4x4Wire Kia Forums
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | >> (show all)
jaybur
Reged: 11/02/07
Loc: ashland oregon
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: jaybur]
      #1080126 - 02/22/08 12:24 AM
FRONT TJ SPRINGS DO NOT WORK, ONLY THE REARS. as far as I know there is no drop in spring from another car that would be the right spring rate and height for us.
Sportage sold.........
tnyankee
Reged: 02/12/08
Loc: Louisville, Tennessee
      #1082340 - 03/01/08 11:40 PM
Does anyone know the spring rate on the front springs?
Edited by DamKia (05/04/08 11:28 PM)
jaybur
Reged: 11/02/07
Loc: ashland oregon
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. *DELETED* [Re: tnyankee]
      #1082372 - 03/02/08 02:05 AM
Post deleted by DamKia
Everet
Reged: 08/10/06
Loc: Silicon Valley, CA
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. *DELETED* [Re: jaybur]
      #1082489 - 03/02/08 06:50 PM
WWW.UPYOURKIA.COM White 96,4x4, man.hubs,K&N filter,3row rad, twin 16" fans, 3" body lift, 4" UPYOURKIA LIFT KIT,265/75 16 TreadWrights on DC2 wheels,140 amp alt. dual batts. 2000 Sporty 2 door
tnyankee
Reged: 02/12/08
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. *DELETED* [Re: Everet]
      #1082533 - 03/02/08 10:04 PM
Everet
Reged: 08/10/06
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: tnyankee]
      #1082541 - 03/02/08 10:59 PM
According to my measurements, they are 12.5" long and 250 lbs/inch
Everet
DamKiaModerator
Kia Moderator
Reged: 02/10/03
Loc: Gold Coast, Queensland, Austra...
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: Everet]
      #1082605 - 03/03/08 08:17 AM
Everet
That sounds about right. When I had the springs done by Ironman here in Oz, the rate we ended up with was about 360 lb/in and 9.1 turns (need about 0.5" extra wrap on the springs when they are wound otherwise they don't sit properly in the stock hardware). This removed the wallowing and crashing from the front end and enabled the front swaybar to be removed as well without any major compromises in the handling.
Everet
Reged: 08/10/06
Re: Lifting a kia sportage? Look here first! Also tire size recommendations. [Re: DamKia]
      #1082621 - 03/03/08 09:31 AM
Rears are 10" and about 100 pounds/inch. That's why the TJ rear springs work good because they are about 2.5 inches longer and the ones I have are 150 pounds/inch, so the ride is just a little firmer and it handles the added hunting gear. I'm looking for the highest rated ones cause it looks like I'll be towing a small trailer along with the hunting gear next season.
Jaybur, what are the stiffest ones out of and their rating? (TJ rears)
Everet
jaybur
Reged: 11/02/07
Loc: ashland oregon
      #1082623 - 03/03/08 09:59 AM
don't know the spring rate, but it is a the ones with a 106 number on the tag. Most common to find are the 104 and 105 though.
Everet
Reged: 08/10/06
      #1082646 - 03/03/08 11:13 AM
Thanks,
I have the 104's
Everet
0 registered and 10 anonymous users are browsing this forum.
Rating: *****
Generated in 0.02 seconds in which 0.007 seconds were spent on a total of 11 queries. Zlib compression enabled.
