sparkem
Reged: 12/12/00
Loc: Ponchatoula, LA
3.5 axle=31 spline, 33.5mm diameter, diff = 9.5" diameter
Where is that from? I thought I remember Mrbishi posting they were 9 1/4.
-------------------- I just want to tell you both good luck, and we're all counting on you.
justice
Reged: 02/06/00
Loc: Coastal N Carolina, USA
Sparkem, specs are from the outerlimits board.
Hazy yes I'm speaking about changing both diff ratios. Not sure if 4.90 is avail for the front but there's a 4.88 and that would get you close enough. I dont plan to run 35's so im sticking with the 4.63.
Mad_Scientist
Reged: 04/25/06
4.90 would be good for the later Gen II's like mine since they only have 4.272 (I think they switched to this ratio with the SOHC 3.5L, right?)
-------------------- '97 Montero 'LSR' - 4.6 gears & factory rear locker, 33" Procomp muds on 15x8 steelies, 50mm coil spacers, T-bar crank, Airlift, sans rear sway, 50mm rear frame & fuel tank lift, Aisins, ARB front bumper + 10k lb winch, 50mm DIY body lift, rock sliders, cut rear quarter panels...
justice
Reged: 02/06/00
Yes sir, you are correct
justice
Reged: 02/06/00
Locker switch installed...I wanted a switch with a cover to protect against accidental engagement..looked all over and could not find one, then I found this "carbon fiber" switch in the ricer lights section of pepboys
the locker pump went into the cubbyhole in the cargo area there's a nice rubber plug that I used to route the air line through to the underside..I used the bracket that came out of the SR and cut it a little bit and bent it to fit the contour(sp?) of the wheel well..
The locker engages quickly and the pump turns itself off when it reaches pressure and also purges when you turn it off, thus disengaging the locker. I havent decided weather or not to wire up the sensor to turn on an indicator light I dont really want to drill another hole in the dash. Maybe later.
Edited by justice (07/08/07 11:07 PM)
Nice! You know I'm jealous...
Lucy's one lucky lady!
-------------------- 73
4xmonty
Reged: 08/13/04
Loc: Vallejo Ca
I say install an indicator lite to make the job complete
Great job
Russ
-------------------- GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
motero
Reged: 01/21/04
Loc: Wittmann, AZ
My 1/2 cent, I have done this swap, 95sr into 89 3.0 manual. The u jionts were not the same and like 52degrees I had a shaft welded up. It is a huge upgrade, lockers, disc brakes, trailing arms, (I have broken 3 sets of gen 1 trailing arms)
-------------------- 99 Montero....15mpg!
02 Jetta TDI....48mpg!
52degrees
Reged: 10/19/04
Loc: In the beer cooler
I buy my covered switches at Radio Shack. I swear they really are still good for something (RadioShack, that is).
They cost under $5.00 each there and they are lit when on.
KG6VNX
StockRaider
Reged: 09/23/04
Loc: Williamsport PA
I am having trouble locating a shop willing to make me a driveshaft... I am stuck till then. My next day off with be finishing up the swap and I will be able to move it around in Fwd At least I have front LSD
-------------------- Richard E
Edited by StockRaider (07/09/07 12:20 AM)
