Toyota Forums >> T100 & Tundra Forum
Pages: 1
bradf
Reged: 06/06/09
Clutch pedal bracket SPRING question
      #1161005 - 06/06/09 06:50 PM
I too fixed my clutch pedal bracket based on the great info in this forum. However, I didn't notice ahead of time exactly how the spring connected. It seemed reasonably obvious, but doesn't seem to be working right. Things were fine for a couple of months, but now I'm having problems with the pedal not returning when I release it.
Could anyone take a pic of their clutch pedal, spring, and bracket so that I could see what it's supposed to look like?
Thanks!
Bill_R
Reged: 06/14/00
Loc: VA. USA
Re: Clutch pedal bracket SPRING question [Re: bradf]
      #1161033 - 06/06/09 11:44 PM
I think that you have the spring connected properly, otherwise it would not have worked for several months prior to giving you this problem. I had a similar issue and it turned out to be the clutch master cylinder. The seals were bad. The best thing I did was get a Toyota master cylinder and replace it. I went through 2 of an off brand and they did not hold up.
Check for a part number here: http://www.toyodiy.com/
Then check an online Toy dealer or check your local to see what kind of a price they give you.
Bill Reid
'93 T100 SR5 4X4
'05 4Runner SR5 4x4 (wife's DD)
eleet
Reged: 06/18/05
Loc: Orange, VA
Re: Clutch pedal bracket SPRING question [Re: Bill_R]
      #1161069 - 06/07/09 08:02 AM
I agree with Bill, because when you open the screw to bleed the clutch, the pedal stays on the floor.
All I have to add is that if you are feeling cheap, the dealer has rebuild kits for both the master and slave, they are shown in the toyodiy diagrams.
Greg_Canada
Reged: 08/25/03
Loc: Toronto, Canada
Re: Clutch pedal bracket SPRING question [Re: eleet]
      #1161253 - 06/08/09 01:34 PM
CLutch master $59 from marlin crawler.. OEM parts http://marlincrawler.com/clutch/hydraulics/clutch-master-cylinder
89 4Runner
Pages: 1
0 registered and 10 anonymous users are browsing this forum.
Moderator:  ErikB, Dandeman, kewlynx
Generated in 0.015 seconds in which 0.003 seconds were spent on a total of 11 queries. Zlib compression enabled.
