4x4Wire.com's Trail Talk Forums: 4WD, 4x4, SUV, Off-Road and Outdoor Recreation Forums
Rugged Ridge
APW LARGEST SELECTION OF AUTO PARTS
RUST BULLET AUTOMOTIVE
4x4Wire Portal | Toyota Tech | Galleries | Offtopic Chat | Garage Sale | Items Wanted | Vendors | Trailrides & Events | 4x4Wire on FaceBook
4x4Wire Toyota Section | Toyota FAQ | Toyota Reader's Rides
Toyota Forums: Early Toyota Trucks | 4Runner, FJ Crusier & SUV | T100 & Tundra | Tacoma | Toyota Archives
Toyota Forums >> Toyota Tech Archive
Pages: 1
kewlynx
Reged: 10/06/02
Loc: Fairbanks, Alaska
Toyota Steering Relay Rod Recall
      #828456 - 12/30/05 09:58 PM
Thread locked for reference only. If you have any questions, please either contact your local dealer, or post in the applicable Toyota section, as this section is not viewed regularly. Thank you.
Here is the literature from www.nhtsa.gov
Manufacturer : TOYOTA MOTOR NORTH AMERICA, INC.
NHTSA CAMPAIGN ID Number : 05V389000 Mfg's Report Date : SEP 06, 2005
Component: STEERING:LINKAGES:ROD:RELAY:CONNECTING
Potential Number Of Units Affected : 977839
Summary:
ON CERTAIN PICKUP TRUCKS AND SPORT UTILITY VEHICLES, IF THE STEERING WHEEL IS REPEATEDLY TURNED UNDER CERTAIN CONDITIONS WHERE HIGH STEERING EFFORT AND POWER ASSIST ARE REQUIRED, FOR INSTANCE, WHEN FULLY TURNING THE WHEEL WHILE THE VEHICLE IS STOPPED, A FATIGUE CRACK MAY DEVELOP IN THE STEERING RELAY ROD.
Consequence:
IF THE VEHICLE IS CONTINUED TO BE OPERATED IN THIS CONDITION, THE RELAY ROD MAY FRACTURE, INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL REPLACE THE STEERING RELAY ROD. THE RECALL IS EXPECTED TO BEGIN DURING LATE SEPTEMBER 2005. OWNERS SHOULD CONTACT TOYOTA AT 1-800-331-4331.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
AFFECTED VEHICLES
Make / Models : Model/Build Years:
TOYOTA / 4 RUNNER 1989-1995
TOYOTA / PICKUP 1989-1995
TOYOTA / T100 1993-1998
Other notes:
**Tacos do not fall under this recall, as they have rack and pinion steering.
**SAS’d Yotas do not fall under this recall (common sense disclaimer).
**The dealer is to do a front end alignment after replacing the rod, as the pitman arm is torn down for this work.
**If you do not receive a letter from Toyota, call the number above; have your VIN handy, as they will need it. Those of you who do NOT have a dealership do your work will need to take this action, as recall notices are sent out on based on their dealerships’ databases, and NOT your vehicle registration. YOU are the one responsible for making an appointment with your dealership to make this repair, once it’s established that your vehicle is eligible for the recall.
**An excerpt from a reader’s letter from Toyota:
“Toyota will launch a SSC in mid-September 2005 to replace the Steering Relay Rod on certain 1989 – 1995 Model Year Truck 4WD, 1990 – 1995 Model Year 4Runner 2WD and 4WD, and 1993 – 1998 Model Year T100 4WD vehicles. On the involved vehicles, if the steering wheel is repeatedly turned under certain conditions where high steering effort and power assist are required, for instance, when fully turning the wheel while the vehicle is stopped, a fatigue crack may develop in the steering relay rod due to insufficient strength. In the worst case, the steering relay rod may fracture, causing a loss of vehicle steering control and thus increasing the possibility of a crash.
The SSC will be performed at NO CHARGE to vehicle owners. The anticipated repair time is approximately two hours. However, an additional 1 1/2 hours may be necessary for front end alignment. The dealership may require your vehicle for a longer period of time based on their workload.”
For the front end breakdown, view this link:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/steering/16steer0.pdf
Seen on old Dodge-'I'll keep my money, my freedom, and my guns; you can keep the change!'
Pages: 1
Moderator:  Dandeman, 4Crawler
Please support 4x4Wire by visiting our featured sponsors
Tire Package
Deal of the Week at JC Whitney Shop at CarParts.com and Start Saving
Support your hobby by becoming a member of BlueRibbon Coalition
Support your hobby by participating in TreadLightly!
| 4X4Wire Portal | About 4x4Wire | Search 4x4Wire | TrailTalk Forums | Advertiser's Guide |
This site and all original materials contained herein are Copyright 1999 - 2009 by OutdoorWire, Inc. -- All Rights Reserved.
OutdoorWire, 4x4Wire, SUVWire, JeepWire, MUIRNet-News are all trademarks and publications of OutdoorWire, Inc.
Generated in 0.02 seconds in which 0.009 seconds were spent on a total of 11 queries. Zlib compression enabled.
