SKC
Reged: 07/19/08
The front differential and the transfer case is something to worry about, though. They are both the weak points in our drive train, so I've been told.
fokion
Reged: 07/09/03
Loc: Athens Greece
coming to the stroker thing again, look this http://carinfo.autold.com/car-kia_potentia-22.html
dont stay on the hp look at the diameter...
-------------------- '96 4d mechanicaly stock so far, rims, spoiler, Cooper AT tyres, Factory LSD, Manual Warn Hubs, handmade exaust, ELECTRIC FAN!!! 3,1'' Lift, PALM GPS
2002_Sporty
Reged: 12/28/08
Loc: Fairbanks Alaska
Here's what I found.
240 RWHP Stroked FE3
http://www.solomiata.com/FE3.html
-------------------- 2002 4dr Kia Sportage 4X4
fokion
Reged: 07/09/03
Loc: Athens Greece
I have read this so many times The thing with this mod is that they were aiming for turbo-ing the engine so thei had special needs conserning straingth. What I think we are looking for is a simple mild improuvment with aw many stock and easy to find parts that would give low torque reliably and not having to fix things every now and then
That is why the b2200 crank and rods only, if they fitted would give a estimated 2200-2300cc with all the rest possibly stock maybe a litle bit of fuel presure more to compensate for the sligtly biger cylinders.
Why wont I try it you may ask and its pretty reasonable. the answer is that I have a perfectly running engine and no spare money to dissasemble it just for the fun of it. If I had a reason like worn piston rings an a smoking engine in need for a re-build, I surely would give it a try, since it would be already in pieces
sportagebandit
Reged: 03/15/05
Loc: miami, fl
how much would it cost to do a full rebuild with the stroker parts? (i have a bad rod knock, perfect candidate) either that or engine swap... i think swapping ina junkyard motor would be the cheapest..
-------------------- 96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
