs flat as a board. [Re: fasteddy]
      #1183915 - 11/02/09 02:46 PM
It works pretty good? I think there is a shop downtown that may do it. So no other leaf pack that may bolt up?
What add a leaf do you suggest?
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
      #1183919 - 11/02/09 02:52 PM
Around here it's Big Moe Spring and Brake, a chain, I think. I'd take their recomendation on the add on, if any. I'd also get the teflon interleaf thingys for smoother ride, and new bushings. Adding a leaf will make the pack a lot stiffer, which it may not need, and somewhat limit articulation...
87monty
Reged: 11/06/08
      #1183923 - 11/02/09 03:29 PM
Where would I find the bushing kit is there a part number or good aftermarket brand?
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Re: Rear leafs flat as a board. *DELETED* [Re: 87monty]
      #1184361 - 11/05/09 09:37 PM
Post deleted by fasteddy
0778drz110
Reged: 08/31/08
Loc: Florida
      #1184362 - 11/05/09 09:39 PM
you could try spring over? If you figure 4-5" from SPOA and about 2" from sag you get about 3" lift...
1988 Dodge Raider 2.6l 4cyl., 5speed, LSD rear, 31x10.50 BFG A/T, 2 100w offroad lights, "Rolled my Montero" sticker
http://www.cardomain.com/ride/3343595
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
      #1184384 - 11/05/09 10:32 PM
Ask the shop who does them. It's what I would do. Always ask the pros...
87monty
Reged: 11/06/08
Re: Rear leafs flat as a board. [Re: 0778drz110]
      #1184595 - 11/07/09 03:41 PM
Spring over? Sorry not sure what that is. I now have about 1.5 inches of down travel befor it hits the stops. Kind of annoying on the trails, and speed bumps for that matter!
I still have not called areound to see who does the work kevin was talking about been pretty busy this week.
0778drz110
Reged: 08/31/08
Loc: Florida
      #1184614 - 11/07/09 08:27 PM
leaf spring over the axle, stock springs are under the axle like a jeep YJ or samurai. Might not be a good idea since you're going turbo with 33s....
1.5" uptravel right? not downtravel? You could do an add-a-leaf with maybe a re-arch with the toyota lift shackles to get some articulation
11 registered and 8 anonymous users are browsing this forum.
Please support 4x4Wire by visiting our featured sponsors
StreetSideAuto.com Shop at CarParts.com and Start Saving
Support your hobby by becoming a member of BlueRibbon Coalition
Support your hobby by participating in TreadLightly!
| 4X4Wire Portal | About 4x4Wire | Search 4x4Wire | TrailTalk Forums | Advertiser's Guide |
This site and all original materials contained herein are Copyright 1999 - 2009 by OutdoorWire, Inc. -- All Rights Reserved.
OutdoorWire, 4x4Wire, SUVWire, JeepWire, MUIRNet-News are all trademarks and publications of OutdoorWire, Inc.
Generated in 0.018 seconds in which 0.005 seconds were spent on a total of 13 queries. Zlib compression enabled.
