superduperbacon
Reged: 02/04/07
Ok, so after some thinking and a close look at my abilties and needs. Ive decided to hold off on the SAS until my ability with welding and torching catch up. but till then i would like to put an IFS lift on my 89 yota pickup. the problem is that i spent all my time researching SAS parts. i was wondering if any of you guys knew of a good IFS suspension lift kit i could go with. im working with about $1000 - $2000, and plan on doing all the labor myself.
Scerb
Reged: 02/21/04
Loc: boonies of NH
If you have that budget then do a SAS. You can even pay someone to do the welding with $2k. The 4" IFS lifts are just not that rugged. They produce too much leverage on the factory brackets. I only have one becuase I got it for $300 used, and would not pay more than that for a brand new one.
I have completely destroyed my ifs, and yes I beat on it when I need to, but its by no means recklessly. There /IS NOT/ an unbent bracket in my front end (excluding steering). I have broken and repaired all three diff drop brackets at least twice. The ifs subframe is bent backwards (again, the drop brackets provide to much leverage and the factory frame bends). My front diff is slanted about 2" to the passenger side and the CV axle is no longer long enough. All of this happened through normal trail riding, mudding and rock crawling in nh (nothing compaired to out west). Took about a year before everything added up and is not un repairable. Basically I have a 2wd truck right now... which is why I have a solid axle in my basement ready to be welded in.
Long story short, the IFS lift wont last long... do the SAS
-Scerb
-------------------- '86 Toy PU, 22R, 268* EB cam, 3" SAS, 63" Chebbies, Duals, Longs, Locked F/R, rear discs, 36" TSL's --
'94 Toy PU Xcab, 22RE, 33's, 4.56's, Daily Driver --
22R Carb FAQ!
RatLabGuy
Reged: 09/26/05
Loc: Winston-Salem NC
How many inches do you want, and for what size tires?
-------------------- With 200+ Billion electrical parts, the world most complicated machine is inside your own skull.
Question Reality.
bkg
Reged: 02/15/01
Loc: Minnesota
My 4Runner was professionally SAS'd. I have the receipt. $1200 total bill including installation of a crawler case. If you have $2000 for lift alone, you should definitely go SAS now. It's only going to cost you ~$200 to have the hanger welded on and the shackle holes drilled/tubes welded. The rest can be done at home.
-------------------- Brian K. Gallus
willzrunna96
Reged: 10/04/04
Loc: Long Island, NY
if you can install the sas yourslelf just bring all the brackets to be welded to a shop have them weld the front truss and holes in the frame...then drive the truck home and cut the ifs stuff out....you dont need a torch but it will be easier
-------------------- 91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD!
96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter
07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
4Crawler
Reged: 01/12/00
Loc: N. California. USA
Not sure what size tires you are looking to fit, but there are some low cost "recipes" for fitting 33s on an IFS truck on the web page below: http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10
-------------------- r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
eightyeight
Reged: 08/03/04
Loc: Hancock, NH
haha jared. i seem to rememer a certain blue pickup about 5' off the ground at on paticular time. beat on it? noooooo.
but yeah, what they said. if you are gonna actually wheel it, do the sas and save your money from doing it twice.
-------------------- -matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
superduperbacon
Reged: 02/04/07
ok for tire size, i think that i have 30's on there right now with a 2 or 3 inch body lift, there may be more on it(leaf spring Hangers?) but i doubt it. i am aiming to eventually be at 35" tires and would like to be rid of the body lift. a 4 or 5 inch lift would be nice. this is my daily driver, witch was one of the reasons for staying with the IFS. But if there isn't anything of quality out there then i probably will go with the SAS.
subliminaltrips
Reged: 08/25/06
Loc: ocala,fl
i agree that an sas is in order but if you want a good price, rough country seems to have the best prices.... i dont know about quality... im about to install one on a buddys truck so ill let you know after i tear his front end apart again after he tears it apart.
-------------------- www.fattshack.com
www.blueyfab.com
elripster
Reged: 03/15/01
Loc: San Diego, CA, USA
If you are not ready to dent sheetmetal, don't worry about the SAS. You won't be on trails where you need it. You can fit 33's inexpensively and reliably. Take a look at 4crawler.com and also Sonoran steel to see what I mean.
The IFS can be very very strong for a small amount of dough
Frank
-------------------- 1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
