4x4Wire.com's Trail Talk Forums: 4WD, 4x4, SUV, Off-Road and Outdoor Recreation Forums
OMIX-ADA Car Parts
APW LARGEST SELECTION OF AUTO PARTS
RUST BULLET AUTOMOTIVE
4x4Wire Portal | Galleries | Offtopic Chat | Garage Sale | Items Wanted | Vendors | Trailrides & Events | 4x4Wire Reader Map
4x4Wire Mitsubishi Section | Mitsubishi Reader's Rides
4x4Wire TrailTalk Mitsubishi Forums: Mitsubishi 4x4 & SUV Tech | Mitsubishi Diesels | Mitsubishi Archives
FrankR
Reged: 02/01/04
Loc: Columbia, SC
Re: buyn a broke engine [Re: Temple]
      #1184081 - 11/03/09 07:33 PM
Building a good blower engine isn't quick or easy, but it can be done with enough determination, money and a plan to follow. Given your USN engine room experience, you should be able to do it.
Watch the S/C thread..... I'm real close to building a new engine..... should be starting it within a week..... as soon as the block and rotating parts come back from the machine shop. The crankshaft is balanced - I'm now waiting for the block to be decked, align honed and bored.
Frank
'89 G-Raider Supercharged 3.0L, MegaSquirt 2, lockup A/T, 2.5" exhaust, 155k, Cibie H4s/Oscar SCs, Hella Micro DE fogs, Cobra CB, Superwinch hubs, LSD rear/Aussie Locker front, Bilsteins, 165A alt., Concorde AGM, Rust-Oleum, cobwebs
Temple
Reged: 10/09/08
Loc: Portsmouth, VA.
Re: buyn a broke engine [Re: FrankR]
      #1184090 - 11/03/09 08:37 PM
I like the words of encouragement, i'm planning on a procharger, over a blower. my question is what kind of psi can i run, and is there oversized pistons so i could do a bore? and i guess 1 more question for now, what kind of power can the automatic tranny take? ........................and FYI these little engines arnt like the blown detroit 12v71's thats i made scream!
"No obstacle brute force and ignorance cant overcome"
89 SWB 35"tires v6/auto
78 bronco 351m/c6 (you'll understand)
MOST of a 2000 3.0l v6 engine
FrankR
Reged: 02/01/04
Loc: Columbia, SC
      #1184093 - 11/03/09 09:02 PM
A ProCharger IS a blower - it just doesn't make much power under the curve...... it's more like a turbo.
It depends entirely on how you build the engine.... what pistons, what crankshaft and how you fuel it and if/how you cool the intake charge. Some 3.0L engines are running waaaay more boost than I would ever try. 6-8 psi will make a very noticeable difference.
For cast pistons, up to 1mm (.040"), but you're boost limited on those. For forged, .5mm (.020" over) can be easily found.... larger if you want a complete custom design.
Plenty.
I've made a few Detroit 6-71/8-71/12-71/6V92/8V92Ts scream also..... I kinda like driving fast fishin' boats......
Someday, I'd like to stab the throttles on a pair of these in a lightweight boat:
web page
Frank
Temple
Reged: 10/09/08
      #1184103 - 11/03/09 09:40 PM
alright heres a crazy idea, my project engine dosent have an intake manifold . and ive found lots of ford lighting s/c and pontiac 3.8l blowers could these work, but how do u control the psi and make it fit a manifold . i'm inspiring (sorry lots of questions )
FrankR
Reged: 02/01/04
Loc: Columbia, SC
      #1184117 - 11/03/09 11:50 PM
The Ford Lightning and 3.8L blowers ain't ProChargers - they're Eaton Roots blowers.
You control the psi via pulley size.
To make it fit a manifold, you build your own manifold to fit the engine and blower:
Frank
Temple
Reged: 10/09/08
      #1184138 - 11/04/09 06:32 AM
yes i know its not the procharger, but you kinda scared me away by all this power curve talk, im looking forward to ur new build! i'd like to kinda build my engine to be a toque monster. thanks for all your time.
justice
Reged: 02/06/00
Loc: So Cal, USA
      #1184156 - 11/04/09 11:36 AM
Since you said this engine is out of a "2000 Montero" and also a 3.0. You need to verify. In 2000, all monteros came with the 6G74 3.5 24V SOHC. If its a 3.0 (6G72) and of 2000 vintage then it perhaps came out of a Montero Sport.
Either way you need to factor in that both of these engines have no distributor and have a different ignition system that utilizes coil packs. I know your saying you want to run MSquirt but with out the baseline of a wiring harness and ECU from the donor it could be quite difficult to figure out.
If it were me I'd supercharge the SOHC that you have in there already and mybe find a complete donor with harness. Not saying it cant be done, but just saying..
-95 SR Auto 33's Locked F/R, 12K winch, ARB Front bumper, trimmed rear panels, sliders
-89 SWB 3.0 Auto 33's, SR locking rear end, Snork, 8K winch, custom bumpers, sliders, 2.85 T-case, CO2
-02 XLS-Stock
Temple
Reged: 10/09/08
Re: buyn a broke engine [Re: justice]
      #1184206 - 11/04/09 07:29 PM
Frank, if i can get this engine together do you think it would be worth the money ,effort, and headaches to swap it into my 89swb?
FrankR
Reged: 02/01/04
Loc: Columbia, SC
      #1184209 - 11/04/09 07:42 PM
As Justice said, you'll have to use the heads with a distributor unless you're prepared to go the MegaSquirt route - or change ECUs and wiring harnesses. I'm not sure that's worth it unless you're going to build a blower engine.
You need to decide what you want to put in the truck and build it from there.
Frank
Temple
Reged: 10/09/08
      #1184211 - 11/04/09 07:53 PM
well i got the engine for 40bucks, so if i cant use it, i am sure someone here can. i really want to supercharge my little truck. i noticed you had alot of wires in your engine bay. i really want to keep that to a min. i dont want to come off crazy or misguided, i'm just feverishly brain storming. and i'm loven all your feedback.........
thank you
10 registered and 14 anonymous users are browsing this forum.
Please support 4x4Wire by visiting our featured sponsors
StreetSideAuto.com Shop at CarParts.com and Start Saving
Support your hobby by becoming a member of BlueRibbon Coalition
Support your hobby by participating in TreadLightly!
| 4X4Wire Portal | About 4x4Wire | Search 4x4Wire | TrailTalk Forums | Advertiser's Guide |
This site and all original materials contained herein are Copyright 1999 - 2009 by OutdoorWire, Inc. -- All Rights Reserved.
OutdoorWire, 4x4Wire, SUVWire, JeepWire, MUIRNet-News are all trademarks and publications of OutdoorWire, Inc.
Generated in 0.027 seconds in which 0.006 seconds were spent on a total of 13 queries. Zlib compression enabled.
