4x4Wire.com's Trail Talk Forums: 4WD, 4x4, SUV, Off-Road and Outdoor Recreation Forums
OMIX-ADA Car Parts
APW LARGEST SELECTION OF AUTO PARTS
RUST BULLET AUTOMOTIVE
4x4Wire Portal | Galleries | Offtopic Chat | Garage Sale | Items Wanted | Vendors | Trailrides & Events | 4x4Wire Reader Map
4x4Wire Mitsubishi Section | Mitsubishi Reader's Rides
4x4Wire TrailTalk Mitsubishi Forums: Mitsubishi 4x4 & SUV Tech | Mitsubishi Diesels | Mitsubishi Archives
Pages: 1 | 2 | >> (show all)
StockRaider
Reged: 09/23/04
Loc: Williamsport PA
My Halloween Project
      #1183822 - 11/01/09 10:45 PM
I got the Diamante home Friday which was to say the least a "fun" trip .
I got it home and was sitting around with my buddy Saturday night and decided to get wrenching .
First the hood
Then the Front axles
More random crap and motor mounts and ready to hook up and out.
We had it out in about 3-4 hours engine trans together. The Diamante belongs to my friend who joined the navy. Timing belt snapped a week prior to basic and bent valves so I am going to rebuild it for him.
Richard E
1989 V6 Raider SR - Locked SR Rear, LSD Front
1989 Montero Stock - "restocked"
2001 Subaru Outback AWD Sedan - DD
1983 Honda XL600R - Busted making me sad
1985 Honda XR600 - parts
87Montero
Reged: 11/19/03
Loc: G-Vegas, SC
Re: My Halloween Project [Re: StockRaider]
      #1183824 - 11/01/09 10:47 PM
When did you get power tools? That garage is the roomiest I've seen it ever!
'92 Isuzu Pickup V6 4x4 5spd
'07 Corolla Type S
StockRaider
Reged: 09/23/04
Re: My Halloween Project [Re: 87Montero]
      #1183825 - 11/01/09 10:48 PM
I have been collecting them over time
Richard E
StockRaider
Reged: 09/23/04
      #1183828 - 11/01/09 10:52 PM
My garage before I cleaned it to work on the car
After
Richard E
StockRaider
Reged: 09/23/04
      #1184114 - 11/03/09 10:44 PM
Quick update: Engine is separated from trans and on the stand most of the way disassembled.
Heads are at shop getting done over. My friend called me today and asked if I can get the block tanked, and re-ring it, So Thats on the menu for the weekend.
Richard E
KrzyDav
Reged: 03/11/03
Loc: SLO County, CA 93453
      #1184186 - 11/04/09 05:28 PM
I'd like to see you drop that in a Montero and see if it will run with a Montero ECU plus see how the power band works with Diamante cams and 10:1 pistons. I'm pretty sure nobody on here has that engine in a Montero yet.
If you go to the trouble I won't have too .
dave h.
'89 Raider V6 5spd,Aisin Hubs,M.Sport frt. calipers,OME910 coils; Gen2: U.C.arms/T. arms/idler arm/LSD w.disc brakes;2 battery system;relocated ECU;cust.bumpers;J.Baker receiver;Conferr rack.
StockRaider
Reged: 09/23/04
Re: My Halloween Project [Re: KrzyDav]
      #1184191 - 11/04/09 05:48 PM
I thought Justice swapped Diamante heads on his 2dr Montero?
Richard E
87Montero
Reged: 11/19/03
Loc: G-Vegas, SC
      #1184192 - 11/04/09 05:50 PM
FrankR has had a diamante block in his truck running montero pistons and a Diamante cam.. but it was also supercharged.. he could give some more insight on the Diamante cam, It's my inderstanding that it's not so much greater with the Monty's gearing and torque band offroad.
'07 Corolla Type S
FrankR
Reged: 02/01/04
Loc: Columbia, SC
      #1184208 - 11/04/09 07:39 PM
I do have (HAD, actually - it's now been crushed) a SOHC Diamante block.... with custom 9.05:1 pistons that are approximately equal in CR to the Montero (8.9:1) pistons. The Diamante block is a bit stronger than the Montero block, but not at all necessary for a N/A 3.0L engine. For N/A use, the Montero block is fine - but the Diamante block might allow a little longer wear life for rings and cylinder bores due to the stiffer block skirt. If you're buying a JY block to do a rebuild, the Diamante SOHC engine block and heads are a good choice.
The Diamante heads are identical to the Montero heads except for the cams, which are quite different. The Diamante cams have 4° more duration and are retarded 7° for inlet valve closing, which makes for a lazy engine on the bottom end and pushes the torque up the rpm band considerably. The Diamante cams are not a good match for a relatively heavy offroad truck with 4.625 gearing. Once in top gear and on the highway, they're ok, but getting there isn't as elegant as with the Montero cams. If you're willing to install offset bushings, the cams can be rolled forward to the same inlet valve closing point as the Montero cams - which should restore lost dynamic CR caused by the retarded Diamante cams. That change should also move the torque back to where it's more useful for the Montero's weight and gearing.
Using the 10.0:1 Diamante flat-top pistons will add about 5HP, but won't give enough torque to cover up the loss from the cams below 2500rpm. The main thing those pistons will do is give a slightly crisper throttle response and make the engine into an interference engine.
Changing the ECU to the Diamante one won't likely help much, either.
Frank
'89 G-Raider Supercharged 3.0L, MegaSquirt 2, lockup A/T, 2.5" exhaust, 155k, Cibie H4s/Oscar SCs, Hella Micro DE fogs, Cobra CB, Superwinch hubs, LSD rear/Aussie Locker front, Bilsteins, 165A alt., Concorde AGM, Rust-Oleum, cobwebs
StockRaider
Reged: 09/23/04
Re: My Halloween Project [Re: FrankR]
      #1184212 - 11/04/09 08:02 PM
If the pistons are cracked from the impact, would Montero pistons fit making the engine non interference? Sorry, thinking out loud.
Richard E
11 registered and 17 anonymous users are browsing this forum.
Please support 4x4Wire by visiting our featured sponsors
StreetSideAuto.com Shop at CarParts.com and Start Saving
Support your hobby by becoming a member of BlueRibbon Coalition
Support your hobby by participating in TreadLightly!
| 4X4Wire Portal | About 4x4Wire | Search 4x4Wire | TrailTalk Forums | Advertiser's Guide |
This site and all original materials contained herein are Copyright 1999 - 2009 by OutdoorWire, Inc. -- All Rights Reserved.
OutdoorWire, 4x4Wire, SUVWire, JeepWire, MUIRNet-News are all trademarks and publications of OutdoorWire, Inc.
Generated in 0.016 seconds in which 0.006 seconds were spent on a total of 13 queries. Zlib compression enabled.
