RUST BULLET AUTOMOTIVE
Toyota Forums >> T100 & Tundra Forum
Pages: 1 | 2 | >> (show all)
Honger
Reged: 04/28/02
Loc: Indianapolis, Indiana
Driveline Vibration - Propellor Shaft Assembly?
      #1044596 - 10/08/07 10:09 PM
Still working on my driveline vibration issue... (see my quoted original post below). Quick question:
If it is the bearing in the double cardan then I have to replace the entire rear propellor shaft don't I? As I'm looking at the FSM it sure looks like the double cardan is not serviceable. All the other u-joints seem to be serviceable by disassembly of the spider bearing. Can anyone confirm? Has anyone done any of this work?
I have vibration when I get to the 55 - 65 mph zone. When I'm on the gas it isn't as bad, but when I let off I can really feel the vibration. If I get above 65 it lessens... and when lower than 50 it hs hard to detect.
I'm leaning toward a driveline issue... and after inspecting it seems all the u-joints are snug. I can move the driveline up and down inside the center bearing about a half-inch. Is this bad enough to replace?
Has anyone here replaced their Center Bearing before and found that replacing it fixed problems? I searched the archives and couldn't find any "after replacement" testimonies.
Thanks,
Joel
1998 Toyota T100 SR5 ExtraCab 4WD
eleet
Reged: 06/18/05
Loc: Orange, VA
Re: Driveline Vibration - Propellor Shaft Assembly? [Re: Honger]
      #1044673 - 10/09/07 02:53 AM
Did you change the centre bearing?
It's possible that a driveshaft shop would be able to work on the cardan joints. If you price out the Toyota parts, they cost about as much as a down payment on a house.
97 T100 4x4
97 328i
95 540i restoration project
ErikBModerator
Toyota Moderator
Reged: 02/23/00
Loc: Auburn, NorCal
Re: Driveline Vibration - Propellor Shaft Assembly? [Re: eleet]
      #1044739 - 10/09/07 10:46 AM
Toyota considers the double cardan joint non-servicable, but driveline shops will service them and NAPA carries the joints to DIY. Its more difficult than a standard u-joint replacement though. This article shows how to disassemble it:
http://www.4x4wire.com/toyota/tech/cvmod
You should be able to tell if it needs work w/o taking it apart though!
http://home.4x4wire.com/erik
Honger
Reged: 04/28/02
Re: Driveline Vibration - Propellor Shaft Assembly? [Re: ErikB]
      #1044754 - 10/09/07 11:54 AM
Thanks for the pointers... good info.
How? What exactly am I looking for? I get under the truck (while in park but no parking brake on) and try to wiggle to no avail. The only place there is give is in the center carrier bearing.
When I back up there is a "squeak, squeak, squeak" that is proportional to speed.
tomr98t
Reged: 10/09/07
      #1044768 - 10/09/07 12:42 PM
My mechanic recently solved what I was convinced was a driveline vibration/noise on my '98 T. I was absolutely sure the vibration/noise was coming from the left rear wheel. My mechanic has a set of microphones which he attached to various places. Then he put on a set of headphones and drove the truck and operated switches to listen to each microphone. He didn't hear anything unusual in the driveline. For no logical reason, he attached the mics near the front wheels and found the vibration/noise was coming from the left front wheel. There was a ridge of rust on the very outer-most edge of both brake discs, where the brake pads don't contact them. But only the left one was causing the problem. He machined the rotors, replaced the front brake pads and the vibration/noise is gone. Something to think about before you spend big bucks replacing driveline components. Good luck.
ErikBModerator
Toyota Moderator
Reged: 02/23/00
Loc: Auburn, NorCal
      #1044810 - 10/09/07 03:04 PM
Description sounds like a bad u-joint, but its kinda hard to tell over the interweb.
Its much easier to inspect the u-joints and double cardan (aka CV) if you remove the driveshaft. Then you can work each joint back and forth and feel for play and/or resistance. Usually its pretty obvious. About the only thing you can do on the truck is make sure everything is in neutral (no tension in the driveline), and grab each side of each joint and twist back and forth and try to find play. A dry u-joint making a squeak is nearly impossible to find this way, until it wears down so badly that there is play. The needle bearings get pulverized into dust.
Honger
Reged: 04/28/02
      #1044814 - 10/09/07 03:23 PM
But if it has gotten to the point of squeaking it needs replacing right? Re greasing it might eliminate the squeak but won't get rid of the driveline vibration I'm assuming.
Joel
ErikBModerator
Toyota Moderator
Reged: 02/23/00
Loc: Auburn, NorCal
      #1044824 - 10/09/07 04:18 PM
Yes, most likely. Assuming that is the source of your squeak and/or vibe.
Honger
Reged: 04/28/02
      #1048373 - 10/23/07 08:22 PM
It was indeed a bad u-joint... the one at the rear differential flange. After removing the driveline I found that I couldn't even move that u-joint with my hands. Removed it and found rust, partially-pulverized needle bearings. GREASE YOUR FITTINGS!!!
I replaced the center carrier bearing while I was under there...
I held off on replacing the front flange u-joint (though I had the part). Partially out of impatience, partially out of (if it ain't broke, don't fix it).
Any tips on driveline greasing frequency?
kewlynxModerator
Reged: 10/06/02
Loc: Fairbanks, Alaska
      #1048380 - 10/23/07 08:46 PM
Follow the interval in your owner's manual, or more frequently if you're a mudpuppy.
**ubi apis- ibi salus**
0 registered and 4 anonymous users are browsing this forum.
Moderator:  ErikB, Dandeman, kewlynx
Generated in 0.018 seconds in which 0.005 seconds were spent on a total of 12 queries. Zlib compression enabled.
