Hello all. As some of you may or may not know me, my name is Jason. I've been on here a VERY long time (since the 90's) and have had quite a few Montes. My wonderful SR nicknamed "Lucky"...(don't mind Carlos's SR on roid's on the right) My old V6 SWB nicknamed "Bronzy".. I miss him so (and I was a dumbass for selling it)![]() My 87 2.6 Auto which my dad now has, nicknamed "bluecar" ![]() and finally my pride and joy!! 1986, tough as nails(except for the piece of crap transmission) SWB, turbo, performance built 2.6 Montero! Nicknamed "REDCAR" !!! ![]() ![]() And REDCAR is not your avg "stocker" SWB 2.6 Monte either ... unless stock means,V6 brakes and SR rear end, 160amp GM Bus alt with 4ga wiring all the way around and 3 deep cyl batteries, and more stuff then I can't even remember right now... UGH.. Anyways, as some of you know, I'm running so much power out of my turbo setup that I keep blowing out my 5sp every 2-3 years and I'm getting tired of pulling this $hit out. I keep blowing out the OD or 5th gear. This time, the tranny has grenaded on me!!! And I've decided to pull a Kevin and do a 372-L Auto-lockup trans conversion..This is MY STORY on my road to hell and back!!! It all starts with me getting everything I need for $650. And that means ANYTHING and EVERYTHING! ![]() ![]() REDCAR looking all sexy waiting for surgery!! I'm so used to pulling out the crappy 5sp that this time it took me a record 1hr and 13min to do it BY MYSELF!!! WOOPEE!!! ![]() In the garage and comparing the 2 units side by side. Dreaming of better days ahead of "auto bliss". Boy was I in for a surprise!! Stupid me!! ![]() In case you ask about the image above, that is a fresh, rebuilt and blueprinted TQ for the tranny. So now, planning the install. A auto-trans has to keep cool right? And I know about keeping a turbo vehicle cool so I yanked the huge cooler off a full size gen4 big body and ordered a 18" Cyclone 3500cfm elec fan because I plan on getting rid of the mech fan. I don't have a problem now but with the TQ adding heat and seeing the guys at Death Valley, I started to think about the issues.... So this is where I'm putting it.... The cooler itself of a big-body... And some custom built brackets that I made to mount it up front. It's also right in front or near the airflow of the AC-cond fan so that'll help as I'll wire that up if things get too hot while crawling... And finally all mounted in and ready to cool!!! SO NOW WE COME TO THE FUN STUFF!!! TRANSMISSION CRAP !!! Well I gotta pull out the clutch and flywheel so out you go! And on goes one of the rarest parts that you'll ever see! A 2.6 flexplate! And I've got one! lol Funny thing is, the guy was going to junk it and throw it away! ![]() Trying to find that thing above is like winning to lottery almost. This one came all the way from N.Carolina after 2 other yards burned me when they said they had it. Since the V6 transfer cases are different, I got the driveshafts also. Actually, the front spines are the same but the lengths are longer. Just the backs are bigger. So after putting the 4cyl bellhousing on it, and getting it on, mounted up there, shift linkages all hooked up, it's starting to look like a legit Automatic setup!!! For now, I'm wiped out. Tomorrow morn, I'll finish typing the adventure and posting pics, but believe me, you guys WILL NOT BELIEVE what has happened!!! ![]() Have a wonderful evening!! Jason |
Can't wait Jason!! |
Nice progress man! And do I spy jumpseats in the rear as well as a 84 era center console?
Quote:Hey Buddy! Well I don't know where the 84 console came into play but if there is one, that's from the 86 or REDCAR and pretty much all the early 1st gen 5sp units I've seen have the same console. As part of the package, I have an 87 Auto- center console that everything will fit into. Also those jumpseats you see are correct in the SR. For some strange reason, my friends or wife's family loves to pile (literally) into Lucky so having 7+ seating is nice. ![]() ANYWAYS, BACK TO THE ADVENTURE !!! So the trans is in, got everything hooked up but of course the V6 rear driveshaft will not fit because of the length so for now REDCAR is a FWD only 4x4 but good enough for testing purposes and driving around.![]() Well, I got prepared before hand and bought 4 gal of standard PepBoys Dex-3 trans fluid. remember that this was a tranny sitting in a yard, and that I dropped the pan, put a new filter kit on it, new TQ, etc so I'm gonna be using alot of fluid. I actually filled the TQ up before I put it on, but it still took almost 3 gal to bring up the dipstick. Time to START THE ENGINE!!! ![]() Crank it over and REDCAR starts right up, no issues, no weird noises... LOOKING good so far! Well, why not put it in REVERSE? -- nothing. Engine off, check the dipstick and it's dry so I add more and then start it... put it in REVERSE. and NOW WE'RE GETTING SOMEWHERE!!!The TQ is starting to slip and grab, slip and grab, etc,etc.. Let the motor run to warm up, and add more fluid and now the tranny engages in all gears. Pull out of the driveway (nervous), and put it in DRIVE - NOTHING.. ohhh crap!! rev it abit and then it engages yanks REDCAR forward!! ![]() Off we go up the street!! 1st gear, 2nd gear.. seem cool.. Then pull onto the major street, give it some GAS!! GET SOME BOOST and spin the front tires!! ![]() get up to 30mph or so real quick and as soon as i hit 3rd gear or D the WHOLE ENTIRE TRANNY STARTS TO SHAKE AND VIBRATE!!! not to mention howl kinda. I'm like WTF is going on here?? slow down and downshift.. 1st is fine... plenty of power and can light up the front tires.. 2nd gear pulls nice and hard.. 3rd GEAR is TOAST.. Feels like it's going to rip off the rubber mount off the crossmember!!! HOLLY$HIT!!! So go back home, check the fluid, etc.. all look fine. The only thing I can think of is a bad thrust bearing or something for that gear??? Who knows.. Maybe the person drove with the OD off and no to little or bad fluid on that unit. ANYWAYS.. so tired, depressed and thinking what to do next, I call my buddies at the mitsu yard and they say.. Quote: Yeah.. "No problem Bro".. I gotta take this crap out again... usually by myself since I'm at home and no one is around during the day and I want to get this done. ![]() So, again as in record time almost (3hrs), I disconnect and pull out this Auto trans on my own, by myself!!! But I can't lift it into the back of Lucky on my own so I have to wait for my buddy to come over who lives near by. The next day, go down in the morn, and swap out trans units. The "NEW" unit looks pretty fresh, clean and 'according' to records, only had 138k on it. We lifted back in and I'm heading home. I'm was fortunate that my neighbor was home at the time for lunch that he helped me lift it out onto the floor jack. ![]() OK -- ROUND 2 OF THE NIGHTMARE !!! READY ??? Get the 4cyl bellhousing bolted on and the trans ready to go. Around 6pm my dad actually stopped by so he helped me for about 45min get it up in there and a few of the cross member bolts on. The next day, wake up, get the TQ, bellhousing/starter and everything hooked up...close to noon. Take a break, eat lunch and contemplate if there's anything I've missed. At this point after checking, start to fill her up with fluid (again, at $11 a gal ) and get it all filled..START UP REDCAR.. all sounds good! Now at this point I have it in 4wd-HIGH. Put it in REVERSE and pull out slow. All seems fine, put it in DRIVE and start to take off. Give it a bit of power and 1st, 2nd & 3rd seem fine !!! WOOOOOPEEEEE !!! Drive around for about 4 or 5 miles to test it out and see how it is... don't like the take off power since i'm used to the clutch and instant "LAUNCHES" but it seems nice. So pull on my street and decide to try 4WD-LOW.. BIG MISTAKE !!!! The LOW RANGE on the transfer-case howls and grinds like something I've never heard before. ![]() So.. Now I have a 2nd setup that does not work. Pull into the driveway, now really depressed and confused about what I'm going to do, I call my buddies at the yard and they say the same thing.... Quote: But this crap is wearing on me, and pulling a trans is no easy task not to mention installing the damn thing. At this point I'm thinking about paying to have my 5spd rebuilt!!! So yest (7-12-2010) went down there and we found the perfect combo, and also I talked to Kevin and this is what he did on his.... Today (7-13) we are going to take a 372-L made in 91 (91JP) but has a active-track transfer on it (same stick as my SR) and divorce it from there, and they have a 87- 4cyl 372 setup and pull that transfer case and mate it up to the 372-L.. So basically, a 91 372-L lockup trans to a 87 4cyl transfer case. Doing that this morning. So... 3rd time's a charm !!! |
Also, does anybody know where to get trans fluid cheap in bulk because Pepboys at $11/gal is getting old going on my driveway and into my drain bucket. thanks! |
I want to see pics of the jumps seats. When I look at my SWB, I can't see how to make them fit. |
Quote:Those jump seats are in my SR and designed to fit in there. REDCAR has a special platform that I designed and built in the back of it and the rear seating is out. It's strictly a 2 seater "love machine" !!!
Jason good to hear u got the flexplate, sucks about the tranny and all the extra work u had to put in. If u still need help by Saturday, hit me up. |
Hey Nick! I txt'd you but never heard back. Didn't know if you were out of town or not. Don't know if tomorrow you're around but I plan on trying to put this thing in. I'll try to get ahold of you again. My new EVO Sprint phone has been acting up here. Anyways... SO GOOD NEWS AND LOTS OF PICS... STARTING OVER AND WITH A TRANS WITH 83k on the ticker !!! Damn this $hit sucks !! Everything in the back of Lucky ready to go back down incase things got nasty and I wanted or got my money back. Everything to do a full Auto conversion. ![]() ![]() So I go down there and I'm greeted by my good friends and they've found me the perfect setup. This beast. A 91 372-L but it looks like it came out of a 95-SR and it has 83k miles, verified and perfect!!! Only issue is that transfer case has a scary amount of solenoids and crap on it and is NOT FOR ME!!! ![]() ![]() ![]() ![]() ![]() So the only thing to do is one thing! DIVORCE THAT [censored] AND MATE IT TO A 4CYL TRANSFER CASE LIKE THIS ONE!!! ![]() This is the 87 non lockup 372 that he pulled the bellhousing off of so I could use for the V6 setup. He was all like "Bro, I tearing apart this whole trans and loosing money just for you! What if someone wants this unit? Now I don't have anything for them" ![]() I'm like "dude, no one has taken this thing in years, no one is going to, don't sweat it, they never die anyways" So, after a few bolts on each unit here and there, a little wiggling... some RTV to seal... This is what we get... ![]() A V6 372-L lockup trans matted to a 4cyl transfer case ![]() ![]() Waiting for my buddy to come over and help me lift it out. Also he let me borrow (jeeze, now he tells me he has this f'ing thing) this auto trans adapter for your floor jack... this will make my life 100000000% easier. And of course, how I look as I sit here... Of course it has to happen near 100* heat but that's what beer if for! OMG I hope 3rd time's a charm!!
Jason did not receive your text, I'll send u a pm. |
Jason, OMG what the heck did the previous owner do to that shifter boot? Let his pet rats chew on it for a while? Also, I don't see the shifter on the new setup or is that detachable?
Ray, I have no idea about the SR but I did get a kick about that boot. It is kinda scary to think all that electronics crap controls our newer transfer cases and such.... AHHHH the good old days when simple swaps were easy! I can not image what it takes to get those newer ones to work! I actually cannot do anymore wrenching today because Pat and I are going to see the screener of Inception down in Burbank so I've got to bail. I did pick up a new pan and filter kit so I'll put that on along with the bellhousing tomorrow. I think Nick may stop by later in the afternoon or evening or help put it in. After that I'm looking at a Thurs- noon time startup
Quote: I dont think you should be using that. There is stuff made for Mitsu and chrysler. |
Is that the t-case from your 4-cyl MT you mated up, or from a 4-cyl AT? |
Quote:sitting here in the theater waiting for the movie to start at 7:30 but that T:case is from that picture and how I described it earlier. Off an 87 4cyl auto 372 non lockup. As for the fluid, this is just for testing and getting it running. I still have 2 cases of Mistu diamond star trans fluid I got for free from my buddy plus my bro still has a case I got for him when he had his Gallant! This is just to get it it up and running! |
I have been running Dexron III in the same type of tranny for ten years without a problem. Kevin |
I like what your doing, and the price is really low. I think I am 2K into my FM145 tranny swap but I am going with a brand new tranny and a Centerforce Clutch Kit. I don't want to chance going with 30 year old used parts because I don't want to be swapping trannies in and out until I find one that works. I have been there and done that and it's not fun. The reason you were blowing your overdrive was because the 5th gear bearing retainer was tightened too tight and the 5th gear bearing sleeve wears into the 5th/reverse synchronizer hub. This problem is further caused by the failure of the 5th gear on the mainshaft, causing the 5th gear to seize to the 5th/reverse hub and then break or in your case grenade. Drivetrain.com makes a bearing retainer with a collar to prevent this from happening.
If you do plan to have the tranny rebuilt, I highly recommend going with Transaction Transmissions in Sun Valley. I live in Utah and I get all my trannies from Brad even though he is 1000 miles away. Brad is a great guy and has been work on these trannies for 30 years. I have never had any issues with any of his trannies and he knows his stuff. http://www.transaction4you.com/ |
Spence, It's funny you mention them because I know them VERY well. I grew up in Sun Valley and if you look at my pic with the new rebuilt blue TQ, they did it for me Pretty much if I was going to have any Automatic or high performance stuff done there, I'd take it to him. But what's funny is that when I asked him about my KM145 issues, he really did not know about the 5th gear problems. Oh well. Hopefully this 372L is a good unit. I'm about to go outside right now and remove the pan, put a new filter on it and seal it up. As for my old KM145... I'm holding on to it for now ![]() Plus I hear they are worth some $$$ actually!! |
Just wondering..You have installed a bad trany or two in this Monty ...Right ..? Are you flushing the cooler and converter each time ...?? Sorry to ask David Hazardous Toys inc |
Ohhhhh yeah. hoses and the hard lines. Pretty much anything and everything. Well, time to start in the 100* heat. Today's agenda.. 1.Swap bellhousing's from the V6 back to the 4cyl. 2.Remove pan and change filter, then reinstall pan with kit. 3.Uninstall temp sensor and related wiring crap and install temp gauge sender unit. 4. Install Transfer case shifter. Then probably wait for Nick to roll over and install this biach. OMG... what a day
He is going from a 5speed to an auto trans and I don't believe the manual transmissions have external coolers. I am sure he is doing it, but I would clean out the cooler being installed regardless. I have a feeling Monte has already planned ahead though.
Quote: LOL, what are the odds, of all the tranny shops in the whole country we use the same one. I think they are the best, especially for these Mitsubishi trannies. Quote: Yeah I had to fill Brad in on this issue, but the reality is, the cause of this problem is due to overtightening. Brad never has this issue because he knows how to rebuild a tranny the right way the first time without overtightening it. But he said it make sense that the 5th gear and reverse are seizing together. Hey if you ever plan on upgrading your rear driveshaft, I have a brand new custom slip yoke with a 1310 connection which will add alot of strength over stock U-joint. It's in the classifieds section , but I will cut you a better deal. I think it would be a great upgrade with all that power you're pushin' and you would not have any issues with leaking oil out the rear seal.
Quote: 1: On the first unit that went on Jason the main shaft nut was torqued correctly. I should know, I'm the one who put the first unit unit together. Jason got that tranny when he bought my wrecked Raider ten years ago. He did the next handful of rebuilds.2: On the units I have looked at the failure mode was not what you described ( over tightening). The bedding in of the parts is caused when the main-shaft flexes in torsion. The parts held in compression by the main shaft nut are a lot more rigid. This causes the parts to move ever so slightly in relationship to each other. Over time this can cause fretting damage to the surfaces. Most people dont realize how much the output shaft flexes in torsion. This is true on all transmissions. Take the engines peak torque rating and multiply that times the first gear ratio and you get about 750 ft lave of TQ that gets output through a 1" shaft. When it gets really bad one of a few things can happen. The main shaft retainer comes loose. This was an issue on the early units and is why the factory upgraded to a large bolt. So unless both the factory and myself missed when we torqued the main shaft nut down, over tightening does not seem to be the root cause. 3: The failures on the OD were fractures at the root of the gear tooth, not the OD gear seizing on the main shaft. 4: I have seen the main shaft seizing problem in some of the units I have gone through. Low oil and or the wrong weight oil and or dirty oil all seem to be factors. The OD gear is hung on the back of the tranny and does not seem to get as well oiled. 5: The OD gear is a two piece unit. The factory makes the dog clutch in a separate operation and welds that to the gear hub. If you combine the thinner section of the gear with a two pieces design you may have a problem. 6: Jason is running tall tires and a turbo 2.6 that puts out a lot of torque. Easily 260 ft lbs. On the stick motors Mitsubishi reduced the boost at low RPM to increase transmission life. The combination of 260 ft lbs and a vehicle that can use that can easily use everything that motor delivers in OD on a long hill put this combination as one of the most highly loaded version of this tranny I know of. Passenger cars are hard pressed to be able to hold the motor at or near peak torque in OD for any length of time. 7: I'm sure people over tighten the parts and can cause problems, however the units have problems even when tightened correctly. In my experience Loctite helps. I also built a better thrust plate lead spreader. for the main shaft. Along that line Jason is running the first strengthening pan ever built. Its not that the mits case flexes more than other units, all trannies have this problem. I realized that anything that reduces case flex increase gear life. Unfortunately it wont help the OD problem. At the time all I cared about was the first few gears, OD was not an issue. The bonus of my design was that i cut fins in the bottom and made it deeper to hold more lube. I dont know if Jason still has it or not. It might be that a new single piece fifth gear would eliminate this problem. The other solution is to reduce the OD ratio. The would increase the thickness of the material under the gear teeth and reduce the stress level on the gear. Kevin |
Interesting points Kevin, you are right, just because the fifth gear on a KM145 fails does not mean it was over tightened. The are still inherantly weak because the gear is pretty thin. So do you think they would be better off with a .79 5th gear ratio like the FM145 found in the Ford Ranger instead of the .856 found on the KM145? I have never run a stregthening pan, but I did buy a Tuff Pan yesterday for my new FM145 because I will be running a 5:1 Atlas I want to reduce the flexing as possible. Like I said, I have never had an issue with the KM145 but I hear alot of horror stories. I push about 200 ft lbs of touque and I also run large tires but the original tranny lasted 275K miles which I find to be acceptable. The reason I replaced it was because I took it swimming and I had a small tear in the spring cover boot. It never failed or made funny noises, but I figured it was smart to swap it out when I replaced the clutch because I had a rebuilt tranny lying around. I also follow a few rules of thumb that I never use 5th gear below 55 mph or while going uphill. I also only use synthetics. But most importantly I also don't let the wife drive it. I try to avoid putting any undue stress on the over drive gear.
Quote: Interesting thought... I think that would help. Even more so if they get the ratio change from the modifying the OD gear. The OD ratio is a combination of the input gear to counter shaft ratio and the OF gear ratio. Some units have different input gear counter shaft assemblies and that ends up changing the OD ratio. The other issue I have seen is the main shaft thrust plate on some KM145 was soft and pounded out. That let the synchro hubs run against the forks all the time, dumping extra metal into the unit and causing all kinds of shifting problems. One last thought is that I'm a strong believer in shot peening the roots of the gear teeth. Assuming it was not done at the factory it can increase fatigue life by a factor of three. Also, nice find on the modded OD gear. Makes me want to build another stick. The upside of the auto is I have had to drive in a lot of traffic and not having to shift is nice. My other car is a stick so I figured I needed at least one auto. Kevin |
So, here is the real solution to bolting up a bulletproof 5 speed tranny behind a H.O. 2.6 liter. You need to obtain a bellhousing from Ford Ranger 85-87 Diesel, which are rare and somewhat hard to find. Then mate a Toyo Kogyo TK5 transmission using the starter, clutch, flywheel, slave from a 85-87 2.9 L Ranger. I know it sounds wacky and complicated but it will bolt right up and you would also get a BW 1350 tcase with a 2.48 and fixed yokes which is a huge improvement over the KM100 TCase. The TK5 is also capable of being mated to the Atlas II Tcase which I like. I am going with the FM145 for now because it has a .79 overdrive campared to the TK5's .84 which gives me a bit more top end on the interstate. I need all the help I can get because I am running 5.13's. But if my FM145 prematurely fails I will swap to a TK5 in a heart beat. |
How was the movie??? |
That is some cool info, Spence. Doing a quick search and it looks like only one bellhousing option for the 85-87 2.3 diesel? |
Well reading through all these last posts, pretty much Kevin is dead about the gears and everything blowing up. Also YES on the pan, I've still got it on there and it works (and looks great!) ![]() Spence, Kevin was right about my setup and my power and I can 'cruise' up the Grapevine in 5th gear doing 80 without breaking a sweat driving those 33's so those 2 OD gears have always been taken a beating. The last time I tore it apart, I put a new set of gears that have a "finer pitch set" to them or more teeth (see pics below). I was told this would hold more power as there's more teeth and less chance to break off the bigger chunks as I'm doing. Beside that, this trans was pretty solid and I've had no other troubles with it except the OD gear. This time the 5th pops out hard no matter what under power. The rest is history as the auto is rock solid (lol) Here's how I like to grenade them... ![]() Gear on the left was Kevin's original... Lasted about 2 years (01-02?) with me hitting it hard. Right side is shot-peen'd after Kevin said to try that about 3 years later or so. As you can see it held up better... ![]() And here's the replacement gear set that's still in here and good, just pops out of 5th...notice the finer pitch. ![]() Now time to write about yesterday's adv !!!
1st. of all..BIG THANKS TO NICK FOR COMING OVER AND HELPING ME WRENCH YESTERDAY !!! THANKS BUDDY !!!! So yesterday started out like any other day except it was going to be triple digit heat!! How nice ![]() So first thing's first. Get the V6 bellhousing off and the 4cyl unit on. V6 Bellhousing -- Biach you gotta gets outta there !! things are looking more promising but this one was the worst of the 3 to get off!! it was on there BAAAD!!! Get the 4cyl bellhousing on and bolted up! Looking good (for the 3rd time )Now the fun part!! Since I'm by myself during the day, I've got to lift this thing up and get it rested on the 2 jack stands so I can remove the pan... Fun times!! But I removed the pan, and that went into the parts washer and the fluid was clean, no bearing material or anything nasty really!!! So hopefully this is a good unit!!So while the pan is getting a good wash down, time to install the new filter kit. Bolted back up and that's pretty much a done dealio! Clean pan out of the washer ready to install!!! Permatex Auto-Trans ATF RTV.. the gasket... and it's a done deal.. To tell you the truth, I don't have any more pictures after that because I was a total mess, it was around 5:30pm and Nick was coming here soon but I was pretty much done with the trans stuff. I had to go pick up the pizza and sodas and crap so I had to bail. Pretty much the rest of the evening turned out like this.. Nick showed up in his Raider, we ate, shot the $hit for awhile... then wrangled with this biach for about 2 hrs and got it in and mounted around 9:30 or so! ![]() We screwed around and looked at his Raider until 11 or so and then he bailed.... I was just to wiped out to do anything else. Today's agenda.. 1. Install TQ bolts ![]() 2. Dipstick Tube 3. Shift linkages. 4. Trans Cooler lines 5. Drive shaft Probably start it up and test later afternoon when the heat comes down abit. It's already baking out there! Fun times! |
Those are some great pics of the carnage. As sick as it maybe, I love to see pics of failed parts unless they are from my truck. then it just sucks. ![]() So what'd really unfortunate is Advance Adapters used to make an adapter that would let you bolt T4 or T5 World Class Tremec that could handle 330 ftlbs of torque which would have mated to the 4g54 motor through the 2.3 diesel bellhousing. The T5 was the tranny they used behind the Cobra Mustangs. It really sucks because it would have been a sweet and reliable setup. Now my only chances of getting setting up a T5 is finding someone willing to part with the adapter or convincing AA to make more. Niether of which I think will happen. For now the only options are the TK5 and the FM145 which are not even in the same leauge as those T5 trannies. |
Quote: Is there any special year/vehicle that TK5s are better? Did you check these guys for a T5 adapter? http://www.5speeds.com/ or these guys? http://www.jamesduff.com/ |
Quote:Quote: No, I just checked with AA because I know they used to make the adapter. But 5speed and JD may have something as well. |
Well how about a little status update everyone?? ![]() Well I guess 3rd time's a charm!!! because that's what it took to get this damn thing to work!Tranny work fine, shifts fine and so far so go! Since I can still only get the front drive shaft in, doing WOT starts is scary in this thing! These vehicles were not designed for FWD only!! They get squirely as hell when the front tires spin hard!! ![]() So the fastest I had REDCAR yest was about 60mph but the shifts are smooth and the feels solid. So far so good and front cooler kept it around 160* according to my temp gun. Underneath, not a single leak, drip or looking wet anywhere. So this morning (Friday) I have to run back down to the yard and do a few things... 1. give him back his jack stand. 2. give him back his V6 rear drive shaft that I no longer need 3. get a shorter 4cyl Auto rear-drive shift that will fit!! Come home, install drive shaft, change trans fluid and see how it looks, refill and now fill the TC all the way! Drive to the muffler shop and get my exhaust re-welded back up!! Start to put some miles on it today!! After that, I need to wire in the AutoMeter temp gauge I bought for it. Does anybody know what the highpoint or what the temp the factory light comes on at? Thanks! Jason P.S. Lots of pics will come here shortly! |
Quote: IIRC, 300ish degrees... If you're putting in an A/T temp gauge, be prepared to pucker on long steady climbs uphill. I regularly see 250 plus. And that's with an additional auxiliary cooler that has an 8" fan on the front of it... Not to say that the temps hurt the trans, though. Mine is still fine after over 200k. |
Quote:OMG!!! 300*?? I don't think my gauge goes up that high!!Quote: ![]() EDIT: Well here's a pic - So now I know that if I'm pegged, the light is probably on and I should probably do something ![]() I think I'm gonna need some aux cooling!! |
Quote:Quote:OMG!!! 300*?? I don't think my gauge goes up that high!!Quote: Mine doesn't either. I didn't realize exactly how hot these things get when selecting a gauge. The aux cooling does help matters. And yours may not get as hot as mine does because of yours being an SWB and having the turbo for more power... |
Quote:Quote:Quote: This is probably worthy of being split into its own thread. Can a 5 speed from a Wrangler and a 231 drivers drop TC be mated to the FORD Diesel bell-housing? |
Re atf temps, the 89fsm has a note on page 21=86ish that the light comes on at 122*F, which is obviously wrong, as the normal op temp range for the atf is 122-176*F. Somewhere that I can't seem to find now, one of the manuals says the light comes on at 276*F, which is way too high, and I think there's a tsb that corrects that to 176*F, which makes more sense in light of the above op range. The stock sensor switch is pretty buried in the flowing fluid and this keeps it isolated from the exhaust heat (but it seems quite sensitive to getting wet). I wonder if Larry's gauge sender is in the same spot as the stock sender switch, and is adversly affected by exhaust heat?. I seem to remember reading that for every 10* increment over 170, you cut 10% off tranny life... The l/u tc should have lower atf temps than the non-lu, since the primary source of heat is the tc slip, but Larry's should be a lu unit, as is the one Jason just installed... |
Only thing I can find so far in my 1998 manual, normal is 158° - 190°F. |
Not to take Jason's swap thread too far O/T... Yes, mine is in the same spot as the OE sensor. I used a 16mmx1.5 to 1/8" NPT adapter from Autometer to install the standard Autometer sensor that's supplied with their electric temp gauges. Eddy I never really thought about it being that close to the exhaust to effect the gauge reading. I'll be adding fabbing a heat shield to my list of things to do when putting the motor and all back in... Mine did regularly read well over 250*. I'm pretty sure the temp that the light comes on is the 276* figure. If you think about it, 170* is nearly impossible to maintain in the trans. First of all, the fluid runs thru a cooler in the radiator. The OE thermostat temp is 195*. So, at least when the fluid is in the cooler in the radiator, it's at 195*, give or take a few degrees. Mine is a lockup unit, so the trans should be the same. His truck is likely lighter than mine, mainly because it's a SWB vs LWB. That should account for several hundred pounds, I would think... I've heard the "for every 10*" thing before. Not so sure I buy it completely. Heat is , in fact, the major killer of A/T's. It's really crazy though to watch the gauge when going up a hill and then down the other side. It can move almost as fast as the tach... |
Quote: Yup, I agree, but you are not at 195 in the radiator bottom tank unless the radiator is doing no cooling at all. In fact, the lower tank should be the coldest place in the cooling system. I have no way of figuring out how much cooler, but I bet at least 20*F, if not more. I used to run a tranny temp gauge in the FJ55 with the 350sbc and the 700R4, and it stayed under 180 unless I was pulling a trailer in 3rd with the converter unlocked. It never got over 200. I had that sensor tapped into the pan, not the cooler lines, at first, but later put it into a well on the to the cooler line, as the pan temps were even lower. Did your light used to come on during hill climbs? I don't trust your gauge reading. Anybody else running a tranny temp gauge? If so, what does it read? |
My light came on once. But it also stayed on for several days. And it had been raining. Go figger... Hadn't thought about the top to bottom temp difference in the radiator. I should've though... Duh... Now, I don't trust my gauge readings anymore. I will definitely be putting some sort of heat protection against the exhaust... |
TSB-89-21-005 (April 1989) says: Cross out "50°C (122°F)" and write "150°C (302°F) Frank |
That 300+ makes this article really scary: Quote: |
This is awesome info Eddy, Frank and everyone else. Thanks! Sorry I've been MIA for the last few days but I've needed a break from everything! so that meant hardcore relaxing, BBQ'ing, swimming and drinking on he side ![]() So... Monday morning.. Time to start knocking out the details and get REDCAR road worthy! I've driven him about 25miles now, and no issues except 1 MAJOR PROBLEM.. Lack of power, lack of boost and over heating ..Now to remind you all, when I first had all 3 transmissions in, I could lite up and spin the front tires like there's no tomorrow and the boost would come right up. Now that I have a rear DS, and I got the CAT and muffler put back on, I've got what feels like a carb'd 2.6 ![]() I can barely get up past 6psi of boost and on the FWY, in OD on the trans, I need more then 75% throttle and 5psi just to maintain 70mph and then my motor starts to get WAY TOO HOT!!! Now this is a new CAT of this JAN, but when I was getting it off, I had to bang the hell out of it to pull it off. Maybe the beads fell down or broke loose? and now mounting it in a vertical position it's blocking the exh? So... this morn, I'm going to unbolt those lovely 2 bolts that come off the bottom of the turbo down pipe and see if I get my power and fast boost back. If so, then back to the muffler shop. If not, then I'm stumped. Oh, and LOTS and LOTS of pics to come later !! ![]() Jason |
I also wonder if the gen II Radiator provides a lot more cooling? If so, it might explain the problems with overheating . |
Quote:I never had a problem before. I also have a custom 4 row radiator in there so that kinda helps! No, I'm using too much throttle and there's too much back-pressure. Gotta figure this out. Getting ready to hit the garage and the ground again! UGH! |
Alright guys... getting my pics and ducks in a row so to speak. Got the fan and radiator dropped down 2" yesterday. So that's done. Been having a pita of a time with the turbo and intake system since it's 2" further away and my rubber boot system is stretched further so it's either pulling off or not working for me. I need to look at the Starquest guys and see what they are doing but I'm getting ready for my Snorkel setup now. But tranny setup, so far- so good, I need to finalize the temp gauge, and the OD setup. Besides that, I have a few things here.. 1. On the HWY, it takes 0-3 psi to maintain around 70mph in OD. On the 5spd, I was always in VAC area but never in boost. Kevin verified this as well as his does this same. 2. I cannot keep HWY speed (70) on a grade with the OD. Have to turn it off (3rd gear) then i can keep 70mph. 3. I'm also pushing a TON of weight also. Kevin said his vehicle is around 3700 or 3800? Last time I weight mine, it came in at almost 4800 lbs!!! plus he's bare and driving 31's. I'm driving 33's and have a 9000lbs winch, associated mounting, massive roof rack and air dam on top and all the under carriage protection so now I see where the power is going so now I don't feel so bad. ![]() 4. A 2.6L engine pushing this much vehicle and still getting 16mpg is not bad! ![]() Anyways.. pics come here in a bit. P.S. my idea of a "grade" is the steep side of the Grapevine on the 5 fwy that I used to be able to go up in 5th gear on my 5spd
Jason, consider the difference between the m/t and a/t top gear ratios. The m/t is .856, and the a/t is .688. That's an almost 20% increase in "resistance" at the flywheel with the torque converter locked up. AND a similar reduction in rpm at a given speed, which drops you down in the power band too. I've been up the grapevine precisely once, in the mid 70's, and from what I remember of the grade, what you are seeing is normal. I was in a repo dodge custom van, and the torqueflite and 318 spent the whole climb in 2nd at high howl rpms... |
Quote: Can you please be more exact FE? ![]() Sorry, nothing really relevant to add other than that.
Quote: My 3.0L blower/lockup A/T reads vacuum at 75mph on the flat in O/D, but requires a slight boost on a grade at 70-75mph in O/D.... about 1psi usually - but if the grade is severe, it might go a bit higher to 2-4psi. Mine has never yet downshifted on a grade at highway speeds. It might on mountain grades, though...... haven't tried it. My curb weight is about 3700 lbs. without anything in the back. The AW372 lockup unit would be a little friendlier if the O/D ratio was a closer to 1:1 and cruise rpm were a little higher. There's just not enough low end torque to pull the truck out of the O/D hole around 2000rpm..... if you're a leadfoot. I have become fairly used to thumb-shifting the O/D at low speeds. I could instead give it more throttle and down-shift it, but that's often more than I need and it over-runs in traffic.... so I've learned to use the transmission as if it were a M/T and I can keep it in the power band quite well that way. I'm still tuning, but fuel mileage is now 16mpg - not nearly as good as the last engine. Maybe with taller tires it'll do better. Frank |
Quote: Sure. "My one and only time"... |
This is all good info to have for sure. No doubt about it that I'm a lead foot and pushing more power then most but also more weight then any 2dr as well. I also think Kevin has the adv because he has the 31's but also he has the TC gearing mod done as well. unless that only affects low range? I can see that helping alot with the taller tires! Frank, I did not see in the you sig anywhere what size tires are you running? On the flats I'm pretty much no boost as well but any slight incline and I need some to compensate. No way I'm going 35's on this. I would never want to use the OD then or I'd just go back to the 5spd.Time for a V8 swap now??
Quote: Yep, only low range. No effect in 2WD... IIRC, Frank's running either 31's or 32's. Is there any possibility you have something dragging? Like brakes or bearings... |
I was running 32s with the last engine, but put on stock 235/75/15s for dyno tuning and they're still on the truck. The 32's will probably be better for fuel economy, but will also rob some torque. Once you get the 32s rolling at speed, though, the truck wants to run at 80mph. Kevin once said it's easy to see why manufacturers went to electronic transmissions with small engines, but I think it's also easy to see why they now have 5 and 6-speed automatics. The AW372 needs another gear for big tires, small boosted engines and sporty driving. V8? Maybe for you, but I'm waiting for a 3.8L crankshaft to put in a 3.5L block with a blower. ![]() Frank |
Quote:nothing is dragging... but like Frank said, he's got way smaller tires, and a much lighter vehicle.Quote: 33x12.5x15's are no easy task to spin around. Take almost a 5k lbs vehicle with the aerodynamics of a brick wall and a 2.6 just needs to work a little bit harder ![]() I foresee my OD switch getting used ALOT in the future!!
I did find that the OD ratio changed on the lock up converter tranny. While the non lockup unit has the .688 ratio the lockup units have a .73 ratio. That may explain why the people that switched from a non lockup to a lockup unit noticed it drives better on the highway. I would be happier with about a .8 ratio, the jump from direct to OD is a bit much. Also I want to be able to control the lockup... That's where the electronic controls would be nice. Kevin |
AWESOME !!!! I'm pulling 14.1 mpg now after a 104 mile drive. Granted it was some hills and "spirited" going from Sylmar to Monrovia and to Burbank and back. But in the end, at 70mph, I'm barely breaking 2500rpm so I'm not the happiest about that. Dropped from around 17/18mpg with the 5spd.Hooking up the trans throttle cable will help because that will unlock the converter and raise the rpm while cruising. For now, need to work on a linkage/cable solution for the trans cable. Not fun stuff ![]() Temp gauge pics and center console stuff coming in the morning... |
TV cable/valve has no effect on lockup at all. Only affects tv pressure to the rest of the elements and downshift/upshift points. BEWARE, if you run with the tv cable unhooked, you run a serious risk of frying the tranny due to insufficient clamping pressures. Many of the internal pressures use regulated pressure plus throttle valve pressure for clamping force on the clutches/brakes inside the slushbox. You can use the carb tv cable from a 2.6 a/t truck with a fabbed bracket, but you will need to add a crank wheel to the throttle shaft for the cable. might adapt the a/t starion setup for the monty cable if you can find the parts. IIRC, the starion bracket leaves the monty cable out of the adjustment range. |
Quote: ???I was under the impression that if left unhooked, the trans has full pressure. ![]() I know that when I'm on the freeway, the TQ is locked hard, and no slippage at all is going on. I'm thinking this, when the cable is hooked up, you give is more gas, you see the RPM's rise from your cruising RPM a few hundred or so... That's the converter unlocking. Happens in my SR, my buddy's LS, and most other standard automatics with a lockup. Give abit more gas and it shifts up to the next gear. I've been driving around with the cable hanging outside the hood and pulling on it manually and it downshifts and unlocks fine.Again, i thought that left alone, the valves are getting full pressure to the assy. I know that the high-power, full boost (16psi) runs I've been playing with, it shifts smooth and no slipping at all between the gears. But I know this is something I need to tackle here quickly. This is a PITA because of the location and the firewall ![]() But it will be done this week. |
The 95sr and the computer shift LS are different animals. The converter will unlock under computer control on those. On your analog slushbox, you get converter lockup at about 40-45mph regardless of throttle position, as long as you are in o/d at that speed. I do not think you get lockup in 3rd at all. If you upshift later than 45, you get the upshift, then the lockup (that's where you'll see the 300rpm drop). It's my understanding that you have less than optimal pressures with the tv cable unhooked. I think I'm quoting KevinC on this one, and you might pm him for a more definitive answer.... I have looked at the hydraulic schematics on the lockup circuit, and it only sees regulated pressure (constant) and govenor pressure (speed dependent) at the o/d lockup valve. When the speed reaches the lockup spec, the governor pressure overcomes the regulated pressure and the valve either blocks the return flow from the lockup clutch, or allows pressure to apply, can't remember which, but I think its the former.... |
Well busy week for sure.. the most daunting task is making everything look stock, work stock and be reliable in the end. This just requires endless days and days and days of my time. No stopping. So, beginning of this week, I needed to start tackling the trans-control cable hookup issue. Figure a way, etc. After a few beers , looking at the spare intake manifolds I have.. I come up with this idea...Use the spring lever here....reverse flip it since it's on a half-shaft and my TV cable is coming from the brake booster area.. So i decide to whip out the oxy-acet and do this little stunt on it so now it looks like this.. Perfect thing is too, it already has a hole that one of my clevises looks like will fit into Problem is, this sucka is on the end..Now if you've ever had a motorcycle, dirtbike, jetski, anything that's FUN, you know what this little "eraser head" end is on this cable. Most throttle cables have them, etc. Now this does me no good so OFF YOU GO ![]() Now, if you've ever been in the world of aviation, or model aviation, these nice 1/4 scale clevises just happen to be the perfect dia fit for the wire. Luckily i had a few left over from my huge sailplane... So on it goes with some silver solder and lickidy split that part is done ![]() P.S. about the above shot, sometimes, working alone SUCKS! because humans don't have 4 or 5 hands.. holding a flexable cable under tension, while trying to hold a clevis an iron while feed solder at the same time sucks! So.. Now that the cable, and throttle body is done, I needs me a bracket... so after some heat, cutting and such, i came up with this little guy... One hole where the brake booster is, the slot for the TV cable and adj.. SO NOW WHERE ARE WE ??? After all is said and done, testing driving etc, I'm happy, but not 100% satisfied. Hooking up the TV cable made a WORLD of difference! and the tranny shifts so much nicer but I can see the flaw in my design and the issue I'm having. So I'm going to redo this.I'm sure the wrenchheads or geeks on here will see this right away. I'd like to see who picks up on this first, but I'm going to try and make it more like the stock system. but for now, it's working well, shifts well, etc. AND NOW FOR SOMETHING DIFFERENT !!! NEVER EVER NEVER EVER BUY SUNPRO GAUGES OR METERS That's Jason's tip of the year.. I'm sure you all probably seen the picture of my trans-temp gauge earlier on page 4 right ?? ![]() Well I wanted to hook it up, so I'm getting ready to mount it and I pull off my center console since I have to now wire up my OD switch system and WTF ??? do I see.. This is what my sender on the trans looks like.. Well this sucks big time, so I go online and start looking at that part# for them, seems to be a BIG TIME issue with the tops just popping off sender units... So, if you're going do it right, do it the first time and do it once.. So I decide to get this.. It's 3 times as expensive (from a $20 to $70 almost) but my 3 autometer units in REDCAR have been in there for over 10 years and the other 2 with Kevin for who knows how long. So they are quality. Problem is, only 1 place in SoCal has this unit, Hawaii Racing in Simi so it's a 1.5hrs total drive to get this mofo.. Once back, pull out the old volt meter which I'm locating down below... Get this guy wired in along with a bulletproof looking sender and I'm all set.. Get that all mounted back in, and wire up the OD relay system. Unfort did not have access to a stock factory harness setup so I'm basically having to wire the whole system up by hand. not a big deal. I've got time. So Today, Friday 30th, center console goes back on, and I'm deciding if I want to chop off my rocker panel units to reweld them higher for the body lift.. Or start on my SR seat conversion ??? I got the front seats out of an SR for $20 !!! so I want to put those in soon. |
You gonna open the throttle with telekinesis??? |
Quote::o No, I added that to the shaft and it was just long enough for the lock washer and nut to go back on. But I'm going to fab up another bracket this week that starts to pull at 45* instead ![]() But I have a bathroom to start remodeling so ![]() But I want to wheel!!! |
