willwinchforfood
Reged: 09/15/08
Loc: Tucker, Ga
I hope you plan on painting that AC comp.
-------------------- 91 LS SR Rear Dons Bumper 10k Gorilla/Promark winch Safari Snorkel 31" BFG All Terrains SR locker and front brakes rear facing toddler seat, monkey doll hanging in the window
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
John and I and wife and g'daughter Aubrey went over to Nate's yesterday after taking Aubrey swimming (some duck in that child) and it looks nicer in person than in the pics. You can not imagine how many hours are in this thing so far, unless you have jumped off into the unknown on a complex project yourself. The work is very, very nice.
SRTNate
Reged: 05/09/08
Loc: Tucker GA
...and it looks nicer in person than in the pics. You can not imagine how many hours are in this thing so far, unless you have jumped off into the unknown on a complex project yourself. The work is very, very nice.
Thanks a ton Ed, I was glad you could stop by to see it and throw around some ideas.
Meanwhile, I have a slight oversight to document...
I was not aware that the Gen 2 3.5L flywheel had 3 more teeth on it. This puts the starter in an incorrect location to bolt into the Gen 1 transmission.
And, whatever these things are called...they needed to be modified too.
 I apparently forgot to take an "after cutting" pic, but you get the idea...
This all took place about a week ago, so the engine is primed, sparkplugs are in, and all the final little bits are on the engine. I still need to finalize the fuel lines, but they're probably 9/10ths of the way done. One other main sub-project that needs to be completed is to adapt the Gen 2 Mass Airflow Sensor to the Gen 1 air box...but I have somewhat of a plan for this.
-------------------- 1989 Mitsubishi Montero SWB 0.0L (3.5L soon?) Auto, Front LSD, Rear SR Locker, Aisin hubs, Safari Snorkel, ARB Front Bumper, Warn M8000, Bushwacker Flares
1984 Mitsubishi Montero
2005 Dodge SRT-4
1970 Plymouth 'Cuda (in pieces)
...and a few others less interesting.
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
they are called by a very esoteric term. "engine plate"...
FrankR
Reged: 02/01/04
Loc: Columbia, SC
I've always called them scatter shields.
Frank
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
What I called scatter shields were the steel cans around the bellhousing to catch the hypervelocity bits of an exploding clutch. I understand the current teck is a kevlar wrap around secured with straps, which would be a shitepile easier.
LandRaider
Reged: 09/04/01
Loc: Ocean Springs, MS
87 Raider 4D56td v5MT1
Almost all stock.
fasteddy
Reged: 01/30/01
Loc: Flat Creek, GA
Watched a guy almost bleed to death and have his '55 2dr post chebbie get cut almost in half by a clutch exploding behind a 301 at near 9000rpms
SRTNate
Reged: 05/09/08
Loc: Tucker GA
...and then there was MAF.
Lots of pics, but I figured it might be helpful to see the progression.
The existing hose is just there for...well, really no reason at all. I'm still trying to decide how exactly I'm going to plumb the intake. Everything is weird diameters and circumferences...
2005 Dodge SRT-4
LandRaider
Reged: 09/04/01
That one came out of my chevelle. I was lucky. Broke the bellhousing in alot of different parts. It came through the floor in 1 spot, but no blood was released.
Nate, that motor install looks amazingly clean. the 3.5 aint my thing, but that looks great.
Almost all stock.
