Mitsubishi Forums >> Mitsubishi Diesels
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | >> (show all)
samwe
Reged: 09/22/07
Re: Ranger - Montero Diesel Swap thread [Re: LandRaider]
      #1047927 - 10/22/07 02:21 PM
My tranny hung up too. I ended up taking the T-case off then I could easily install the tranny with no problems.
pmontero
Reged: 07/12/01
Loc: Peachtree City, GA USA
      #1048317 - 10/23/07 03:54 PM
I was dove hunting in South Texas along the Mexican border last weekend and just got back today. My friend is coming down next weekend and we're going to pull the engine and tranny together. We're hoping we can pry it apart without cutting into the bell housing. (that's the worst case so we can remove the clutch basket and flywheel bolts.)
Pmontero
You gonna stop by and see me on the way back to ATL?
LR,
I would have stopped by but I don't think I could convince the Delta pilot to divert and stop by...
Pmontero
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
pmontero
Reged: 07/12/01
Re: Ranger - Montero Diesel Swap thread [Re: pmontero]
      #1051072 - 11/03/07 10:28 PM
I got the engine out today. There was a needle bearing resting near the bolt holes in the crankshaft after we pulled the flywheel so it looks like the pilot bearing was frozen on the input shaft.
I have some cleanup to do on the engine and fuel system work in the Montero and on the engine before it goes in the Montero.
One step closer!
Pmontero
'87 Montero Diesel
and more...
Greasology
NotPetroleum
dylanb
Reged: 01/06/05
Loc: Atlanta, GA
      #1051203 - 11/04/07 03:16 PM
Just a quick update from my end as well.... progress is slow due to school. Got my oil pan and pickup issues settle thanks to some stock pieces from PA_JERO. It also looks like I won't have to have a new PS hose fabbed. The fitting on the mitsu hose will fit the Ranger pump as long as it reaches, so we'll find out for sure when I try to place the engine. Next order of business is figuring out motor mounts.
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
PA_JERO
Reged: 11/01/04
Loc: Gilbert, AZ
Re: Ranger - Montero Diesel Swap thread [Re: dylanb]
      #1051774 - 11/05/07 11:08 PM
I may have some extra mounts, if you are refering to the motor mount brackets that bolt to the block.
!!!!!!!!!!!!!WHAT ABOUT BOB!!!!!!!!!!!!!!!
dylanb
Reged: 01/06/05
Loc: Atlanta, GA
Re: Ranger - Montero Diesel Swap thread [Re: PA_JERO]
      #1051819 - 11/06/07 02:46 AM
I have a pair from the ranger, but they are nowhere near being the same as the 2.6 mounts like I heard they were. Can you post a picture of the mounts to see if they're different than what I have? thanks,
Dylan
89Diesel
Reged: 10/20/07
Loc: Regina, Sask Canada
      #1051939 - 11/06/07 02:36 PM
The motor mounts off a 2.6 D50 interchange with the ranger. The D50's bolt on farther back than the ranger. The extra bolt holes are hidden by the ranger mount.
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
PA_JERO
Reged: 11/01/04
Loc: Gilbert, AZ
Re: Ranger - Montero Diesel Swap thread [Re: 89Diesel]
      #1052041 - 11/06/07 10:56 PM
the mounts that I have look like the pic above. They came off of a 2.3 out of a mighty max
dylanb
Reged: 01/06/05
Loc: Atlanta, GA
      #1052061 - 11/07/07 12:26 AM
hmmm.... the bolt holes on my block don't look like they're even close to lining up with the 2.6 mounts... i'll check again/ post a pic this weekend when I go home.
89Diesel
Reged: 10/20/07
      #1052122 - 11/07/07 10:07 AM
Ya, I didn't think mine would bolt up either, but when I took the other mounts off, the top holes weren't used and hidden in behind. It still didn't look like they would work until I actually held the new mounts right up to it.
The rubber part of the mounts, I had just left in the truck, but found out you have to modify the driver side. There is a U shaped iron that goes around the outside of the rubber (pass. side doesnt have this) So either cut the rear of the U off (I did) or swap mounts side-for-side. The iron wont interfere with anything on the pass. side (I should have swapped them, but engine was in and hindsight is 20-20). This iron hits the solenoid on the starter if left in place.
Edited by 89Diesel (11/07/07 10:10 AM)
0 registered and 5 anonymous users are browsing this forum.
Moderator:  LandRaider, PHIL
Generated in 0.015 seconds in which 0.006 seconds were spent on a total of 11 queries. Zlib compression enabled.
