Greg_Canada
Reged: 08/25/03
Loc: Toronto, Canada
Also, you know it isnt too difficult to build a planishing hammer? Ours we used 4x4 tubing, a long barrel air hammer, some die's and a foot actuated valve.
-------------------- 89 4Runner
CJM
Reged: 09/22/03
Loc: Penticton BC
my neighbor (landlord) has one sitting in the back 40 .. I think this year , I'm going to get a metal shop going .. building some "specific" metal pieces ...
-------------------- 86 4x4 , fiberglass bed , 1/2 doors , hood, etc..
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
couple of progress pics
engine compartment "mock up" continues ... Rad installed , starter is now wired as well as the alternator .
and more floor space ............
and also dash cluster "mock up"
83 Trekker SR5
NEW Trekker forum
RatLabGuy
Reged: 09/26/05
Loc: Winston-Salem NC
Man, all that nice touch and clean up udner the hood - I'm really surprised you didn't repaint that brake master cylinder, it really sticks out now.
-------------------- With 200+ Billion electrical parts, the world most complicated machine is inside your own skull.
Question Reality.
CJM
Reged: 09/22/03
Loc: Penticton BC
please dont forget this is all "MOCK UP" ... there is NO WAY i'm usin' that rusty ol' master ... come on now , you know me better then that !!!!
I'm just getting an idea of where things go .. drilling holes , and mounting "ecential" 5Z pieces into the 22R engne bay . MOCK UP ...
This will all be torn apart again .. even the cab will come off again for final welding , and prep . this is just an excersize .
83 Trekker SR5
NEW Trekker forum
Edited by CJM (01/08/09 08:39 PM)
trcdrunner
Reged: 09/28/03
Loc: Cincy, Ohio
Am I seeing thoughts of a 'glassed dash???? if so any other thoughts for the other componets (Air vents/Gauges/Switches)
hhhhhmmmmmmm
-------------------- aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
CJM
Reged: 09/22/03
Loc: Penticton BC
hhhhhmmmmmmm
keep em' guessin' and they will return
83 Trekker SR5
NEW Trekker forum
Edited by CJM (01/09/09 09:16 PM)
CJM
Reged: 09/22/03
Loc: Penticton BC
ok .. working away .. and 1 thing on the list to get done was the lower rad to engine connection ..
with the new turbo 3 core rad , there was only a wee connection between the engine and the rad .. so i ended up cutting about 3 " off and welding a "new" lip ..
and installed .. sorry .. not a good pic .
now a simple 90* to connect .. .
83 Trekker SR5
NEW Trekker forum
CJM
Reged: 09/22/03
Loc: Penticton BC
for those of you whom have commented about the "rusty" master.. I thought I would get to the real replacement ..
2000 4Runner duel diaphram booster with the 1" master , and clutch master .. the clutch master is close and actually touches in 1 spot .. I'm going to correct that when I pull it a part .
because of the size of the booster and the length of the studs , the original spacer is not usable . also installing the booster with the stock steering shaft the u-joint at the fire wall hits the booster .. so in order to accomplish the booster install , I pulled out a spare /84 shaft I had from my 2WD project .. the shaft has a ball socket , instead of a u-joint , making the "connection" much smaller .
swaping the whole steering column is not possable because of the mounting points [size=2]79-83[/size]
[size=2]84-88[/size]
unbolting the lower column housing and "swaping"
the floor mount for the 83 dosnt fit the 84 lower .. so I have to "open" it up a bit ..
and with everything back together .. I now have "VERY" large brakes :) and should be able to "stop on a dime"
83 Trekker SR5
NEW Trekker forum
Greg_Canada
Reged: 08/25/03
This should be the nicest trekker ever on the road when it's done. I cant wait to see it
