Mitsubishi Forums >> Mitsubishi Diesels
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | >> (show all)
lordtrunks
Reged: 05/22/01
Loc: Apache Jct, Arizona,USA
Re: Ranger - Montero Diesel Swap thread [Re: 89Diesel]
      #1052227 - 11/07/07 04:52 PM
or you could just go buy the right mounts
Grandpa's Cadillac
89Diesel
Reged: 10/20/07
Loc: Regina, Sask Canada
Re: Ranger - Montero Diesel Swap thread [Re: lordtrunks]
      #1052232 - 11/07/07 05:12 PM
I wish it was that simple. Where I'm located at, I can't even get an oil or fuel filter! No kidding, we have a pop of 250,000 and the auto parts stores have no idea what a Mitsu diesel engine is! I've only seen one other Mitsu diesel in the country.
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
PA_JERO
Reged: 11/01/04
Loc: Gilbert, AZ
      #1052791 - 11/09/07 09:35 PM
well I dont have the mounts off the diesel block but I compaired the 2.6 ones to the 2.3 block and they are the exact same.
!!!!!!!!!!!!!WHAT ABOUT BOB!!!!!!!!!!!!!!!
dylanb
Reged: 01/06/05
Loc: Atlanta, GA
Re: Ranger - Montero Diesel Swap thread [Re: PA_JERO]
      #1052935 - 11/10/07 02:04 PM
Alright then.... don't know what I was thinking the last few times I looked at the block, but yeah.... I got the motor mounts on a few minutes ago. Going to the store for some bolts and probably going to get the diesel dropped in today.
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
rockrenegade
Reged: 11/01/07
Loc: Chico, CA
Re: Ranger - Montero Diesel Swap thread [Re: pmontero]
      #1052976 - 11/10/07 05:36 PM
I didnt realize a 2.6 4x4 pan would work on the deisel. I wound up building a whole new rear sump oil pan. I just cut the pick up in half and mounted it in the bottom of the pan and ran a hose between the oil pickup and the flange.
84' twin turbo diesel PowerRam 50, Rockwells, 4 linked, 47" LTB's, dual cases
rockrenegade
Reged: 11/01/07
Loc: Chico, CA
      #1053680 - 11/14/07 04:56 AM
Have you tried locating parts through a Mitsubishi Dealership? Not many people know about mitsu diesels around this area either. I found basic stuff ( filters exc ) at a local auto zone, had to order them though. I was able to find everything else I asked for ( pistons, injectors, turbo rebuild kits ) at the dealer. They even had it all in stock. So I would try that if you havent already.
kcyule
Reged: 12/02/07
Loc: ohio
      #1058018 - 12/02/07 08:21 AM
who are the "BREAKERS" in missouri that have these ranger diesels?I NEED a crankshaft pulley in a bad way!:)
thank you
kc
dylanb
Reged: 01/06/05
Loc: Atlanta, GA
Re: Ranger - Montero Diesel Swap thread [Re: kcyule]
      #1058091 - 12/02/07 05:27 PM
try going to Car-Part.com and seeing what you can find through them.... I'm pretty sure that's how Powell found his parts way out in Mizzou
dylanb
Reged: 01/06/05
Loc: Atlanta, GA
Re: Ranger - Montero Diesel Swap thread [Re: dylanb]
      #1060664 - 12/12/07 05:18 PM
Okay, so it has been a while, but I just finished finals for the semester and I'm back to working on the truck for a couple of weeks.
Update on the PS pump: It turns out that the shaft diameter on the Ranger's PS pump is smaller than that on the Mitsubishi pump. So, I had the hole in the Ranger's v-pulley bored out to where it will fit (interference fit) onto the Mitsubishi pump shaft. Hacked up the two brackets to come up with one that will work (Mitsubishi pump is a bit larger than Ranger). Here are the results so far, with just a bit of tweaking left to do as it is just slightly skewed still.
Other than that, have to wire up glow plugs, put engine in and see how the clutch feels, and change transmission mounts because mine are ridiculously worn out.
dylanb
Reged: 01/06/05
Loc: Atlanta, GA
      #1062484 - 12/18/07 02:05 PM
She's in! Got it bolted in before work yesterday. First two things I noticed: the engine bay is now pretty crowded, and the Ford accessories are a good bit above the hood line.
Still got a good bit of plumbing and electrical work to do.... wire fuel pump, charging system, glow plugs, relocate PS reservoir as it is super close to the turbo now, and get creative with the hood. Hopefully get her started in the next week or so.
0 registered and 8 anonymous users are browsing this forum.
Moderator:  LandRaider, PHIL
Generated in 0.016 seconds in which 0.005 seconds were spent on a total of 11 queries. Zlib compression enabled.
