4x4Wire Kia Forums
Everet
Reged: 08/10/06
Loc: Silicon Valley, CA
No Power above 3000 RPM
      #1166252 - 07/11/09 01:57 PM
Here's the scoop:
1. Codes P0300,0303,0304 All misfires cylinders 1-4
2. 1.2k miles on valve job, Brand new plugs, wires and coils
3. Slowly lost mileage on trip from 25 down to 20 and slowly lost power.
Things I've done:
1. Swapped out coils with old coils and wires. NO CHANGE
2. Changed fuel filter NO CHANGE
3. Changed fuel pump NO CHANGE
4. Swapped out injectors. NO CHANGE
5. Swapped out throttle body NO CHANGE
6. Checked compression 155-160-163-152
What it acts like is that it is starved for fuel...Doesn't really have a miss.
If you are idling and go to WOT, it sometimes will rev up to about 4k rpm and then stop revving, other times it will die like a car with a bad accelerator pump in the carburetor.
Next thing to change is the fuel pressure regulator on fuel rail.
Any other thoughts???
Everet
WWW.UPYOURKIA.COM White 96,4x4, man.hubs,K&N filter,3row rad, twin 16" fans, 3" body lift, 4" UPYOURKIA LIFT KIT,265/75 16 TreadWrights on DC2 wheels,140 amp alt. dual batts. 2000 Sporty 2 door
Everet
Reged: 08/10/06
Re: No Power above 3000 RPM [Re: Everet]
      #1166258 - 07/11/09 02:54 PM
Well, swapped out pressure regulator and NO CHANGE...but...got more codes:
0326 knock sensor, 1586 AT/MT Codification, 0501 Vehicle Speed Sensor Range/Performance (odd since car wasn't driven), 0604 Internal Control Module RAM Error.
Wonder if computer is having issues.... Think I have a spare...better check ground wires...
Anyone have any other thoughts....
Everet
Axe ManModerator
Kia Moderator Emeritus
Reged: 03/02/02
Loc: Highland, NY
      #1166259 - 07/11/09 02:55 PM
The cat converter has broken apart internally and is blocking the exhaust.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
Everet
Reged: 08/10/06
Re: No Power above 3000 RPM [Re: Axe Man]
      #1166260 - 07/11/09 02:58 PM
Just talked to my neighbor....He said sounds like a bad cat!!! Great minds must think alike...
Axe...thanks for the input...guess I know what I'm doing tomorrow... (I have spares of upper and lower)
Everet
Axe ManModerator
Reged: 03/02/02
Loc: Highland, NY
      #1166262 - 07/11/09 03:02 PM
Your '96 should have just one cat, directly under the driver.
'98 and newer have two cats. One on the exhaust manifold and one under the driver.
Axe ManModerator
Reged: 03/02/02
Loc: Highland, NY
      #1166263 - 07/11/09 03:11 PM
Everet
Now it looks like you fubar'ed something. Go back and check what you did.
Everet
Reged: 08/10/06
      #1166265 - 07/11/09 03:47 PM
This one's a 2000 so I'll change both.
Last thing I did was changed the pressure regulator...no wires...
I'll reset and see if they come back...
bombardj1
Reged: 08/25/06
Loc: New Philadelphia, Ohio, USA
      #1166280 - 07/11/09 09:11 PM
hey Everet,
is it a Stick or Auto, if it's a Auto trans could it be the torque converter ? does it have a trans module ?
Did Kelly ever PM you about the clutch fan ?
Everet
Reged: 08/10/06
Re: No Power above 3000 RPM [Re: bombardj1]
      #1166384 - 07/12/09 05:19 PM
It's an auto...hope it just needs resetting. Did all these codes while parked.
Just PM'd Kelly.
Everet
DennisThompson
Reged: 03/15/02
Loc: Utah
      #1166394 - 07/12/09 06:09 PM
When my cat went out I just kept driving it intil all the peices went out the tail pipe. Actuly I didn't know I had a problem intil I was building my new exhaust and looked in the cat and it was empty. I have a MagnaFlow on it now just hanging there awaiting an engine.
Good luck, Dennis
95 Sportage, gone, will be missed.
0 registered and 3 anonymous users are browsing this forum.
Generated in 0.019 seconds in which 0.005 seconds were spent on a total of 12 queries. Zlib compression enabled.
