4x4Wire.com's Trail Talk Forums: 4WD, 4x4, SUV, Off-Road and Outdoor Recreation Forums
Rugged Ridge
APW LARGEST SELECTION OF AUTO PARTS
RUST BULLET AUTOMOTIVE
4x4Wire Portal | Galleries | Offtopic Chat | Garage Sale | Items Wanted | Vendors | Trailrides & Events | 4x4Wire on FaceBook
4x4Wire Isuzu Section | Isuzu Reader's Rides
4x4Wire TrailTalk Isuzu Forums: Isuzu 4x4 & SUV Talk | Isuzu 4x4 & SUV Tech | Isuzu Diesel | Isuzu Archives
Pages: 1 | 2 | (show all)
scooter36863
Reged: 03/17/05
Loc: NC Mtns...
Re: SAS for late model Trooper?? [Re: Landmonster]
      #698987 - 03/19/05 10:50 PM
well these arent of the suspension, but no way could i ever do this with the ifs, for some persepective that step up came up to my chin and i'm 6 feet tall.........
supposed to go up to the rock garden toorrow so hopefully ill be able to get some good pics on the rocks
Scott
'95 trooper, custom long arm coil sprung SAS on 37's, welded front, LSD rear, 4.56 gears, tera lows in the garage ....
http://www.cardomain.com/id/scooter36863
scooter36863
Reged: 03/17/05
Loc: NC Mtns...
Re: SAS for late model Trooper?? [Re: scooter36863]
      #698990 - 03/19/05 10:54 PM
..... and Charles is right, dont plan on usin that ARB again b/c it aint gonna fit. i would say that 4.56's are gonna be your best bet for gears if you still wanna keep it good on the road too...... make sure to get some good pics and keep us posted when you start......
Scott
paulevans76
Reged: 07/16/01
Loc: Greenville, NC
      #699045 - 03/20/05 01:20 AM
I wouldn't use a toyota minitruck axle on a late model trooper, its just too narrow (55.5") even on 1st gens you have to use spacers to match the rear. an FJ60 axle is wider (60" IIRC)and would work better, but they are much harder to find and probably more expensive (depending). Waggies are about 60" IIRC, but I'd use a fullsize chevy axle and cut the long side down to use a waggy long side axle. That would put you around 63-64" which is a good match for your rear.
just $.02 of food for thought.
88 Troop - Posing yard art
Re: SAS for late model Trooper?? [Re: ducktrooper]
      #699110 - 03/20/05 09:45 AM
..Mark, what are advatages of coil springs vs. leaf springs, ie, 440444?...My goal for this rig is to make it a stout weekend trail rig while still using it primarily for DD for next 2-3 years.
John: IMO, the leaf spring setusp are easier to engineer and install, but I think the coil setups provide a better ride and can offer better articulation. Some of the local guys that have done coil SAS on 4runners and explorers have turned out with some very drivable rigs.
ducktrooper
Reged: 03/28/01
Loc: Memphis, TN
Re: SAS for late model Trooper?? [Re: ]
      #699143 - 03/20/05 11:41 AM
Thanks guys...this is really helping. Any ideas on best way to do internet searches for axles, FJ60,FJ80,Waggy D44, and others? I guess I first need to know what year and model vehicles these axles come off of. Mark, I kind of like your idea of coilover suspension, but I read somewhere it might cost a lot more than leaf. What do you think?
'99 Trooper, ARBs, 4.77s, ARB bullbar, Warn M8000 w/Amsteel, OME 912s w/2.5" spacers, Rancho 9000xs, K&N/Magnaflow, 33" Kumho MT's, Aisins, boulder bars, Indy 4X brake lines, diff drop, Flexalite
Landmonster
Reged: 11/08/03
Loc: State, Country
      #699182 - 03/20/05 01:33 PM
Car-Part.com is a decent site to start you off on your search. Also try searching around other off-roading websites in their for sale sections, as well as this one. Post in various "Wanted" sections, check your classifieds, junkyards, and maybe even Craigslist and eBay.
http://www.car-part.com/
http://www.craigslist.org/
I'm not Mark, but leaf spring setups are usually cheaper than linked type suspensions. There are just fewer components that go into a leaf-sprung setup, and generally less work. But of course, there are always exceptions. It's all relative to coming across good deals, searching and researching your butt off, and/or how much of the stuff you can avoid buying.
Good luck with your search.
ducktrooper
Reged: 03/28/01
Loc: Memphis, TN
      #701337 - 03/23/05 10:28 PM
what about clearance on a Waggie 44 versus a yota axle if I'm running 33's? I think coilovers will be too much $$. Are coil springs front and rear an economical and practical option to leaf springs?
randii
Reged: 08/02/99
Loc: Fair Oaks, CA USA
      #701403 - 03/24/05 12:23 AM
All other things the same (width, suspension, etc.) the axle you choose won't make much difference for clearance...
1.) Steering clearance can be adjusted by height of steering arm vs. drop in Pitman arm.
2.) Spring clearance of turned tires is more function of axle width and where you put the leaf springs (inboard/middle/outboard).
3.) Tire/body clearance depends mostly on how much lift you have and how much body cutting you're willing to do.
4.) Tire size and width combines with rim offset to affect 3.) and 4.) above.
Coilovers are pricey just for the shocks and springs, but you also need to factor in the cost of links and brackets. If cost is a concern, you're looking at leaf springs, in most cases, or perhaps a radius-arm setup as done on Early Broncos or similar to what Dan Houlton has under his red Amigo.
Randii
Please support 4x4Wire by visiting our featured sponsors
Tire Package
Deal of the Week at JC Whitney Shop at CarParts.com and Start Saving
Support your hobby by becoming a member of BlueRibbon Coalition
Support your hobby by participating in TreadLightly!
| 4X4Wire Portal | About 4x4Wire | Search 4x4Wire | TrailTalk Forums | Advertiser's Guide |
This site and all original materials contained herein are Copyright 1999 - 2009 by OutdoorWire, Inc. -- All Rights Reserved.
OutdoorWire, 4x4Wire, SUVWire, JeepWire, MUIRNet-News are all trademarks and publications of OutdoorWire, Inc.
Generated in 0.026 seconds in which 0.007 seconds were spent on a total of 13 queries. Zlib compression enabled.
