trcdrunner
Reged: 09/28/03
Loc: Cincy, Ohio
I remember the part supra part mini truck... all monster.... Still cant wait for the trekker thou... BTW U R A MAD MAN
- Nice work
-------------------- aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
CJM
Reged: 09/22/03
Loc: Penticton BC
thanks .. me to .. I'm stoked to get the trekker finished ..
so a little bit today ... now that the cab is in the paint shop .. I needed to paint some pieces myself..
satin black
-------------------- 86 4x4 , fiberglass bed , 1/2 doors , hood, etc..
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
and the dash bezzles :)
same satin black
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
I checked in on the paint today .. and it will be " hi-build" primered tomorrow :) and then inners will be colored next week I hope ..
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
so a little bit more today ...
got the alignment done , and locked down .. steering damper is also now attached ..
replaced the spark plugs with a heat range lower and platenum tipped ($80.00 bucks) and also a lower temp 170* gates # 33867 thermo .
front drive shaft is now in the works ..
some cleaning and POR15 in the works ...
on the front part of the drvshaft .. under the u-joint , there is a plug ... I have misplaced the size /part # anyone know it ?
83 Trekker SR5
NEW Trekker forum
kewlynx
Reged: 10/06/02
Loc: Fairbanks, Alaska
Plug or a zerk fitting?
**ubi apis- ibi salus**
CJM
Reged: 09/22/03
Loc: Penticton BC
plug ..
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
got everything back together today . I checked some of the aftermarket stores today, for the dish style frost plug and had no luck , most wern't open today because it was a holiday , so I ended up taking the plug out of an old shaft I had from another truck that I parted out ... I "miked" it .. and was 34.25MM .. if anyone is ever interested..
anyway .. I install the plug , and cleaned and washed and prepped for the POR15 coating ...
Chassis is now complete .. (once I bolt on the front shaft) ... only thing left to do is the Gear oil ... everything is done :) and ready for the cab
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
ALL gear oils changed today ...
also picked up the locks .. ALL were re-key'd to match ..
i'm ready for the cab !!
83 Trekker SR5
NEW Trekker forum
Edited by CJM (05/27/10 08:56 PM)
CJM
Reged: 09/22/03
Loc: Penticton BC
worked on the rear door today while my boy was at ball practice ... no I'm not coaching this year!!
fit the new inner cover .. and also glued the rear door skin back on to the frame ..
also painted the shifters ..
cab should have been primed today .. I guess I'll see on Monday
83 Trekker SR5
NEW Trekker forum
