4x4Wire Kia Forums
Hydra747
Reged: 06/29/06
Loc: South Texas
Weak Brakes
      #1106066 - 07/09/08 06:07 PM
I had to change my resovoir 3 times in the past year due to leaks (brake symbol was coming on). I have a new one in right now. I do not have anti-lock option with this Sportage --like my other ones.
Well, to make a long story short-----My brake pedal can be pressed all the way to the floor if I push it that far. Is that Normal?
And it seams that it lacks braking power when I try to stop. I have brand new ceramic in the front and the drum area is brand new. The fluid is full in the res.
Does anyone think that there could be air in the line?
What are the signs and symptoms for this?
I asked the mechanic to bleed the fluid, and he said that it did not need it!
Or are our brakes really weak?
____________________________________________________________________________________________________
Hydra747
Reged: 06/29/06
Loc: South Texas
Re: Weak Brakes [Re: Hydra747]
      #1106067 - 07/09/08 06:16 PM
Sorry, I forgot to add that the res. is Full!
And no codes now..............
Thanks ---Mike
Edited by Hydra747 (07/09/08 06:17 PM)
4runnernomore
Reged: 07/24/07
Loc: Darwin Australia
      #1106094 - 07/09/08 07:46 PM
Sounds like your brake master cylinder has gone. Mine went when I first bought it and exhibited the same symptons. Could not bleed up the brakes no matter what.
Look at replacing that and you should be good to go.
Cheers, chris
97 Sporty, snorkel, K&N filter, power chip fitted with "98" tune, 50mm extended front forks, 40mm Dobinson Springs, KYB front struts, 35mm Jeep TJ Dobinson Springs, RAV 4 OME shocks from ARB, front Kaiser diff lock, 5.38 R&P's, 1&3/8 body lift, Tru Speed device (to correct speedo) with more to come
Hydra747
Reged: 06/29/06
Loc: South Texas
Re: Weak Brakes [Re: 4runnernomore]
      #1106104 - 07/09/08 08:29 PM
I had the Master C changed already----isn't it the reservoir?
What other parts are they?
Iron
Reged: 10/05/06
Loc: Edmonton, Alberta
      #1106107 - 07/09/08 08:34 PM
Don't he brake and clutch share the same reservoir?
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Everet
Reged: 08/10/06
Loc: Silicon Valley, CA
Re: Weak Brakes [Re: Iron]
      #1106115 - 07/09/08 09:03 PM
Same reservoir, different cylinders. Master cylinder is the cast steel thing with the attached brake lines, and is what the reservoir is attached to.
If that has been replaced, sounds like you have air in the lines. Would recommend having them bled again by professional.
Everet
WWW.UPYOURKIA.COM White 96,4x4, man.hubs,K&N filter,3row rad, twin 16" fans, 3" body lift, 4" UPYOURKIA LIFT KIT,265/75 16 TreadWrights on DC2 wheels,140 amp alt. dual batts. 2000 Sporty 2 door
Airdale73013
Reged: 08/18/03
Loc: Oklahoma City, OK
      #1106224 - 07/10/08 08:55 AM
The vacuum-booster could be bad.
2009 Sorento LX, 4x4, V6, Auto, Red
fokion
Reged: 07/09/03
Loc: Athens Greece
Re: Weak Brakes [Re: Airdale73013]
      #1106228 - 07/10/08 09:17 AM
If the culinder is ok I vote for Everet's opinion
If the bouster was bad the pedal would be very hard, like braking with the engine shut.
Airdale73013
Reged: 08/18/03
Re: Weak Brakes [Re: fokion]
      #1106249 - 07/10/08 11:15 AM
If the booster has a leak in the diaphram the pedal will go to the floor unless you pump the brake pedal.
Hydra747
Reged: 06/29/06
Loc: South Texas
      #1106284 - 07/10/08 03:43 PM
Forgive my ignorance in this matter, but if the Booster is bad does it leak any fluid????
1 registered and 8 anonymous users are browsing this forum.
Generated in 0.018 seconds in which 0.004 seconds were spent on a total of 11 queries. Zlib compression enabled.
