RUST BULLET AUTOMOTIVE
4x4Wire TrailTalk Jeep Forums
Jeep Forums >> Jeep Tech
Pages: 1
hlhneast
Reged: 02/22/04
Loc: LA.......Lower Alabama!
1979 CJ Wiring Diagram
      #1040722 - 09/24/07 04:16 PM
Anybody have a 1979 wiring schematic?? I am trying to adapt a 1979 6 cylinder wiring harness to a V8 motor. Other than the obvious Delco vs Motorcraft alternator differences, there are subtle differences in the colors of the wires from 77 to 79. The coil jumper is a combined deal with a red w/black trace (+)and a light blue wire (-) which disappears back to the fuseblock. According to my 77 diagram, there should be a green lead from this terminal(-) to the igintion box. Its easy enough to run a jumper between those 2 points but where does the light blue wire go? I still need a wire to the solenoid from the switch too so I need some help with that one. Can someone scan their diagram and send it to me? A 1980 or 81 might work too
77 fiberglass CJ-7 304, Ground up Resto-mod Edelbrock Air Gap, Holley 1850, Headers and Flowmasters, Black Diamond suspension, BFG 33X9.50 on Outlaw I's. Hopefully on the road this year!
Edited by hlhneast (09/24/07 05:00 PM)
Brown81CJ5
Reged: 10/15/06
Loc: Arlington, Texas
Re: 1979 CJ Wiring Diagram [Re: hlhneast]
      #1040870 - 09/25/07 12:25 AM
I have a Haynes with wiring schematics...I will try and post some pics of it tomorrow evening after work.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
What this country needs is unemployed politicians.
hlhneast
Reged: 02/22/04
      #1041941 - 09/29/07 08:59 AM
Bump. Come on guys, somebody out there has a 79 FSM and a scanner. Help me out.
BigJim
Reged: 10/07/03
Loc: Central Texas
      #1041951 - 09/29/07 10:17 AM
I would wing it from where you are.. Jus t make it work with jumper wires..
Big JIm
Brown81CJ5
Reged: 10/15/06
Re: 1979 CJ Wiring Diagram [Re: BigJim]
      #1041982 - 09/29/07 12:06 PM
I'm working on it. My scanner isn't working, and I left my digi camera at a friend's house, but I will have it up by the end of this weekend.
Gun it and run it!
hlhneast
Reged: 02/22/04
Re: 1979 CJ Wiring Diagram [Re: Brown81CJ5]
      #1042159 - 09/30/07 02:05 PM
Thanks, Jim, Brown. I found some diagrams at Autozone.com in thier repair manual section. They helped and I think I have it done up right. The thing that threw me was two of the wires were connected with a rubber piece that made em fit at the solenoid or the coil. According to the diagram, the blue lead from the ignition switch was supposed to go to the solenoid and the red/black trace was supposed to go to the (+)coil then a seperate green lead went to the coil from the ign. module. I changed out the distributor with the one that has both connections that go to the module. All I have to do is crimp some bullet connectors to new wires and I think I am done. We shall see when I get done rebuilding my tilt column and turn the key, lol. Thanks again guys for your input.
Brown81CJ5
Reged: 10/15/06
      #1042362 - 10/01/07 11:14 AM
Cool. Let us know if she starts up!
Or if you will need the diagrams.
Gun it and run it!
Pages: 1
0 registered and 4 anonymous users are browsing this forum.
Moderator:  KF6ZPL
Generated in 0.013 seconds in which 0.004 seconds were spent on a total of 12 queries. Zlib compression enabled.
