Pages: << 29 | 30 | 31 | 32 | 33 | 34 | 35 | 36 | 37 | 38 | 39 | 40 | 41 | 42 | 43 | 44 | 45 | 46 | 47 | 48 | 49 | >> (show all)
CJM
Reged: 09/22/03
Loc: Penticton BC
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJMT100]
      #1177271 - 09/19/09 10:54 AM
it was my temper I got mad at it .
86 4x4 , fiberglass bed , 1/2 doors , hood, etc..
83 Trekker SR5
NEW Trekker forum
CJMT100
Reged: 09/06/06
Re: sold the first one .. so this ones mine ... Trekker Build [Re: CJM]
      #1177275 - 09/19/09 12:32 PM
I see.. Scary stuff man.
CJM
Reged: 09/22/03
Loc: Penticton BC
      #1177315 - 09/19/09 08:34 PM
once in a while .. ya just gotta "vent" ..
inanimate object's are ok in my eyes !!
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
      #1180350 - 10/08/09 08:58 PM
sorry for the slow progress ...
but today I have a wee bit of an update .
started the drivers door panel , I have to re-pin the hinges , so I will be sure to post that as well .. (hopefully this weekend) but for now , this will have to do
started with removing the door and hinges
Next .. with the grinder "clipped" the edges
and off comes the skin .. there is a few spot welds , expecially for the vent window supports .. but easlily dealt with ..
New skin goes on .. and time to make it stick !!
I didnt have a mini rasp, have to go buy one .. so I called er' a day ..
83 Trekker SR5
NEW Trekker forum
kewlynxModerator
Reged: 10/06/02
Loc: Fairbanks, Alaska
      #1180405 - 10/09/09 01:10 AM
Shakes head in awe....wow.
**ubi apis- ibi salus**
CJM
Reged: 09/22/03
Loc: Penticton BC
Re: sold the first one .. so this ones mine ... Trekker Build [Re: kewlynx]
      #1180515 - 10/09/09 08:35 PM
got the flanges cleaned up today .. and got the POR15 on them
also "cleaned" up the inside , and got it POR15'd
trimmed up the holes for the handle and lock
and installed and ready to "bond"
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
      #1180630 - 10/10/09 07:23 PM
ok continueing on ... In order to "attach" the fiber skin .. you need to scuff the panel , where it will contact the metal shell , for as the say in the industry "tooth" , meaning .. something for the epoxy to stick to
fiber panel
metal shell , back to bare steel .
The epoxy I use in my shop is 3M panel bonder .. it's expencive , but if done propperly , it will never come apart , and they guarentee it !!
so now .. epoxied .. and clamped .. just has to cure ..
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
      #1180633 - 10/10/09 07:43 PM
so now the door is "curing " ...... time to address the hinges ..
lots of play , so time for some new hinge pins .
had the hinges sitting in a pot of deluted hydrofloic acid over night
so it make sandblasting a little easier and heres the works ..
had to cut the pin , and punch it out
next , I had to drill the old hinges to fit the new bushings
both sides have to be done because , the pin is a little larger . File the " burrs " and install the new bushings .. The pin also has to be trimmed , because it was to long .
I "plug" welded the bottom of the hinge , for safty .. and a little primer ... DONE
just have to wait for the epoxy to cure .. and I can mount the door :)
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
      #1180717 - 10/11/09 07:14 PM
all excited , I went in this morn. to get the door mounted .. removed all the clamps , and connected up the door handle , bolted on the hinges .. and got the door back on
Marked the position of the mirror , drilled and "nutcerted"
and put the mirror back on
Very happy with the way it turned out .. when I trim the fiberglass panels , I always trim them LARGE .. so there is enough panel to make my own panel gaps . it's always easier to remove material , then to add it . So when I do the "final" body work , I will be able to sand down the door edges , to make perfect panel gaps
83 Trekker SR5
NEW Trekker forum
matts
Reged: 01/04/02
Loc: S.E. Wisconsin
      #1180797 - 10/12/09 01:24 AM
Are you making door skins for sale? 84 - 88? Tell us more about the hinge pins too. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
1 registered and 18 anonymous users are browsing this forum.
Moderator:  4Crawler, kewlynx
Rating: *****
Generated in 0.026 seconds in which 0.015 seconds were spent on a total of 11 queries. Zlib compression enabled.
