Bernoulli
Reged: 05/17/06
Loc: Brisbane OZ/NW USA
On my current trip through the PNW, I pushed 20mpg at 75 on Washington gas, but the E10 in Oregon has dropped it by 10%.
I don't get it. I use the same amount of gas plus I have to burn water loving ethanol which cost more global warming to produce as well as driving up world wide commodity prices etc., etc.
-------------------- 89 3L V6 5spd SWB Raider in Bellingam, WA or Portland , OR
95 3L V6 5spd SWB Pajero GLS Redland Bay, QLD
pcc
Reged: 03/17/05
Loc: North Carolina
You always have to expect less mileage with ethanol in the gas. I easily get 20+ mpg hwy at about 70mph without ethanol gas, with ethanol you'll get at least 10% less mileage. So that cheaper price for ethanol (subsidized) gas is bogus. I calculated I could get the same dollars or better per tank for non-ethanol gas for a price up to about 10 cents more per gallon. But I have no non-ethanol choices now that the local Amoco/BP caved in and stopped selling non-ethanol gas. Thank those corn state congressmen and the ag industry. Let's see, using land for gasoline instead of food - yea that makes sense.
-------------------- 92 Montero LS 3.0L V6 Auto, Stock, Original owner, 140K miles
Kevin C
Reged: 05/20/00
Loc: Portland OR, USA
I'm pretty pro enviorment and have all the emmisons equipment intact even though I added a turbo (EGR, Cat and pulse air system), but I cant get behind ethanol gas.
I also think it affect some of the older vehilce a bit more since that carb vehicles dont compensate for fuel changes as well. I also think that the lower turbulance hemi style engines might be bit morea affected by the slower flame speed of the ethanol mix ( 2.6).
Around town its hard to get much more than 14 -15 on my Raider. On the highway 18 to 21 is typical. I have gotten 20+ mpg long highway trips, as long as the AC was off. I averaged agou 75 mph. The AC seems to drop the fuel economy by 1-2 mpg.
I also trrned the boost down from 14 or so PSI to around 11, that seems to have helped. On the turbo I think that a by pass valve would improve fuel economy, I just need to get around to setting one up.
Kevin
-------------------- 87 Raider, 2.6 Turbo-Intercooled, lockup auto tranny, 2.5" mandrel bent exhaust, 2.85 T case, LSD front diff, Torsen rear diff, V6 brakes and front axles, Dual suspension seats = lots of fun.
KrzyDav
Reged: 03/11/03
Loc: SLO County, CA 93453
Another need for campaign finanance reform,,,and a Guillontine on wall street. Multinational Corps owning Congress and perpetuating the "Ethanol Myth". What's the ratio of fuel burned to make a gallon of ethanol , like 1.0 gallons of petrolium to make a 1.5 of ethenol.
-------------------- dave h.
'89 Raider V6 5spd,Aisin Hubs,M.Sport frt. calipers,OME910 coils; Gen2: U.C.arms/T. arms/idler arm/LSD w.disc brakes;2 battery system;relocated ECU;cust.bumpers;J.Baker receiver;Conferr rack.
Edited by KrzyDav (11/01/09 04:29 PM)
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
IIRC, alcohols have roughly half the btu's per gal. as gasoline. I know that alky carbs have jets about twice the xsect. area of gas jets. We used to overdrill gas jets with a drill size about 1.4x the original jet diameter (sqrt of 2 is 1.44ish) when converting to alky on round track cars and dragsters.
Therefore, if you're burning gasahols, your power and mileage will go down. It always looked like a case of ecological correctness geting in the way of good engineering. Mistrust all radicals. They don't let either science or common sense get in the way of ideology...
-------------------- "If you turn yourself into a sheep, the wolves will eat you." B. Franklin
95 SR named Ella 120k mi
RocLimer
Reged: 04/22/08
Loc: California
I just got the best highway only mileage this last weekend, 19.92 miles per gallon on Highway 1 and Sir Francis Drake Blvd out near Tomales Bay and Bodega Bay this last weekend.
-------------------- 1989 Montero 2-Dr 3.0L V6 15X8 ProComp 97 Series w 30.5x9.5 Cooper M/T's
http://www.cardomain.com/ride/3143932
OneTime
Reged: 02/07/08
Loc: Phoenix, AZ
Roclimer. To think I used to get paid to patrol Sonoma Co. Man do I regret leaving that place. OK Hickjack off....
-------------------- 98 Gen 2.5 w/ winter package & 31x10 BFG ATs.
ejm
Reged: 12/10/03
Loc: Back in NJ for a while
I just drove cross country to LA. and i got between 16.7-18.5 mpg. That was on 265/75/16 stock roof rack. My avg speed was over 73 mph the trip. Made it from Ocean City,NJ to Santa Monica,Ca. in 57 hours.
-------------------- 98 Montero, OME lift, Girvin Systems roof rack, Custom Discovery rear ladder 285/75/16 Mickey Thompson MTZ, Cepek DC-1 16x8
KrzyDav
Reged: 03/11/03
I went ahead and took my Conferr off for the season. I mainly use it to keep the sun off my roof,,,the dog stays cooler that way. Seems I have my power back, that thing makes for alot of wind resistance.
cdl1701
Reged: 08/06/08
Loc: North Carolina
I have run my MPG 4 times now and am getting 20-22 every time on my 88 2.6. running 255/75s now but getting ready to put some 31x10.5 on this weekend... wonder what that will do to my MPG?
-------------------- 88 Dodge Raider, 4.3 is in but not finished.
88 Montero, 2.6 Black
