CJM
Reged: 09/22/03
Loc: Penticton BC
so pulled the sterio stuff out today , and started the "layout"
and unpacked , and set in position
and ... seriously ? wiring again !!
still have most of the GPS to do , and I didnt get my back up camera yet .. but gettin close to done with the other stuff , gonna start the sub box next week
-------------------- 86 4x4 , fiberglass bed , 1/2 doors , hood, etc..
83 Trekker SR5
NEW Trekker forum
RatLabGuy
Reged: 09/26/05
Loc: Winston-Salem NC
Why not put the amps under the seats so you don't lose the cargo space in the back?
-------------------- With 200+ Billion electrical parts, the world most complicated machine is inside your own skull.
Question Reality.
CJM
Reged: 09/22/03
Loc: Penticton BC
not enough room , + here in the summer , i'm positive they would overheat . building a box , and with the rockfords I got , it is a min size box necessary so I can put the amps , fuse block , and crssovers all on the box .. box dimentions are 40" X 12 " X 8" wide .. so all in all , I wont loose to much space
83 Trekker SR5
NEW Trekker forum
Greg_Canada
Reged: 08/25/03
Loc: Toronto, Canada
My amps overheat if i cover them up (unless i run cooling fans)... under teh seat would be OK if there is enough flow over them... but when they're in the sun they'll overheat
-------------------- 89 4Runner
CJM
Reged: 09/22/03
Loc: Penticton BC
so as I mentioned .. steering wheel is in ..
I also bought one of those cheep car covers off of ebay .. it's suposably for a 4Runner .. its basically a generic cover , but I figured with the interior and electroncis going in , and my shop being so dusty .. It might be a good idea ..
also .. got the SUB box mostly done ..
83 Trekker SR5
NEW Trekker forum
bkg
Reged: 02/15/01
Loc: Minnesota
any idea how much weight was added with the sound deading material? curious only.
-------------------- Brian K. Gallus
CJM
Reged: 09/22/03
Loc: Penticton BC
shipping weigh bill says 38 LBS ..
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
so with today being a long weekend I was able to get a little more done on the sub box .. Friday I gel coated it .. about 40mils thick .. so I could sand it down smooth .. this will "seal" the wood , so I can continue with paint..
sanded , and prepping for some "hi build " primer
shot with the hi build , and ready for some sanding
and finally .. I decided to go with the interior grey of some of the interior plastics , dash base , center console ...
should be all cured and ready for the subs , amps and crossovers tomorrow :)
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
and put together
front side
and back side
83 Trekker SR5
NEW Trekker forum
masheen
Reged: 02/19/07
Just curious Corey, but from the pix you posted, I don't see any air ports in your speaker enclosure. As far as I know, speakers gotta breathe. I built 6x9 enclosures for mine and drilled a 3/4" hole in the side of each. I have no idea what size hole is best suited for a given speaker size. With my stereo cranked up, the air that gets pushed through the hole is pretty substantial! Yours will push much more and if there's no where for the air to go, your speakers won't move like they should and the sound will suffer. Just my opinion, but I could be wrong...... I'm with many others here; great build and awesome documentation on your build! You could write a book!! LOL
-------------------- 85 4x4,22r Carb, BFG 33x12.5/15x10 Rocket Startrack rims, 2" Body Lift, Rancho Springs(3"f/2"r), stabilizer & adj tork rod, Skyjacker adj drag link ,Bilstein shox, Line-x'd where it counts, KC HiLites, grill guard, roll bar, dual quad rear bumper.
