89toyOn35s
Reged: 03/22/05
Loc: TN>Nashville
well while i was cutting the bedmounts off the frame i cut into the rubber brake hellper or what ever it is called i was wanting to plumb that stright to the brakes to from the frount is it ok to do this or do i need to replace it ? thanx i will be posting my weekend project soon what pics
toyrunner
Reged: 11/24/99
Loc: Pasadena, CA. USA
Replace the rubber line with another rubber line or a braided stainless line. Fix your speel checker while you're at it!
-------------------- 1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
89toyOn35s
Reged: 03/22/05
Loc: TN>Nashville
It is not a line that I cut it is the thing on the frame that all the lines go to before they go to the drums Might it be all right just to bypass that?
4Crawler
Reged: 01/12/00
Loc: N. California. USA
That would be the proportioning valve (LSPV). You'll need something like that to regulate the rear brake fluid pressure. Either get a used one or you can run a Wilwood prop. valve.
-------------------- r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
89toyOn35s
Reged: 03/22/05
Loc: TN>Nashville
Do I need this on the truck it is not an everyday driver?
4Crawler
Reged: 01/12/00
You need something to cut the pressure to the rear drum brakes to keep them from locking up before the disc brakes do. Drums take less pressure than discs. Front Range makes a replacement valve:
- http://frontrangeoffroadfab.com/nfoscomm/catalog/product_info.php?cPath=27&products_id=57&osCsid=2b4998ac05b932eb8cb53680c1e258ee
Or convert the rear to discs and it may be OK w/o a prop. valve (probably good to have one though).
Project: 4Crawler
