CJM
(Body Damage is Cool)
12/08/07 09:27 PM
sold the first one .. so this ones mine ... Trekker Build
bought a few Trekkers a while back .. and now have started my own .
this one is going to be a "some what" stock restoration .. but with a few "extras" .
so here's where I'm starting .
don't mind the dust .. it's been sitting inside my shop for a while now .
there is one small rust hole on The right side .. front spring hanger , inside box steel .. you can see it in the pic .. it's so minor , I'm just going to weld in a patch .
so a little work today ... got onto the frame repair .
got the little plates/patches welded in .. It really wasnt that bad at all , the main / worse dammage was from me hitting with a hammer it trying to find the rust .. I really didnt see any point in doing "fish plates" .. as there (in my opinion) was NO structural strength loss . Other side is perfect .
and done ..
also started "prepping" the frame for the POR-15 treatment.
Dok
12/10/07 10:50 AM
Re: sold the first one .. so this ones mine ... Trekker Build
As with all of your builds, lookin' good This one gettin' a 7mgte too?
CJM
12/10/07 11:02 AM
no 22r +
I hope . :) just workin' on the deal .
Greg_Canada
(Roll Me Over)
12/10/07 12:41 PM
gosh darnit CJ you're stealin my ideas! (blown 22r in a trekker) but atleast youre bringing them to reality
oh and you can thank me for youre next order of 89-95 bedsides to london you dont have the flared ones yet eh?
CJM
12/10/07 08:53 PM
well, not a "done deal" yet .... guy wants to trade so , well see . can't let him know I want it to bad :)
Trekker is for sale ! .. as any piece is !!! , for the right price .. so it could be yours :) but I think I'll drive this one first :)
Thank YOU for your references .. I totally apprecieate them . " word of mouth " is my only advertizing .
Flared/hi-clearance are in the works .
CJM
12/11/07 08:16 PM
so got the top side done (cleaned) , flipped it over and started on the bottom side .
also ordered the POR15 .
87Toy4x4
12/11/07 09:01 PM
damn, was that the most rust-free frame you could find lol? are you going to por-15 the inside somehow? if not i would think it would just rust from the inside out.
CJM
12/11/07 11:21 PM
it's really not that bad , it actually hasnt been used in 10 years , but it was sitting outside (under cover) , so it has surface rust .. lots of factory black , in many spots .. it looks way worse in the pics , then in real life .. Trust me , It's the BEST frame I have seen in a lot of Years , Very solid .
I have a pressure pot , with a flexable hose and a 360* spinning v notch nozzle .. works awesome , so YES .. inside will be done as well as outside .
Vanishing_Point
(Wheeler)
12/12/07 02:31 AM
I've debated spraying the inside of the frame with oil. I'd have to watch the welding.
dcg9381
(Rock Warrior)
12/12/07 12:16 PM
no 22r +
CJM, ping me on that blower.. There are some things that you need to know.
wsquaredodie
(Rock Warrior)
12/12/07 03:05 PM
Might as well get it sand blasted. There are ag shops that have people doing large equipment all the time. Get the whole thing blasted, then you can see if "surface" rust is really surface. Not that expensive, especially with the results you will get. Make a decision based on results. If all is fine a quick pickling will go a long way. Best primer step for iron / steel is to hit is with phosphoric acid. The result is black iron phosphate which is a dandy anti rust layer and makes a perfect paint surface. Check it out on wikipedia. There are several ways of doing the pickling, including spraying with diluted phosphoric, using "navy jelly" or some variant of that. After the metal turns gray / black, a quick wash with water will get rid of the acid and away you go. So, blast, pickle, wash and paint....
CJM
12/12/07 08:23 PM
no 22r +
you have mail :)
I dont think I need to go that far .. but thanks for the info ..
LAST one I did .. I did all that (some of you may remember this build) but .. POR 15 does NOT need this process .
The rust you see in the pics really is only surface .. the reason for the hole (in my opinion) was because the gas tank was left in , and mud was packed in there , and it stayed wet .. thats the side that was on the bottom .
ANYWAY .. I'm totally comfortable doing as POR15 recomends .. loosen the scales , de-grease , use the metal prep .. and paint on the POR 15
This one is now 5 years old .. and still going .
CJM
01/15/08 07:50 PM
well a little progress to post ..
parts truck is now in pieces .
long box frame has been sold , so it's time to "strip er' down " ... got the engine out , and cab hacked to pieces ..
box had been removed previously , and I had cut a hole in the back of the cab for the "long box Trekker" I built ...
Now that that project is all done (for me anyway) It was time to get to work on my project .
I sold the long box frame .. and I need alot of the pieces for my trekker .. so time to strip it .
lots of work yesterday , cut the roof off , and rockers , and cab corners .. I'm going to make some replacements :) so i wanted to keep them . got the engine bay mostly stripped , and engine out .
and here is where I started this morning ..
and finally the cab off ..
frame stripped ..
and diffs ready to build .
and finally my front clip .
CJM
03/09/08 09:04 PM
so work on the front diff is finished ..
axle rebuild is all done .. and new "vented " rotors .
you can see the whole thing here http://toyotatrekker.proboards107.com/
Greg_Canada
(Roll Me Over)
03/09/08 09:19 PM
Wow you can eat off that backing plate.
I cant wait till i have time to start working on my truck again! *damn college*
CJM
03/17/08 10:50 PM
Thanks Bro ...
got some goodies delivered today :)
and put away for the moment ..
CJM
03/19/08 08:04 PM
so I flipped the frame over late today , and got started on the "mock up"
installed the front springs
CJM
03/19/08 08:05 PM
so lookey what I did today :)
stuffed the rear springs and diff back on .. didnt get it por-15'd yet .. but that'll come later ... and yes , those are blocks .. for now .
I needed my jack stands , so I made some little wood blocks .. for everything to sit on .. I guess I did pretty good on them , kuz , it's perfectly level
moved the front diff over , and got it mounted as well ..
same thing .. I still need to "detail" but for now , I have other stuff to do .
grabbed my "cherry picker" .. and decided to see just how close the engine is to fitting on the stock mounts ...
it sorta fits , but new motor mountd are definatly called for .. the right side actually "sortta fit" ... I was able to get one bolt in , and over 1/2 the hole is showing on the second bolt ..
I'm going to "re-do " both sides .
it's comming :)
CJM
03/21/08 08:30 PM
ok .. so its not going to be as "easy" as I first thought ..
original mounts wont work ...
got the front all degreased , and cleaned and stripped
got the engine in , and leveled .. and figured this is where I wanted it .
I left some room between the alt , and the frame .. and also I was hoping to use the original motor mounts .
got the front clip on ......
NO way .. I cant have it sitting this high .. it's about 1' above the original hood line ..
so , time to start stripping the motor a bit , so I can get it down a bit .. I also think it's inevetable , I am going to have to use a body lift ..
Greg_Canada
(Roll Me Over)
03/22/08 10:51 AM
Body lift? I'm sure a man with such resources can make a nice hoodscooped fiberglass hood to hide the motor
CJM
03/22/08 10:16 PM
K .. hood is inevidable .. but !! maybe not so much .
CJM
03/22/08 10:18 PM
ok .. so took a " step back" today , and had a look at "things"
remove a bunch of "extra accessories" I wont be using ..
I went over to a buddies place , and had a look at his /83 .. and did some measuring (I dont have a complete truck)
I found basically the engines are the same length , but the 3.4 is wider , and taller .
so I did some more "mocking up" and I think I have it now .. :)
so with the crossover on the passenger side .. it actually hits the frame .. it also would interfere with the slave cylinder , and clutch fork , so It MUST be modified .
using the crossover pipe means , I cant use a rad . ORS wants $370.00 + a core charge on the flanges for a crossover pipe .. Downey wants $395.00 for a set of chrome headers .
I have a feeling I'm going with the Downey headers .[B] ??[/B]
ok ... so .. now with the crossover removed and the a/c compresser .. I can now get the engine where it should be , or where I want it .
[color=Red]>>>
the stick indicates the firewall [color=Red]<<<
[color=Red]>>> the stick indicates the hood line [color=Red]<<<
and finally .... fan and rad .. :)
I still have a bit of room at the back , so I will move it back a little further .. + I know a guy at a fiberglass shop ( ) that can build a custom hood .. and NO BODY LIFT REQUIRED .
I think I will be using the original upper mounts , and build some lowers .. not sure on the isolator yet ..
also at this height .. there seems to be lots of clearance on the oil pan .. I'm using the stock "push/pull steering" .. but if I were to go to crossover , I would need to change out the oil pan for sure ..
back to work !
CJM
04/06/08 08:29 PM
so .... wee progress .
cut a couple of pieces off ..
also the brake line mounts .
ready to go ... :)
so started working on the motor mounts .
after weeks of shopping , and 1/2 as$ looking around , I finally found the mounts I want ..
They are just perfect ... and exactly what i have been looking for .
They fit the original mounts ..
and "hang" exactly where I want .
I started on the frame side mounts , but had an issue with the press . ... so I had to stop here .
What I have , are the 20r,22r& re engine mounts ...................
I cut them to fit the angle of the frame , and the angle of the mounts ... ( paper cut-outs & tape)
I'm making a frame bridal/bridge now and got them all cut out .. and ---- no press ...
so had to stop there . untill I can fix it ....
CJM
04/23/08 08:46 PM
so progress .....
but is really any one interested ???
stock87
04/24/08 01:00 AM
so progress .....
Yes.
Emphatic yes.
There are those of us who one day dream of being able to fabricate like you.
*cough*me*cough*
kewlynx
(Toyota & Classifieds Moderator)
04/24/08 02:52 AM
Shoot, we're lovin' it. Don't kid yerself. It's more fun to step thru your pictures and watch it all come together rather than comment, esp with your expertise. Classic fab/restoration thread.
Staceman
04/24/08 10:09 AM
I'm with kewlynx!
Keep them progress pics and 'splainations coming.
CJM
04/24/08 10:45 AM
ok so ... update then :)
heres what I got so far .. I intend to add some gussets when I remove the engine to do the frame , but here's the "jist" of it .
also got a little delivery today .. :)
My NEW rad .. turbo 3row .
Fan is also ordered ..
Maradyne 16" excellent flow .. should work great .
also got to work on the drive shafts ..
started with the front ... hung the original 95 shaft , and no way , to long + the CV would not bend enough . So I decided to compare .
angles are WAY different and rather then shortening the 95 shaft , i'll use the earlier The 83 shaft .
you can clearly see the differance . (not sure on the 84-88 shaft , dont have one)
so now to line things up .
front flange works (of course , diff side) but the rear (transfer side) has the 10MM studs .. with just a few measurements , I found you could knock out the flange studs . and using the 79-83 8MM drive shaft bolts , it'll line up . I was worried about the differance in the 10mm original , and the 8mm 79-83 .. but if you look at the flange/flange , there should be no movement .
so .. now FRONT DRIVE SHAFT ON . :) , I may have to lengthen , not sure yet .. but it's on :)
rear was not so difficult .. just had to drill the flange . set it up , and drilled .
finished
and installed .
so NOW I can build my crossmember .
CJM
04/24/08 10:54 AM
started on the crossmember ..
started with cutting off the original mounts
also got some frame plates cut , and "placed " .
also got the "mounts" completed ..
then made a "trace" of the original mount holes , and cut the lower crossmember
BUT WAIT ... "says to self" ---- "self" .. better lay the header pipe in place to make sure everything will fit .
so I layed the "header" pipe where I thought it should be , had to watch out for the shackle clearance and such , and sure enough , it would have hit the crossmember .. so I think I have the crossmember figured now , but I figured I might as well get the crossover done , and in place first .
heres the pic of the cat , and the shackle clearance ... just for referance .
so I chopped up the old crossover ..
some guys have "re-worked" the old pipes , and expansion joint , I decided to go all new .
cleaned up all the old flanges , and put them in place ..
made a "template" of the first pipe , and ran of to get it bent . :)
trimmed it up , and cut it to fit ..
[size=2]the stick indicates the firewall [/size]
pipe #2
and pipe # 3
a little triming (a LOT of grinding)
and a tack here and there , and finally I can weld .
I talked to the muffler shop , and the pipe bender guy suggested staying with the original Toyota flex joint , as they are WAYYY better then the aftermarket ones .. so I cut it out , and re used it .
starting to weld ....
and fully welded ..
part of the reason for this excersize , was I really wanted to have the original heat shield back on .. and TA, DA ..
and some clearance pics ..
and water pipe clearance .
total price ... $30.00 + consumables , and my time .
now I can finish the crossmember .
CJM
04/24/08 10:58 AM
so back onto the crossmember .
tranny mount is there , and now time for the frame attachment .
cut some pieces , and cut and ground and bend .. and heres what I got .
welding
LONG shot ...
lots of fitting and drilling cutting and fitting
cut some frame braces ..
boxed in the mount
and got er' ready to drop out .. long shot
added the protector plate , and strengtheners ..
clearance ..
and VIOLA .. DONE .
next on the slate .. and just arrived today
Red_Chili
(Toyota Section Staffer)
04/24/08 01:59 PM
Just checking in... glad to see you are not using the Downey headers after all. Mine has the ORS crossover, and was the prototype for his production unit (mine was version 1, then version 2. Version 2 is a keeper). It is worth it, very labor intensive and well made.
But it looks like you have the equivalent.
The 3.4 fit in my engine bay with the drivetrain 3" forward, with the stock hood, 1" body mount, and 2mm of clearance. I elected to put in a scoop mostly for bling. Prior to the BL I ran a ventilated hood (hole ) ). The firewall clearance was TIGHT until the BL. Much easier to fiddle with things now.
CHANGE THAT OIL PAN. You want a T100 2WD pan. Move the dipstick.
I used a FRORF crossmember, clean and strong, but not compatible with the chain tcase of course. I am running an R151 but frankly I'd run the stock R150 now with a V6 plate to get the Marlin Crawlers adapted. The R151 is bulletproof, but doesn't shift as nice.
Lookin' GOOD.
[edit] oh, and POR15 Metal Prep is basically the same pickling mentioned, just more expensive. It works.
Staceman
04/24/08 04:49 PM
CJM
04/24/08 07:33 PM
thanks guys ..
I really wanted the heat shield on the crossover .. as far as I can see .. so far i'm the only one whom has acomplished this ? :)
on ward and up ward ..
Vanishing_Point
(Wheeler)
04/28/08 02:33 PM
I like your cross member. I have a similar idea with the trany mount.
CJM
04/29/08 08:34 PM
thanks ...
CJM
04/29/08 08:35 PM
ok .. so a wee bit of work in the last couple of days ..
got the front calipers in and ohhh!! boy .. they need some work .
heres what I started with ..
got em' all "blasted" and cleaned
and then "zinc 'ed " ,
now ready for some Caliper paint , and NEW Toyota Pads ... I think I wanna fit the rims first .. so well see .
also started again on the rear diff .. got it out and started pullin' axles to get on the rear discs ..
and ordered parts .....
CJM
05/02/08 12:45 AM
so continueing on with the rear , I cut off all the brackets I dont want to use
and started to "test fit " the rear calipers and brackets ...
also making some new brakeline brackets
welded the nuts
and got them ready to weld on .
also got the new fan in today , so .. got the front lower rad support cut out , and fan mounted
test fit the grill
and made a NEW lower support ..
I still have to make the center support , and finish welding , but this will hold it together for now .
CJM
05/02/08 08:34 PM
so continueing on .... on the calipers .. a little detail .
some caliper paint .
and ready for new pads .
also .. put on the new tie rod ends ..
and got it all aligned , and "temporaly" installed
Staceman
05/05/08 10:22 AM
Dang Cory, I need sunglasses to look at those calipers! Lookin good, keep 'em coming. What calipers are you gonna use on the rear axle?
CJM
05/05/08 11:07 AM
:) thanks ..
rears are Caddy calipers with the emerg. leavers .. I'm just fuguring the cable , and mounts out for that , then I will POR the rear axle , and put the calipers in the same caliper paint .
rear discs are being "cut" right now , and I have ordered the front toyota pads , and rear bearings .. so i'm just waiting for those now .
Red_Chili
05/05/08 03:49 PM
All that work... and no high steer?? Keeping the J-arm?
Staceman
05/05/08 05:51 PM
Keeping the J-arm?
Well, he did flip the ball Bill
Greg_Canada
(Roll Me Over)
05/06/08 12:09 AM
Hi steer, not with that low a truck.
he could still do low steer, maybe he hasnt thought of it yet... COREY!!!
bkg
(Roll Me Over)
05/06/08 09:32 AM
Hi steer can be done w/ less than 3" of lift as long as the drag link is positioned right relative to the frame and the tie-rod relative to the oil pan... and bump stops are set appropriately.
I've owned one. :)
Staceman
05/06/08 10:03 AM
C'mon guys. If this was my rig, I sure as h-ll wouldn't be taking through boulder fields. Nothing more than fire service roads thru the woods. Don't need no hi-steer for that, or dual cases, or exo.... see where I'm coming from??
bkg
(Roll Me Over)
05/06/08 10:15 AM
Agreed. I look at cross-over steering, in cases like this, an option for making the steering "feel" and "perform" better (quoted for a reason).
Red_Chili
05/06/08 01:34 PM
We are not talking rock buggy here. High steer (or at least a proper crossover steer) is simply superior in all applications. Dual cases and exo were not mentioned. Do you see where I'm coming from?
On IFS/SAS, true, you need lift to do high steer. Not so much on an SA truck.
Vanishing_Point
(Wheeler)
05/06/08 07:22 PM
The high steer kits are stronger, reduce bump steer, and offer better response.
CJM
05/13/08 09:31 PM
sorry for the delay in my reply ... Had problems logging in .
NO hi steer . I dont need it . With all NEW components steering will be just fine , + it saves me having to replace the oil pan , and relocate the dipstick .
CJM
05/13/08 09:47 PM
progress .. i'm waiting for the bearings I ordered , and the discs to be turned ... but I did get the backing plates finally pressed off .
so started with the backing plates , and started to strip off the brakes , and un-necessary stuff for the swap .
knocked out the studs that hold in the bearing retainer ..
and knocked off the backing plate ..
and got them all cleaned up ready for the POR treatment .
so finally got my rotors back ..
just for referance , rotors are for the /80's chev 6bolt light duty 1" thick .. (the heavy duty 1.3" thick wont work with the calipers ).
center hole has to be "bored" out to fit the toyota axle ..
so with that the new bearings
are "poped" into the bearing retainers
outer seal installed
and then pressed on to the axle .
axles are stuffed in , and rotors are installed .. calipers , and test fit of the pads .
and done ..
and back under the truck .
now to figure the emerg. cables ..
(calipers are on the wrong sides .. I have since corrected)
Vanishing_Point
(Wheeler)
05/14/08 03:45 AM
I see you like to use the zinc coat spray paint. Does that stuff hold up well to our northern winters?
CJM
05/14/08 10:47 AM
it does ... it works very well . my winch bar on me DD came off of my /80 (bought NEW from warn industries in /80)
in the mid /90's when I sold the truck , I kept the winch and bar .. by that time it was really starting to rust .. so I sand blasted and zinc'd .. and painted ..
this is the same bar not even repainted .. but a new winch
here in 2007 . top bar is rusting from the inside out , but other then that .. it still looks great . this is the main reason I use it .
Red_Chili
05/14/08 04:00 PM
What led you to want to use blocks of that height?
CJM
05/14/08 07:51 PM
space .. I need the space for the rear disc and emerg. leavers .
CJM
05/14/08 07:58 PM
so tacke'd up my hoops today ..
plumb bobbed , and leveled
also put the steering box in place .. to check clearances ..
connected up the drag link , and got it adjusted ..
all so I decided to brace the front hoops .. I have heard in some situations , they will tear right off the frame .. and I didnt want that .. so .. I'm also making some gussets , and will post em' up when i'm done .
thats about it .
Rauch_Off_Road
(Forum Moderator)
05/14/08 09:27 PM
Looks really good but I'm thinking you may regret the blocks especially with the 3.4. Why not do a Chevy swap using 1" or 2" lift springs? That way you could have a good ride and do away with the blocks. The way your building this truck its no problem to do it now rather then later.
CJM
05/14/08 10:08 PM
the blocks provide space for the emergency cables , and access to the caliper bolts , and adjustments .. as mentioned .. in this case , they are an asset
another build with out blocks
to close for my comfort , and there is NO room to adjust . to do any caliper "work" the axle must be dropped .. not smart in my books ..
on a personal note: I've ran blocks for 12 years in my 80 (pic'd above) .. 36" swampers , ARB's and 5:29's and kicker's .. I never had 1 issue .. not 1 .
I will run them again .
matts
05/14/08 10:31 PM
Maybe you already indicated is, but where did you get your rear caliper brackets? -- Matt
CJM
05/15/08 10:27 AM
there Sky's brackets .
Red_Chili
05/16/08 03:15 PM
the blocks provide space for the emergency cables , and access to the caliper bolts , and adjustments .. as mentioned .. in this case , they are an asset...
Granted, you need the room. Why not get the lift you need using springs/shackles of the proper lift? The rest of your rebuild/swap is of such high quality, it seems a shame not to.
Vanishing_Point
(Wheeler)
05/16/08 07:38 PM
With a traction bar(s) blocks are just fine in the rear. Tire size also plays a big role.
Are those Marlin Crawler shock hoops? If so short or tall and do they require cutting?
CJM
05/16/08 08:06 PM
it's not the "lift " thats the issue .. it's the space beside and under the spring .
The block allows access to the caliper bolts , and emerg. leaver , without having to remove the u-bolts , and seperate the spring and axle ..
with this set up (block) I can easly access ALL the bolts , and adjustment with NO problem ..
just imagine a rear seal leaking .. and having to drop out the whole rear end to access , sound like a good plan ?? I dont think so .
I am going with a "traction shock" like Rancho use to supply , not a traction bar .. I have found the shock to be much less harsh and allow just a little better "ride" .. I'm building my own , because they're no longer avaliable .
tires i'm going to run are either 33 x 12.50's or 35's x 12.50's
shock hoops are TG .. 12 " and supose to be NON cut .. they seem tall , and hit the inners .. but I dont have the cab on yet , so I dont actually know yet .
CJM
05/17/08 07:41 PM
so " buttened " up some loose ends today ..
cut 4 gussets for the front hoops , here's 1
and welded
also , wanted to finish up the new crossmember .. so I cut some pieces , and got er' all finished up .. I just need to do a center suport now .
also .. brake lines ..
got the new steel lines on , and stainless lines in place , and just tacked the line supports ..
CJM
05/22/08 08:38 PM
so trying to figure out the emergency cable and brake lines ..
first working on the emerg. cable . My final outcome .. is to have the stock cable hook up to a short extension .. heres the direction i'm going ...
I first found some 3/16 cable .. and fittings and such
with an idea in mind , I found a bolt to cut for cable retainers .
I drilled out the center of the bolt , and then cut it in to pieces ...
then [size=2]" V "[/size] grooved to top , an slid the cable up threw the center .. and welded
and "loosly" hooked up !
I checked with the GM dealer today also on the price of the return springs $50 bone each , and the secondary spring leavers .. only avaliable with the calipers .. yeah right :P so I decided to make my own ..
made a template for the bracket , and started cutting and drilling ....
and finally an install pic ..
[size=2]loose [/size]
[size=2]and clamped [/size]
so far so good ..
Red_Chili
05/23/08 01:49 PM
Interesting limitation to Sky's brackets. You've overcome them, but for many they would not be optimal.
CJM
05/23/08 09:04 PM
no .. rear discs arn't for everyone ..
EXPENCIVE to make work propperly (if you can fab on your own)
CJM
05/23/08 09:06 PM
a little worried the wheels wouldn't fit (REM sleep causes this)
so this morning I fit on my "shop tires" 8" wheels and 31's .. and clearances look good . ;D
also .. got some of the rear brake lines hung .. but am having a problem finding the "banjo" style fittings for my calipers .. help is appreceated !!!
CJM
05/25/08 08:19 PM
so I found the right lines !!!!
First I opened everything up .. and had a look .
I realized my previous "hanging " of the rear line was no good , so I started with moving the rear upper hanger .
welded , and re-bent the line .. I also added some posts for the line to bolt to ...
so with the line now loosly fit ..
I wanted to make the brackets fit my supports .. so I removed the crimping from the new lines , and started cutting and forming and fitting
and now a perfect fit .. and re-crimped back onto the lines ...
here in BC .. brake lines also must be supported with a bracket , and "C" clip ..
so I made some brackets ..
welded and [size=2]"C"[/size] clipped
and used the "domestic ends , and a small piece of line with the original ends on it .. double flared the ends , and done .
CJM
05/25/08 08:21 PM
small project today .. that now I can check off the list .. DONE!
Track bar was a little to short because of the lift , so I had to correct ..
Cut the main rod out , and also cut a new main bar .. notice the diameter differance .
all welded .. and you must be carefull to NOT burn the bushing ..
and installed ..
CJM
05/29/08 08:23 PM
ok .. so I know you guys arnt "keen" on the blocks ..
I ran them in my "white knight" for 12 years .. 36" swampers , ARB's front and rear , and 5:29's .. wayyyyy back in the early years .. so for this build , I'm usin em' .
anyway .. blocks work for space for the new rear calipers , and emergancy cables .
so to make the blocks work .. as on my old rig .. I built some "kicker shocks" there not as harch as a traction bar .. and still allow some movement .. but very limited , and "absorbed"
I first I cut out some brackets
welded them to the frame , with the MOCK-UP shocks in place
then I took the original u-bolt holder , and made some more brackets .. welded , and added some bump stops ..
and now I have a correction for the blocks , and " 0 " loss of clearance .
zachwrenchsr
(Need a Spot)
05/31/08 04:11 PM
Just wondering why you put the torque rod back in? I'm putting a lift in my 81 and same thing too short go figure!
I've noticed most lifted toyota's dont have it installed. There was a adjustable one on ebay for over $100. but why waste a bill or hasle with it when I see so many without one installed.
I also noticed were mine mounts to the frame there's some cracks have you seen this before? I'm new to the toyota (ex chevy guy)and you seem to know your way around one. Good looking truck thanks for sharing your project.
Vanishing_Point
(Wheeler)
05/31/08 09:30 PM
I'd replace the torque rod. I talked to a guy around town with a lifted '83 with 35s. He slammed on the brakes at 70 and the front axle wrapped so bad that the springs bent and he rubbed against a conrete divider.
CJM
05/31/08 10:43 PM
torque rod elimenates spring wrap on the front , VERY improtant .. you dont want to eliminate this on a "daily driver"
at slow speeds , offroad, rock crawler it's not necessary , due to articulation restrictions .. but on any insured driver , it is absolutly imperative you keep it .
removing it will affect braking , steering .. and a raft of other necessary functions .
fix it , and keep it .
zachwrenchsr
(Need a Spot)
06/01/08 06:26 PM
Thanks for such a fast reply I 'll be welding soon!Good bye heavy chevy's This little toyota's gona be helli fun!
Red_Chili
06/02/08 12:10 PM
If and only if you have the stock steering.
Mine (and most) is/are fine without it. Yes, DD duty. 80mph on the highway too, no issues.
CJM
06/04/08 07:44 PM
I wanted to finish up the rear bump stops .. so I unbolted the originals and removed
made some new "low profile" .. and installed
CJM
06/04/08 08:13 PM
started a bit of work on the rear emergency cable .
started with cleaning up some of the brackets , and making new ones ..
the main "swivel" mount was tapped . leveled and welded .
I picked up some 90* 's off the front cable , (on the firewall) 79-89toys from White Valley Collision
got them all cleaned up ..
I went to incert the cable .. for a test fit .. and found they wouldnt work .. the inner wheel was plastic , as well as not the right fit for the cable ... I didnt think the plastic was strong enough either ..
so I lagthed some new wheels ..
and now cable fits perfect ..
made the new mount brackets ..
braced and tacked into place ..
They seem to be good , although I do have about 1-2 mm of deflection .. I either need to brace them better , make some more supports .. or re-do the brackets in a thicker material ..
CJM
06/07/08 09:12 PM
so i'm basically FINISHED the emergency cables ..
I decided to weld in a support bracket .. I used the same 1" pipe I have been using for the other supports .. a little continuety .
They are now 100% with zero deflection ..
I also added 1 more support for the cable , didnt want it "rubbing" against the shock body ...
and now I just have to "crimp" the cables .. and done .
matts
06/10/08 12:09 AM
I'm surprised that you didn't choose Front Range Off Road Fabrication's Full Floater Conversion for your rear axle. Especially with a blown 5VZFE in your future plans. Not to say that I don't admire your work so far. -- Matt
CJM
06/10/08 08:36 PM
not necessary .. Toyota rear axles are larger then chev 1/2 ton ..
buddy had a 327/350hp in his rig (almost beat my Vett in a race ) ..stock toy axles and 36" swampers .. never a problem .. and I'm NOT that aggressive .
besides .. this rig is NOT a rock crawler , it will be a DD /tow rig , as I have stated !!
bkg
(Roll Me Over)
06/10/08 09:19 PM
Shaft diameter, perhaps, but not ring gear side...
Greg_Canada
(Roll Me Over)
06/11/08 02:13 PM
Full floaters arent gonna give you a bigger ring gear, tho... (i know you didnt say it)
Red_Chili
06/12/08 12:11 PM
He meant the ring gear end of the axle shaft. Toy ring gears compare favorably to Dana.
FRORF's full floater conversion would have been much stronger, cleaner, and easier to execute.
For a DD with a blown 5VZ.
bkg
(Roll Me Over)
06/12/08 03:46 PM
My bad - typo. I mean to say that the ring gear itself is larger than a Toy.
CJM
06/12/08 09:00 PM
toyota alles are just as strong , if not stronger then the Chev 1/2 tons . axle sizes between the 2 are basically the same , but the chevs have a "narrowing" near the end of the axle .. creating a weak point .. Toyotas dont !!
Ring gear here , being the STOCK 4:10 ratio , and lots of "beef" should hold up excellent to the horsepower .. ( 280 est. with the supercharger we'll see)
Full floaters are obviously stronger , with load sharing at the disc end .. I just couldnt justify the price !! shipping and all adds up .. just like when i'm sellin' my stuff .. same sh!t differen product .. http://toyotafiberglass.com
yotaman7
(Wheeler)
06/12/08 09:59 PM
CJM, awesome post. Just wanted to say thanks for postin all the great pictures and descriptions. The fabrication is awesome as well. Good luck with it.
CJM
06/12/08 10:28 PM
Thank you ..
CJM
06/22/08 11:37 PM
not much to add .. started the POR treatment ...
driveshaft washed .. then de-greased .. washed again . "metal-ready" prepped , and washed as per instructions , and then the POR-15 .
bkg
(Roll Me Over)
06/23/08 08:51 AM
Interesting POR-15 story...
was swapping out brakes this weekend from an old set of knuckles to the T. Rather, I tried. Rust got in the way.
I had POR-15'd the knuckle, steering arm and everything but the disk brake dust shield (which was powder coated) back in 1996. These parts have seen about 8-9 winters of use since then.
The POR-15 areas were still "black," but they were pealing like skin after a major sunburn... The powder coaded pieces were great.
CJM
06/23/08 10:19 AM
hmmm .. I hope i'm not wasting my time .. I only have 5 years on a previous frame coat , and so far no problems
did you do the wash, clean , metal ready ... ect.. steps ?
bkg
(Roll Me Over)
06/23/08 10:32 AM
I think it might work fine for you... might not, I can't say.
I spent over $350 and numerous hours prepping that dang 4Runner. I POR-15'd everything. Scrubbed it clean, washed, cleaned w/ the POR-15 cleaner, Metal Ready, then POR-15 when the parts were ready. Used two coats, even.
I've just never had good luck w/ it. Others swear by it. If it were me doing things again, I'd blast, etch prime, prime, paint and clear coat everything. But I'm a glutton for punishment as well. :)
Greg_Canada
(Roll Me Over)
06/23/08 04:10 PM
I POR'd my frame when they were saying "right over the rust" so i cleaned it up decently and brushed it on.
First winter, i went to powerwash the frame and the stuff came right off (i powerwash my frame every week in the winter time)... from then on, i just put a layer of tremclad on every year....
CJM
06/23/08 08:46 PM
well in my experiance ...
I have had no problems . there is a procedure .. and I guess I will let you all know in about 5-9 years on how this coat goes :)
CJM
06/26/08 09:07 PM
diff .. and extras ..
springs are in the works .. and soon the frame ..
CJM
06/27/08 08:48 PM
springs are done ...
If all goes well ..I'll have the frame done this weekend .. :)
CJM
06/28/08 08:16 PM
springs ..
but there is no way I'm doin' the frame this weekend .. it's 36* C (about 90* F ) outside .. so I'm goin' to the beach ! .. :)
CJM
07/07/08 07:46 PM
so a wee bit more progress on the POR treatment ..
and I have started to "BLOW" apart the suspension .. so I could get the frame done
.. when FINALLY .. look what shows up ..
my new fuel tank ..
it's a bolt in .. and will accept the 84-89 EFI fuel pump bracket .. (mine needs a new pressure tube ) but it's all bolt in ..
yotaman7
(Wheeler)
07/08/08 09:55 PM
Tank looks good. Where did you get it from and what did it cost?
CJM
07/09/08 09:17 PM
I am now the distributor ..
http://www.toyotafiberglass.com ..
this paticular tank was $275.00 .. but it is one of the more " expencive " tanks .. it's not on the site yet , so just refure to this post .
CJM
07/09/08 09:19 PM
dont know if you can see in the previous pic or not .. but the pressure line on the sender is gone .. and the other pipe is rusted .. so
I had to fix .
I drilled out the old pipes , and started to manufacture my own .
The /84 holder didnt fit as "perfect" as I wanted .. so I bent the fuel pump holder , and fit .. bend and fit .. now it fits exactly where I want .. and to go with it .. new pipes .
bent up the PRESSURE pipe ..
and the return line
saudered , zinc'd and installed ..
Vanishing_Point
(Wheeler)
07/09/08 11:10 PM
Same way I did it.
matts
07/09/08 11:50 PM
Nice work on the pump bracket. When I converted my '84 pickup to efi I went with a new tank (made in Canada), but my 4runner donor vehicle had a different pump bracket to match the differently shaped tank. I had to pay around $112.00 for the new bracket, but they use the same pumps so nothing extra for that. I was worried about the tank and corrosion, but it seems that they finished mine with some kind of plating that is similar to galvanizing. I coated the thing with spray-on rubberized undercoating for an extra measure of protection. I'm pretty sure it's gonna outlive my truck. -- Matt
Vanishing_Point
(Wheeler)
07/10/08 07:37 PM
Gas eats rubber undercoat pretty quick, so watch for fuel leaks.
CJM
07/12/08 07:58 PM
so frame is stripped again , and going for the final welding , and POR-15 treatment .
to today , I got the frame ALL welded ..
topside ...
and bottom side ..
rolled it out side , and got the washing ... drying ... degreasing, rincing .. degreasing .. rincing .. and washing again ..
and now I think im good to go ..
dragged it back in .. and did the "metal ready"
just another rince and dry tomorrow , and its ready for the POR -15 ..
CJM
07/17/08 08:05 PM
got the frame done today using my "gun" and a small paint brush ..
2 wands .. first is a rotating 360* "V" notch . Second is a 90* rotating .
I'm VERY happy with the way it came out ..
CJM
07/18/08 07:11 PM
got another little surprise today ..
I sent the flywheel out for resurfacing .. and just got it back ...
when the UPS man shows up with my new F1 Racing stage 1 "organic" clutch .. it's rated for 280HP .. so with the supercharger , it should be good .
CJM
07/22/08 08:26 PM
so started putting it all back together ..
all new hardware , or cleaned and zinc'd
also got my shocks today ..
so had to get them installed .. loosly .
Talon84X4
(Rock Warrior)
07/23/08 05:14 PM
That is one cleeeeeeean build. Looks great, i'd love to do a frame up build someday. I think a t-case e-brake may have saved some time and maybe headaches as well dealing with the discs on the rear. Love the build and great work.
CJM
07/23/08 08:55 PM
thanks ..
I'm not one to "buy off the shelf" .. I like to be just a little different , and with all the rear discs out there , I just wanted to show something different . I'm glad I did the emergancy brake the way I did , It's a "1 off " .. and will work for years to come .
Talon84X4
(Rock Warrior)
07/24/08 12:54 AM
Very understandable, I like to build my parts as well.
CJM
07/30/08 08:51 PM
so not much to add today .. but a bit ..
dropped the engine back in place , and started on the transmission .. and clutch .
blasted the fork to check for cracks and such .. , and then zinc'd
on this swap , you will need to use the 3.0L throwout bearing ..
greased the fork , and inner bearing surface , and installed .
installed the pilot bearing ..
the 3.4L clutch installed ..
with these kits you get a "goofy" plastic alignment tool .. but I like to use my own .. an original input shaft .
and finally the tranny back in place ..
also mounted the starter ..
on the bottom mount of the 3.0L belhousing .. it is threaded .. so is the starter .. you I had to drill the threads on the starter so the bolt would go threw
very simple
Bent_85
(Getting the Wheeling Fever)
07/31/08 12:33 AM
Great progress! Excellent Post!
Just thought I'd throw in my 2cents.
CJM
07/31/08 10:27 AM
Thank you .. I appreceiate your comments ..
CJM
08/05/08 08:26 PM
re & re'd the ATM wire harness , for the MTM harness ..
also installed the front shaft .. had to remove the transfer flange because it has 10mm GRD11 studs , and stock 83 is 8mm .. so same as the rear shaft , I had to drill .
also mounted the front of the exhaust again , to get ready to build the rear ehaust pipes , and muffler ..
also fully mounted the fuel tank , and installed senders , and pump for good ..
I think thats it ..
Pyroboy
(Mudrunner)
08/07/08 03:40 PM
Looks good, Corey!
CJM
08/07/08 09:07 PM
thanks ..
hope you had a good time when you were here ...
CJM
08/09/08 06:48 PM
thought i'd post some progress pics ..
as of today Aug 9th 2008
just working on the "plumbing" getting the fuel lines bent up .. , almost done .
CJM
08/15/08 10:43 PM
started the teardown of the original 4runner the harness came out of ..
My therory here is to strip down the harness , and use what I can ..
from the "cut " ( as seen in ths pic) on the end of the trailer .. I'm going to use the original harness - some un-needed weight .
I also have the new booster , and brake master , and clutch master ..
i'll get pics tomorrow ..
CJM
08/16/08 08:11 PM
so as promiced .. the complete wire harness ... i'll bet this sucker weighs in @ 50lbs !!!
dont know what i'll be using .. but I wanted it in one piece ..
same here .. I know I will be using the booster , and brake master for sure .. but the rest , well ........ we will see .
and finally the front clip stripped .. and off to the recycler
CJM
08/23/08 07:06 PM
so with family here for some holidays , and the shop being stupid busy , I havent gotten much done .. but every little bit , is a little more done .
I was working on the harness today , and got lots of it stripped ,
hooked up most of the connections , and tagged what I new .. and started cutting some of the non-ecentials , that I wont be using
and what I have cut out so far .
I have a few connections , that I have no Idea about (I didnt dissconnect).. so I'll have to do some research to figure out what they are .
CJM
08/25/08 09:47 PM
so finally finished the harness , and set it aside for now .. I know I have more to cut out .. but dont want to do it just yet , as I'm hopeing to incorporate the systems into the Trekker . I also need to get some more pieces from Daren (White Valley Collision) , as there missing from the original purchace .
and what I have cut out so far ..
I didnt weigh it , but I should have .....
I'm now ready to put on the cab .. then I can route the wiring some what , and fire this baby up ..
but to do that , I now have to tear apart the original Trekker body ..
CJM
08/28/08 10:43 PM
so how about this :
I'm thinkin' it's time to get that supercharger on order .. as i'm almost ready to fire up the engine ...
so I called my "old dealer" (one I use to work a " TRD DEALER " ) and went to order the new Supercharger ..
apparently , they got an email ......TODAY .... , saying that Toyota Canada was NO longer supplying TRD pieces in Canada ...
yeah great .. now what ?
Knucklepin
08/29/08 09:22 AM
Well, there may no longer be any TRD pieces in Canada.........but at least you still have Rush
CJM
08/29/08 11:00 AM
hahaha ...
so I checked into having one shipped from the US , and with all in , adds about a grand to the purchace
so I guess i'll be waiting , and hopefully the to "girls" can get things straightened out .
CJM
09/01/08 06:40 PM
so I buttened up the fuel and brake lines today , and added the filter ..
I ACID dipped the line brackets , as much easier then sand blasting every one
bolted it on
an got the line run perminent
philly
09/02/08 11:36 AM
everything is lookin great in this build. i am really looking forward to seeing it when its finished. keep up the good work!
CJM
09/02/08 08:47 PM
thanks ....
RatLabGuy
(Rock Warrior)
09/02/08 10:47 PM
yeah great .. now what ? .
So, clock may have ticked too long.... but I'm curious...
what would happen if they were to "accidentally" order something?
Aeound here, one can often find/make a "buddy" working at the dealer whom might, say, for a couple of beers and a game of darts/pool/poker, accidentally "forget" to read their email every now and again and, oops, had already ordered the part for a good long-time customer... boy surely we wouldn't want to lose the patronage and word-of-mouth compliments of a well-known customer, eh??
Greg_Canada
(Roll Me Over)
09/02/08 11:07 PM
so how about this :
ACtually Corey, your main problem is that Toyota no longer sells the 3.4 superchager BRNAD NEW... the only new one you can get is from a dealer that bought alot and has overstock. TRD no longer sells them (or so i hear).
I can get TRD products around here no problem, wonder why you have so much trouble...
BTW Looking good!
CJM
09/03/08 08:40 PM
actually no .. TRD still sells the supercharger , brand new.
thing is ....
Toyota Canada had a DEAL with TRD to import into Canada , and distrubute threw the Canadian dealer ship network . The dealers had to "buy in" at a cost of ~ 15G stock there stores in able to supply TRD to there customers .. this was the agreement. so now only CERTIAN dealers are offical TRD suppliers here in Canada.
now Toyota Canada and TRD are having difficulties .
I do realize I can still order , and still get from most dealers in The USA .. BUT
problem is .. the cost , I use to be able to buy (MY COST) $2200.00 delivered to me .. If I have to import myself , best deal I have found so far is $2400 USD + shipping + broker + inport fees + Taxes ..
by the time it's landed to my door , it'll run ~ @3400.00
I'm gonna wait , and hopefully I will find the right deal .
CJM
09/03/08 08:42 PM
thanks .... but
no stock in Canada .. so it will get cancelled .. already tried :)
CJM
09/03/08 08:43 PM
little shipment today ..
all new hardware , neversiezed and installed , " torque'd to spec "
philly
09/04/08 10:25 AM
whats that shock for along the leaf spring? looks like some type of traction bar. but wont it still twist
IceBlueT
(Mudrunner)
09/04/08 01:42 PM
look higher in the post. he explains it.
CJM
09/20/08 07:57 PM
started to tear down the original Truck today .. finally .......
got it up to the bay doors .. My son , and his buddys started to clean out the rear .. lots of crap stored in there ..
and cleaned out ..
I was very anxious to see the condition of the rear seat , so that was second on the list ..
I was at the front , and was looking at the front passenger seat , and noticed a [size=4]leaver[/size] .. so I pulled it , and to my surprise .. COOL the seat flips forward , to allow the rear passengers room to get in
you can also see the backs of the front seats are covered .. and also , with the seat folded flat , you can see it makes the floor flat .. this is the "Q" for the seat deleate panel in the 84-89's , how [size=4]cool is that !!!![/size]
I had Brayden jump in , and I had him pull up the seat ..
It's absolutly perfect .. no rips , tears .. nothing .. only the seat belt impressions .. other then the rust on the steel , it's an absolutly awesome shape .. :)
and from the back (seat folded up )
how cool is that ?
so continuing on ...
the boys got the windows out
and that was about it for them ..
I "cut" out the roll bar , as the one side was rusted completly threw
and then had to grind the bolts off the trim panel , to start the interior strip .
once I got those off , I could pull out the sides , and the headliner ..
and thats it for today ... :)
CJM
09/21/08 07:02 PM
so some more today ...
basically got er' stripped .. front and rear seats out
and carpet , and interior
and now just a shell , and ready to come apart ..
looks like im going to need a whole new floor though ..
Pyroboy
(Mudrunner)
09/21/08 08:52 PM
I usually ship my parts to a U.S. UPS store near the border and bring it across myself. I have only ever paid PST & GST on parts, regardless of where they were made, although technically, you should pay duty on parts made outside North America.
If you bring it across yourself, there are no customs or brokerage fees. With used parts, like the diffs I got, the border guys usually ask a few questions and wave me through, no charge. If you're stuck, PM me. Maybe I can help since I live a mile form the border.
CJM
09/27/08 08:23 PM
today , we got the roof off .. finally
what a job .. there are tons of screws holding them suckers on .. WOW .
Brayden cutting the rivits , and elevator bolts
seperating the roof
and finally removed ..
and the dirt packed into a leaking seam ..
and the bottom edge of the topper ...
also got the doors off , and my apprentice , started cutting off the running boards .. They were so rusted , there was just no other way ..
his buddy also showed up , and started on the other side ..
we got er' done , or should I say , they got er' done , while I closed the box install with my customer "Chad" .. and then brought another 4Runner (Andrews) Complete in to the shop , starting Monday ..
Tomorrow .. Brayden and I are going to try to get the rear tub and fenders off , and also the cab ..
matts
09/28/08 02:52 AM
How are you going to fix that floor!!? Are you going to fab all new sheet metal or cut some sections out of a donor vehicle? -- Matt
CJM
09/28/08 01:32 PM
well so far the plan is ...
I cut out the floor section of an old box I had .. because of the ribs .. so i'm going to see if I can use that .
other then that , i'm not sure yet ..
Greg_Canada
(Roll Me Over)
09/28/08 08:37 PM
I know toyota sells floor panels for 84-89 4runners... maybe you can get one for an 83 pickup?
CJM
09/28/08 08:48 PM
really ? .. I didnt know that ..
I will check it out ! ..
CJM
09/28/08 08:51 PM
so my weekend is done now .. with 2 more jobs booked into the shop this weekend .. I dont know when I will ever be able to get back on my Project !!!
but anyway ..
heres what I got done today .. SUNDAY .
sides are off ..
I'm saddened by the rust I found , but should be an easy fix
and now finally with the tub off
I can finally get the cab off ..
and with a little work .. off it comes ..
and so now I'm ready to get it "set" on the new frame , and start this puppy up .. :) :)
RatLabGuy
(Rock Warrior)
09/29/08 10:21 PM
Nice to see your helpers wearing not only safety glasses, but hearing protection as well.
That way they still have it to get blown out at a rock concert, lol.
CJM
10/15/08 07:57 PM
not much to add ... but every little bit is a step forward ..
has a moment ... so I was able to "knock" off the original sound deadner in the cab .. If I can find a flat bed trailer , I can send it off to sand blast ..
CJM
10/20/08 06:53 PM
so with the floor now cut out ..
I started to cut out the rest of the rust ....
VERY happy with the out side rockers , no rust at all !
so I have now started building it back up ..
couple of small pieces .
CJM
10/23/08 08:25 PM
got a bit more done today .. sandblasted the inside of the rocker , and zinc'd ..
also got the seatbelt rienforcements in place ..
and with all the pieces now cut out , I started to weld er' all together
just have to "dress" the spot welds and one side is ready for the floor :)
CJM
10/30/08 01:06 AM
did a couple of hours tonight .. got the cab mounts bent up , and welded ..
and kind of what they will look like ....
also . did a little more cab repair ..
welded in a new little patch ...
cut out the new piece , sand blasted ther inside , and zinc'd ... and welded .
CJM
11/05/08 07:22 PM
so a wee bit of work the last couple of days .. and I believe I have finally got the drivers outer rocker done .. so now I can do the inner .
cut off the old rotten fender mount ..
cut the new/used one off my parts truck (already done a while back) sandblasted .. and then fit .
and welded
also made a little patch for a weak spot on the rocker
and now I can fit the inner :)
matts
11/05/08 10:34 PM
Kent White, aka, The Tin Man and owner of TM Technologies is one of the premier auto restoration master craftsmen in the world. What Corey is doing with this Trekker is in the venerable old tradition that Kent promotes at TM Tech. I suggest that if readers like this kind of craft that they check out the videos, live workshops and tools available through TM Technologies. If I was younger I'd make this kind of stuff my life's work. I might anyway.
I'm not in anyway connected with TM Tech or Kent White, except that I admire what he has, and is, doing to preserve the fast disappearing art of the metal man.
Keep up the good work Corey. -- Matt
masheen
(Need a Spot)
11/06/08 11:28 AM
My frame has a rust hole in the EXACT same place above the front leaf spring mount on the passenger side rear. Anyone else have the same issue? Is there a design flaw that causes this to happen? By the way, great job you're doing!
CJM
11/08/08 07:55 PM
Thanks and pretty common on that area of the frame .
CJM
11/08/08 07:56 PM
so now the outer is done on the drivers side .. time for the inner :)
got the upper support welded and started on the lower and seat belt support
and finally the inner rocker skin
also got all the welds "dressed"
and also got a little new piece today ...
just need an "extension" on the stock pipe , and I can install the mufler :)
Greg_Canada
(Roll Me Over)
11/09/08 12:00 PM
ewww why a flowmaster?
CJM
11/09/08 01:55 PM
why not ?
RatLabGuy
(Rock Warrior)
11/09/08 05:48 PM
why not ?
Some people don't like the tone, especially on a 4cyl.
However, w/ your drivetrain plans i think it will sound nice.
CJM
11/09/08 08:17 PM
yeah ,no 4Cyl in this piece , supercharged 3.4L V6 .. and I think it'll sound great ..
a little louder then most would like , but.. I'm and "old school" and dont mind some "tone" ............. foo!
Greg_Canada
(Roll Me Over)
11/10/08 01:01 PM
It's also the worst flowing aftermaket muffler out there... creates alot of unwanted backpressure...
they are tough as nails tho....
CJM
11/10/08 09:10 PM
stats ? .. as far as I know , they are a free flowing /minimal back pressure muffler .. it's what I have read anyway . only down issues I have read and heard on wave files .. is there loud .. but' i'm likin' the noise ..
Greg_Canada
(Roll Me Over)
11/11/08 08:32 AM
Here's a chart for you.
http://www.dynomax.com/products/ultrafloweld.html
i believe it because the dynomax is a straight through design and the flowmaster has lots of baffles to create the sound.
zachwrenchsr
(Need a Spot)
11/19/08 01:46 PM
I am also surpized to hear toyota has floor pans for sale for 4runners. I ve seen aftermarket for FJ's almost the same as jeep pans not much to them.
CJM
11/20/08 08:46 PM
Toyota has NO floor pans avaliable ..
Greg_Canada
(Roll Me Over)
11/20/08 10:44 PM
Why do they offer them then?
CJM
11/21/08 08:27 PM
they dont ... well maybe we should clarify !!!
on the 4runner rear "box" floor area and rear passenger seat pans are avaliable .. but for the front of the cab , under the gas pedal and mid cab mount area , they are NOT avaliable . They do show a picture of it in the EPC , but NO prefex # to order front floors .
if you'll send me your serial # (4runner) .. I will post the EPC pic .
CJM
11/27/08 08:48 PM
so I was able to work a bit on the trekker last night .. Because of rust issues with the drip rails .. I decided to cut them off .. and so started to cut the rails off .. had to do this in sections , and tack it , so that the roof wouldn't "pop" off :)
and with it fully removed
and just about finished 1 side
Greg_Canada
(Roll Me Over)
11/27/08 10:50 PM
Nice.
I was SUPER close to do doing that with my 4runner, but didnt want to spend the extra cash... should look great....
CJM
11/28/08 08:45 PM
thanks bud .. smoooothie cowl is next on the list ..
CJM
11/29/08 07:40 PM
little more progress .. and custom touches :)
because the 3.4L 's intake is on the battery side .. I had to remove the old battery trey .. It was a little rusty anyway , so it was an easy decision
and started "plugging" and grinding all the NON-ecential holes ..
also .. cut out the vents .. for a "smoothie cowl " ..
just about done , and ready for sandblasting ...
CJM
12/04/08 12:39 AM
cab is finally back from the blaster ..
and "clamped" .. and ready to weld :)
CJM
12/10/08 06:44 PM
got one side on the back done today ..
cut out the rust and made some patches
made a new panel
and all welded
Greg_Canada
(Roll Me Over)
12/11/08 10:35 PM
Damn, i'd hate to know what i would have to pay to get all that work done...
RatLabGuy
(Rock Warrior)
12/12/08 04:59 PM
Is it just me, or will about 25% of the steel on this truck be new welds?
You must have the worlds best memory to be able to get it all back together after taking it that far apart...
I took about about 100 pictures and made around as many labels just removing/re building my engine.
CJM
12/12/08 06:49 PM
lots and lots :)
well I've been building toy trucks (exclusivly) for about 28 years now ... I kind of just know I guess :)
CJM
12/12/08 06:50 PM
back at er' today .. and got the other side done ..
also got most of the cab sanded ... and ready for some epoxy primer :)
zachwrenchsr
(Need a Spot)
12/13/08 05:38 PM
looking great! I have floor issues on my 81 hope you post some good pics on the floor repair/install. I m sure it wont be made of street signs.
CJM
12/13/08 07:40 PM
THANKS .. and NO ..... NO street signs here !!
CJM
12/13/08 07:40 PM
some epoxy primer today :)
yippie .. it can now go onto the frame , and I can get on to building the floor .
matts
12/14/08 06:59 PM
I was just thinking, the other day, that I have turned just about every bolt in my '84 truck and even put new metal into my frame. I'm nowhere near the master of this stuff that you are, but it made me think that it's a good thing to have this kind of knowledge and familiarity with a machine that you use everyday. Much better than going down the road without a clue. My plan is to stick with the second generation truck and a first gen 4runner and work them until I'm dead or they are outlawed
CJM
12/14/08 08:32 PM
kind of my Idea as well ... stick with what you know .
kewlynx
12/14/08 10:15 PM
Mad, mad skills Corey, we can't say it enuff!
CJM
12/14/08 10:30 PM
tks M :)
CJM
12/15/08 08:38 PM
cab on !! :)
yippie .. now I can start on the floor .
everything fits awesome , and I'm very happy .... EXCEPT only 1 problem .. well not really a problem , but they arnt what they say !!!!
the TrailGear hoops I got , say "Our Medium Hoops will accommodate 12" shocks without cutting the inner fenders"
this is not true .. because of this , I will now have to add a 1" body lift .
so 1" body lift .. and all is extra good ..
good clearance on the cross-over
and a test fit of the STOCK hood :) . oooo yeahhhhhhh !!!
stock87
12/16/08 01:01 AM
OK, I'll bite. Why do the floor with it on the frame? Is it because it will require some custom fab to clear the swapped drivetrain?
CJM
12/16/08 10:08 PM
that .. and just want to make sure it fits .
trcdrunner
(Mudrunner)
12/18/08 06:10 PM
MAN O MAN... my wife just had to smack me, cause I was drooling.....
That is one sweet ride!!!!
CJM
12/18/08 08:31 PM
CJM
12/18/08 08:31 PM
and body mock up ...
yotaman7
(Wheeler)
12/19/08 08:09 PM
Lookin freakin awesome! Do you plan on replicating the orginal graphics like the side stripes and "trekker" on the back?
CJM
12/19/08 08:39 PM
yep .. I think so ...
except the part on the back that says "made buy winnabego"
i'm thinkin' "made by toyotafiberglass.com"
CJM
12/23/08 09:22 PM
so with the holidays apon us ... and Me booking "lightly" in the shop ... I had some time to work on a few things ..
muffler I bought a while back I fianlly got it placed ..
I hade to get a small "extension bend" to get it where I wanted .. but it's now in place with a hanger .
also acid dipping some small pieces ...
CJM
12/24/08 12:31 AM
so a little bit more
got the cab mounts .. "fit" .. + 1" body lift to clear the TG hoops >:(
had to cut , and drill .. and zinc .. but finally "tacked" .. and cab is now sitting on it's own ;D
now ready to "mock" up the floor .....
CJM
12/24/08 07:37 PM
so a little bit more today .. :) working on the floors .. made some templates first .
and transfered them to steel
cut them and fit them
also started on the tranny tunnel pattern
RatLabGuy
(Rock Warrior)
12/24/08 08:51 PM
What's wrong with the tranny tunnel you have? is there some fitment issue w/ the replacemnt tranny? i'd think the (unplanned) 1" lift would help that.
And - are you concerned about noise and/or fitment issues w/ the homemade floor pans being so flat, as compared to the original?
CJM
12/24/08 09:50 PM
I'm using the original tunel as a "template" only .. I will not be reusing it ..(as you can see in the pics).
old one wont work , just simply be Kuz I said so !
I'm still in the process of building .. so please be patient .. I still have to add some corragation , or bead roll for strengtheners to stiffen up the floor .. I will also have to build some "plates" undernieth .. I still have a ways to go ....
but I apprecieate your comments .
CJM
(Body Damage is Cool)
12/31/08 08:21 PM
so more work on the tunnel , and a solution to the cab floor , and Trekker tub connection .....
so now with the basic "mock up" of the floor and tunnel , I can now cut the floor of the tub and build a deeper floor for the rear seat passengers
and starting a new fiberglass tunnel (templating from my new tunnel)
one issue , maybe ............ I cant find anyone in our town with a plenishing hammer .. so no floor corragations .. I guess we'll see how it goes .
Pyroboy
(Mudrunner)
01/02/09 11:49 PM
Corey,
Looks great! How will you make the transition from the steel to fiberglass floor?
CJM
01/03/09 12:12 PM
Re: sold the first one .. so this ones mine ... Trekker Build
thanks .... there will be a crossmember undernieth for support , and the fiber floor is then bolted (originally screwed) and sealed to the metal floor .
CJM
01/03/09 08:37 PM
and NOW ..... the fun begins :) ------ check it out ---->
cut a hole in the firewall .. and started some connections
Greg_Canada
(Roll Me Over)
01/06/09 03:59 PM
I'd let you use ours... but... couple thousand km's away! lol...
why not buy a bead roller? I dont think they are TOO expensive... are they?
CJM
01/06/09 08:29 PM
bead roller wont do 14G .. I didnt relize this when I first posted !! .. but I know now .
Greg_Canada
(Roll Me Over)
01/07/09 04:57 PM
Also, you know it isnt too difficult to build a planishing hammer? Ours we used 4x4 tubing, a long barrel air hammer, some die's and a foot actuated valve.
CJM
01/07/09 08:41 PM
my neighbor (landlord) has one sitting in the back 40 .. I think this year , I'm going to get a metal shop going .. building some "specific" metal pieces ...
CJM
01/07/09 08:42 PM
couple of progress pics
engine compartment "mock up" continues ... Rad installed , starter is now wired as well as the alternator .
and more floor space ............
and also dash cluster "mock up"
RatLabGuy
(Rock Warrior)
01/08/09 12:27 PM
Man, all that nice touch and clean up udner the hood - I'm really surprised you didn't repaint that brake master cylinder, it really sticks out now.
CJM
01/08/09 08:38 PM
please dont forget this is all "MOCK UP" ... there is NO WAY i'm usin' that rusty ol' master ... come on now , you know me better then that !!!!
I'm just getting an idea of where things go .. drilling holes , and mounting "ecential" 5Z pieces into the 22R engne bay . MOCK UP ...
This will all be torn apart again .. even the cab will come off again for final welding , and prep . this is just an excersize .
trcdrunner
(Mudrunner)
01/09/09 05:50 AM
Am I seeing thoughts of a 'glassed dash???? if so any other thoughts for the other componets (Air vents/Gauges/Switches)
hhhhhmmmmmmm
CJM
01/09/09 09:15 PM
hhhhhmmmmmmm
keep em' guessin' and they will return
CJM
01/10/09 02:10 AM
ok .. working away ..
and 1 thing on the list to get done was the lower rad to engine connection ..
with the new turbo 3 core rad , there was only a wee connection between the engine and the rad .. so i ended up cutting about 3 " off and welding a "new" lip ..
and installed .. sorry .. not a good pic .
now a simple 90* to connect ..
CJM
01/11/09 08:23 PM
for those of you whom have commented about the "rusty" master.. I thought I would get to the real replacement ..
2000 4Runner duel diaphram booster with the 1" master , and clutch master ..
the clutch master is close and actually touches in 1 spot .. I'm going to correct that when I pull it a part .
because of the size of the booster and the length of the studs , the original spacer is not usable . also installing the booster with the stock steering shaft the u-joint at the fire wall hits the booster .. so in order to accomplish the booster install , I pulled out a spare /84 shaft I had from my 2WD project .. the shaft has a ball socket , instead of a u-joint , making the "connection" much smaller .
swaping the whole steering column is not possable because of the mounting points
[size=2]79-83[/size]
[size=2]84-88[/size]
unbolting the lower column housing and "swaping"
the floor mount for the 83 dosnt fit the 84 lower .. so I have to "open" it up a bit ..
and with everything back together .. I now have "VERY" large brakes :) and should be able to "stop on a dime"
Greg_Canada
(Roll Me Over)
01/11/09 10:41 PM
This should be the nicest trekker ever on the road when it's done.
I cant wait to see it
CJM
01/13/09 10:45 AM
needed a battery tray for the drivers side .. so I made one ..
not welded to the cab yet as I need to do some finish bracing .. so I'll wait untill I pull the cab off to do the final welding ..
also started "prepping" some mounts .. getting some pieces in there final location ..
fuel canister is "mocked up" cut some metal out for the perfect fit under the hood ..
shouldn't be to bad as , i'm not using a "flexy" suspension .. I doubt I will ever "touch" this mod with a tire .. I know I could run the "round" type fuel canister .. but I didnt want to .
CJM
01/16/09 07:59 PM
made up some brackets and finally got the fuel canister mounted ..
and also the fuse box
also started on the gas pedal . the original 83 was toast .. as with most of them the hinge that mounted to the floor was rusted and beyond repair .. I didnt want to use another "floor mounted " pedal ... so I made my own
heres where I started
the bolt patterns are different and positioning is also way different , so they are NOT interchangeable .
I started by cutting the pins off of both pedals ..
first I cut off the /83 pin and welded it to the 2000 shaft .
then for the tension spring I used the post fron the 2000 , drilled a hole for the spring , and welded it to the /83 bracket .. sand blasted and started to put it back together .
put some zinc , and then some color and mounted ..
I had to drill new holes for the throttle cable and will weld up the old ones when the cab comes off for final welding and engine bay paint
CJM
01/25/09 08:41 PM
progress has been slow as of late .. My shop is going threw some growing pains , so not much getting done threw out the week ..
but this weekend , I was back at er' ..
getting everything labled .. it's comming !!
also , checking the fuse box on the drivers kick panel .. and there really isnt much room ...
so I'm going to build a specific box or "french" the fuse box
RatLabGuy
(Rock Warrior)
01/26/09 10:43 AM
I really do not envy you on that wiring job...
CJM
01/26/09 10:53 AM
it's not fun ... the manuals are not as good as I thought , wires posted in different areas , I have even run into different color coded wires then listed , I know it's me and not the manuals , but jeeeezzzzz ... I have little hair as it is .
looking back , I should have just stayed with the original harness , but my delema with that is that it was 25 years old ! so in the end I think it will be worth it .
Greg_Canada
(Roll Me Over)
01/26/09 12:33 PM
I'm so glad i bought the ORS swap harness and brand new engine harness for my 3.4 swap.
CJM
02/07/09 08:29 PM
finally got a day off to work on my truck :)
and got the brake lines done and clutch line ....
all the brake lines are now plumbed .. even built a bracket and mounted the new proportioning valve
2 more lines to run .. fuel and fuel vapor ..
CJM
02/09/09 08:39 PM
supercharger is here ... havent unpacked it yet tonight .. but will soon ..
Greg_Canada
(Roll Me Over)
02/09/09 08:43 PM
Hey corey, if you dont mind me asking, where did you get it from and how much did you pay? I'm looking for one (PM me if it's private info)...
Greg
CJM
02/09/09 10:03 PM
my dealer program is no longer importing the 95-2002 superchargers into Canada .. go figure ???? as soon as I need one ..
anyway .. I found one on Cali craigs list , and bought it .
and why dont you have the 1/4r's listed in your sig ?
Greg_Canada
(Roll Me Over)
02/10/09 01:51 PM
Not enough words! LOL, got to edit it with a link to my cardomain... (3.4 and swap kit, now looking for a S/c and fuel kit).
CJM
02/10/09 08:01 PM
ahhh yes .. :) ...
CJM
02/10/09 08:02 PM
unpacked today
and VERY happy ... it is as complete as if it were new .. everything is there including a k&N cold air kit , bolts , well almost everything , only thing missing are the "supercharger" chrome emblems ..
CJM
02/15/09 08:47 PM
went skiing for the weekend , so not much time for the project ... BUT .. I was able to slip away for a few hours today and get some things buttoned up .. ground wires were made , and connected , i was also able to "loosly" connect the fuel system ..
so I think i'm good to go here .. need a battery , and some fuel .. then I'm ready to crank !
CJM
02/23/09 06:41 PM
so more today .. I just couldnt wait ..
Its alive !!!!
sorry for the crappy vid ... just my little camera , it's all I had .. I hope it gives you a good idea of what it will sound like ...
RatLabGuy
(Rock Warrior)
02/25/09 02:03 PM
Most important thing I see in the vid is your HUGE grin!
That must have been a good feeling. This has been quite an epic build.
CJM
02/25/09 09:00 PM
Thanks .. yeah , VERY happy , as in VERY .. I wish the vid gave the true sound and vibs (maybe turn up the base on your speakers) .. it "sparked up" perfectly ..and truely sounds wicked !!! i'm stoked !!
kewlynx
02/25/09 10:12 PM
Yeah, grinnin' like little kid with a new bike. Whooo-hoooo!!! Grinnin' right along with ya Corey.
Pizza and beer night.
Aces, buddy aces!!!!
CJM
02/26/09 07:42 PM
yep .. just like a "giddy school girl"
I've had PERMA grin for about 2 days now :)
Greg_Canada
(Roll Me Over)
02/26/09 08:57 PM
Nice, time for a new camera! Grab a Canon SD1000 (or w/e the new version is) like mine, here is it's video's on low quality http://www.youtube.com/watch?v=5f1IIbQ9b_g
Under 200 bucks brand new.
CJM
02/27/09 09:21 PM
yep .. a promice !
to have a NEW vid cam when the supercharger is on .. and you can take that to the bank !
Pyroboy
(Mudrunner)
02/28/09 11:52 PM
Congratulations, Corey!
Awesome!
SK
CJM
03/07/09 08:25 PM
little more today .... still workin' on the wiring !!!
I believe I have the body computer figured finally , well "somewhat" , wow .. what alot of head scratchin'
buttoned up the wipers finally .. The 1999 + wiper switch, houses the relay . Yes they are combined .. /83 is is seperate ... so I had to wire in the /83 relay , and now I have intermittant wipers , and the "mist" works all speeds .. DONE .. well except for the final saudering ..
I also have dash lamps and guage lamps ..
head lamps and signal lamps are next ...
K_Raider
(Rock Warrior)
03/08/09 01:26 AM
Awesome build man. Everything looks great so far. I couldn't stop reading.
CJM
03/08/09 12:20 PM
thanks ... build progress is slow right now because of the wiring , but I hope I now have it figured ... and can now get on with some more building.
Vanishing_Point
(Wheeler)
03/08/09 11:54 PM
Any pics of the wiper switch? Retrofitting a 99+ switch sounds quite interesting. I didn't know it would mount up.
CJM
03/09/09 10:31 AM
i didnt use the 99 switch .. I used the original /83 .
I am however using the whole 99 body harness, and it dosnt have a seperate wiper relay . originally i thought it was controlled by the body computer/integration relay , but it's not .
CJM
03/12/09 07:00 PM
I have head lamps , hi and low beam w/daytime running lamps (Canadian option) also park lamps
CJM
03/13/09 08:23 PM
excellent day today ... I think I have this body computer figured out finally ..
sigs work horn, hazzards , brake lamps and all park .. heck I even got the clock happinen' dash lights , door swithches , ignition ring + delay ..
just about done the wiring ... I to to have it all buttoned up this weekend ... :)
CJM
03/19/09 09:24 PM
little bit more today ...
heater works + REAR heater (never had them in Trekkers ) , and reverse lamps .
here's the nice thing .... i'm now counting DOWN to the last few things I need to wire .. The list is almost done ...
heres the list left to do ..
speedo/sensor
4WD indicator lamp
oil pressure guage
amp meter guage
BOOST guage
rear view mirror/dome lamp
Greg_Canada
(Roll Me Over)
03/19/09 09:40 PM
I hope you've got a wideband as well!
CJM
03/19/09 10:33 PM
why ?
it's not a turbocharger and I dont need EGT's to run it properly ... it's a supercharger , horse power robbing , belt driven supercharger !
Greg_Canada
(Roll Me Over)
03/20/09 09:24 AM
Have you done reasearch about this blower? Without proper fueling it runs lean lean lean...
www.gadgetonline.com
CJM
03/20/09 10:17 AM
yes I have ...
Greg_Canada
(Roll Me Over)
03/20/09 10:54 AM
I'd say about 20-30% run well without proper fueling, but you will make more power and run safer (lower EGT's) when it's tuned correctly.
CJM
03/20/09 07:46 PM
so gadget dosent even use a wide band is not even recommended .. but ya never know .. I might just do a wideband !!! I know all about "tuning" ..
I will have all the capabilities of the OBD2 from original spec , and I WILL be able to map my own computer .. and not have to realy on other manufactures "gizmoes" .. gimmy a break , have you read the "parts list " zip ties , and shrink tube .. I dont think so ! not in my house .
BraneDead
(Wheeler)
03/20/09 09:37 PM
Word of advice about force induction, dont think the stock EFI will just "work" if the stock motor was not supercharged with same exact parts, id really recommend taking it to a dyno have them deal with it, I melted down a turbo'ed M10 bmw motor in matter of weeks (21lbs boost 300hp :). Really neat build, I never seen someone take so much detail into a truck like this. Cant wait see it completed
CJM
03/20/09 10:32 PM
cool thing about a TRD supercharger (2nd gen ,black) ... they are built to fit on a stock truck with NO mods .. this is also why the "stock" set up with supercharger , gets more HP with the stock air cleaner assembly then with the K&N cold air intake !!
just like that .. TRD spends tons of cash to make sure it works on your stock engine ! I will go that route .
thanks !!!
Greg_Canada
(Roll Me Over)
03/21/09 04:44 PM
Nah nah nah, the problem with the 3.4 blower, was they didnt add any fuel modifications. THEN, when Gadget started doing the URD fuel kits, TRD came out with the 7th injector kit to cure the leaning out / high gear/pinging issue. However, since the TRD 7th was not end-user tuneable it didn't work well all the time (usually ran pig rich).
Now, with the 4.0 v6 an 5.7 v8 blowers, TRD sends NEW fuel injectors and has a re-flash for the computer (which they didnt do with the old ones, dont think it was possible) which compensates for the boost. TRD knows they screwed up large on the 3.4 kits and they rectifyed it for the new kits.
Also, how do you have control to "tune" your stock OBDII computer, gadget cant do it without add on devices, so i doubt you could, without a piggyback computer, no offense.
Read this page: http://www.gadgetonline.com/4Run.htm
Take a look at that difference in power, with just a piggyback computer and bigger injectors... no smaller pulleys, nothing. TRD definately didn't do it right.
CJM
03/23/09 10:12 PM
no offence taken ... what can I say , this is how "things" happen ... People also said I couldnt put in a 2000 harness in an 83 and make it work !!!!
so ..........
started "cleaning" up the wiring .. being I'm almost done with the wiring .. I want to start "wraping" the systems :)
CJM
03/28/09 07:38 PM
so a little bit more today ....
I got the dome lamp/rear view mirror "fit" and wired
and almost done the wiring .. only things left now are the :
1. radiator cooling FAN
2. amp guage
3. boost guage
4. o/p guage .... and any other guage I might "think" I will need :)
everything else is DONE !
I know it dosnt look very "nice " at the moment , I do still have to "pull " some pins and i'm going to wait untill I pull it out again to do so .. most of the final saudering is DONE .. again .. I want to wait for some of it untill pull the harness out , so I'm not working in such cramped quarters .
also working on the factory air box just about dont that ..
RatLabGuy
(Rock Warrior)
03/28/09 08:04 PM
What happened to that snazzy floor you fabbed up?
CJM
03/28/09 08:52 PM
it's easier to "climb " in and out right now , with out the floor in ..
BUT ...
it IS going in VERY soon :) .....
wsquaredodie
(Rock Warrior)
03/30/09 05:11 PM
Spaghetti factory??
CJM
03/30/09 07:35 PM
not for long .. basically done today
guages were the last of the interior wiring
so all I have left to do is the engine fan .. :)
time to start welding in the floor ... yeah!!!
kewlynx
(Toyota & Classifieds Moderator)
03/30/09 09:25 PM
Yeah, I reckon if you were doing dash work that standing on the floor instead of the pan would make one's back a lot happier.
Greg_Canada
(Roll Me Over)
03/30/09 11:04 PM
Any plans on sound deadening? I'm planning on doing mine before the 3.4 goes in. with my exhaust, those 'glass rear panels do NOTHING to stop the sound... should be a fun project...
CJM
03/31/09 10:57 AM
yep ... I'm picking up some dynamat for the floor , I also am getting DEI thermal firewall and tunnel shield ..
of course this all goes under the insulator and carpet .
as for your 1/4rs , I've had some guys spray the inside with undercoating , and tell me that makes a big differance on sound infulltration .
Greg_Canada
(Roll Me Over)
03/31/09 12:38 PM
I suggest not to get dynamat. the regular stuff is junk, and the "extreme" is overpriced.
From my research, this is the best on the market http://www.secondskinaudio.com/products/Noise-Reduction.php
CJM
03/31/09 08:45 PM
so where in Canada do you get it ?
Greg_Canada
(Roll Me Over)
03/31/09 11:18 PM
There's a place in Fonthill (about 20 min from niagra falls) where i'm going to pick some up. Damplifier is about $3.50 / sq ft. Oh yeah, anything that comes on a "roll" or is rolled up, isn't meant for cars, it's meant for roofing. If it comes in sheets, it's meant for a car. I've learned that in my searching (dynamat extreme and damplifier come in sheets) The b-quiet stuff comes in rolls (made in alberta) .
Here's a cool site: http://www.sounddeadenershowdown.com/
CJM
04/01/09 07:49 PM
had an hour today ... so I thought I would start on the floors .. got them drilled , and fit again , and started to "plug" the holes ..
got a couple done and ran out of wire .. crap !! I hate when that happens
CJM
04/02/09 07:49 PM
tacked !!!
still have to modify the seat crossmembers to fit (there just sitting there ) and weld the nuts before I can weld them in --- but kind of shows you the seat support .
CJM
04/10/09 06:30 PM
couple of things today ..
got the seat belts installed / mocked up
I do have to still plate the mouinting bolts on the floor , but I will do that when I have the cab off .
also removed the air intake muffler , and made a pipe . this pipe diameter is 2.75" and seems no one in town has .
CJM
04/11/09 07:28 PM
continued with the floor mock up ...
but first had to replace the seat tracks .... some one cut and welded the rails >:(
i'm going to re-do the seats anyway , so no biggie !!
removing the seat back cover , lock strip and hog rings .
and installing the new rails ...
with the new rails , I now could line up the rail , and weld mounting bolts .. and zinc .
aligned , and welded
and seats ... BOLTED :)
CJM
04/12/09 07:33 PM
couple of more things ....
buttoned up the heater control valve , and hoses including the rear heater piping ...
also
got the new fan installed .. I decided to take back the 14" 1500CFM in favor for the 16" .. 2500 CFM
had to cut the lower support .. but no biggie ..
made a new hood lock support , "boltable"
just now waiting for the fan controller now .. :-/ (ordered a week ago )
CJM
04/22/09 07:38 PM
so not much to add ... built the box for the body computer .. and I'm just awaiting my new fenders to check clearances .. I want to move out as far as I can to alow for inner kick panel clearance ..
also got my new Optima battery
and also just got to day for the wiring near the exhaust ... some heat tape :)
flyinhawaiian
04/23/09 02:16 AM
sweeeeet, awesome job. kinda envy how you have the space and time to do this work...by the way, is that heater valve oem? aloha.
CJM
04/23/09 10:37 AM
thanks , I wish I had more space and time .. fishing and camping soon , and also coaching my boys ball team ... not much time for me .
Yes heater control valve is from a 89 4Runner 3.0L with rear heater . hoses and all fit excellent . I changed the routing of the rear piping for the rear heater though , I am using 14" of copper for each line , only to get by the crossover pipe , then I'm going to route rubber hose , and insulate it for better rear heat .
CJM
04/25/09 08:17 PM
so spent a few bucks today ...
bought some shop tools and consumables , and some dollies . I wanted to put some tires and wheels on it , and the dollies will just make it that much more maneuverable ..
so .. I put the shoes on for mock up (they dont fit quite right as they hit the calipers) and got it on the dollies .. also got the fiber fenders set on to check the body computer box clearance .. fits perfect :) , so now I can weld that ....
so now I can push it around the shop .. I thought I would do a full body mock up ... hehehe .... enjoy .. I did
allochris
(Rock Warrior)
04/26/09 12:24 AM
Where about in Penticton are you? Every spring i plant around princeton & climb at Skaha but i kept forgeting to come visit you. Guess I will have no excuse this coming summer...
flyinhawaiian
04/26/09 05:54 AM
coming along real nice. are the bedside pnls the originals? what happened to the roof, is looks like its sagging???
RatLabGuy
(Rock Warrior)
04/26/09 10:13 AM
Is it just the angle, or is there something up w/ teh camber on the driver's tire?
CJM
04/26/09 11:46 AM
on Commercial Way , in the industrial area ... your welcome to come by .. I just ask , you call me first .... I cant always just stop , to chat .
bed panels are the original fiberglass from winnabego , and so is the canopy .. I'm going to be building a new mould for the tops because most Trekkers look like that .When Winnabego built them , they used balsa strengthener strips , and they have all collapsed .. I have pictures of the Trekker I built for a fella in Texas If you want to see .
Yes there is .. as mentioned above , the rims hit the calipers on all 4 corners .
The "shoes" are actually my summers for my DD IFS toy . These are just on there for now (mock up) , untill I order my NEW ones . I really wanted to get a "guage" as to what size of tire I wanted .. those are 31's .
CJM
05/06/09 10:25 AM
finally got the fan controler mounted and wired .. I decided to go with the Flex-a-lite controler .. it will work from 60% to 100% depending on temp. .. + if necessary , it will run 30 seconds longer after vehicle has been shut off .
also .. got my new shoes
315/75R16 's .. (35 X 12.50 16)
Greg_Canada
(Roll Me Over)
05/06/09 11:18 AM
NICE! I dig the wheel choice! Makes it look like a whole new truck vs the other ones... (damn maybe i should put mine back on)
CJM
05/06/09 08:23 PM
Thanks Bro .. I really like them myself .. old school
CJM
05/06/09 08:24 PM
so continuing working on brackets for mounting "items" got the rear heater mounted
also working on the wiring ...
made brackets and mounted the computer , routed wires , and "tying" the harness for final loom ..
also started on the dash ...
because of the larger 2000 4Runner speedo , the left ball vent would not fit .. so I first cut out the old , and started to tack in the new .. Thanks Paul .. (donated the piece to the project)
CJM
05/08/09 07:59 PM
so couple of things today ...
started machining a new antenna mast mount .. I know some might call it silly .. I just think it's all in the small details ..
you can see the old ones in the picture .. and neither nor really fit the new 2000 POWER antenna .. and because the fender is "flat" on the top where the antenna sits , the newer power antenna mounts dont fit either , they sit on the side of the fender .. in the picture .. the chrome stock piece is only a 1/2 .. the picture only shows 1 side .. I think it looked dumb , so this is why I'm making one .
so I started this .. still more polishing to do .
also decided to mock up the headlamp doors ...
and continued working on the dash
First I made a template for the original "woodgrain" , out of paper ... layed it onto some steel , and cut it out ... test fit
then I cut a tab or edging and welded
trimed and drilled ... and screw'd into place ....
Now I have a bare template for heater controles and switches , and sterio ... I'm not a smoker , so there will be NO ash trey in this unit !!!
and .. as this day was ending ... I decided to tape off the dash , and lay some tin foil on the dash .. in prep for fiberglassing a new "base plate" for the new dash pad ...
and a first layer of mat
kewlynx
05/11/09 01:11 AM
Wow, you're really getting there Corey.
With all the little electronic gadgets out there, you might consider putting in a cig lighter, if not for anything else, for a solar battery charger or something. I use the one in the back of my '99 quite a bit; mostly for air pump for camping mattresses or small air compressor.
Just a thought; what do the boys think of this project? I know ya keep 'em busy!
RatLabGuy
(Rock Warrior)
05/11/09 09:59 AM
I don't think my ash tray has ever had actual ashes in it - but it's a great place to contain loose change, rnadom bolts, candy... all kind of crap that would get thrown around as soon as you leave pavement.
i liek teh idea of starting w/ a fresh flat console plate though, now you can lay it out however you want.
CJM
05/11/09 10:53 AM
exactly .. I am going to use the 2 accessory ports from the original 4Runner .. I did keep the wiring intact for those for exactly the reason you mentioned . 1 in the front (dash) and 1 in the rear .
no ash trey , I want the room for "other things" .
I know what you mean about the "little things" being tossed in the ash trey , my DD is the same . I have thought about this , and I am going to be building a center console .. so I will have the room there , as well as cup holders
not set on the lay out of the dash yet , I just know for sure , where the heater controls are going ..
Greg_Canada
(Roll Me Over)
05/11/09 12:08 PM
Are you gonna throw in an inclinometer just for kicks?
CJM
05/12/09 07:18 PM
nope .
so little more to add .....
got the POWER antenna mount done ... and mounted
also .. continuing working on the dash ..
trimmed the fiber dash base
and "hammered" out a new corner dash piece , and welded ..
CJM
05/13/09 07:52 PM
made the Left lower dash plate today .. in the same manner as the right.. hammered out a piece , and welded it together .
Last piece is the center piece . Then I can start to make the "cutouts" for the switches and such .
CJM
05/14/09 08:19 PM
got the center section done today ..
now I can lay out my switches , sterio and heater controls
then .. time for some body work and "tweeking" , paint .. 2 part foam and sewn leather top
CJM
05/21/09 08:39 PM
not much to add ...
have been "tinkering" on it every "now and then" .
I have pulled off the back 1/2 again .. because I wanted to wire the LAST pieces .. pump and sender .. pump works awesome , sender NO .
1 of the issues is the fuel warning lamp . /83 dosnt have .. /99 does (dash cluster)
I dont know of any way to wire this issue .. so I'm going to have to use a /99 fuel tank sender and build my own sending unit .
under way
CJM
05/24/09 08:47 PM
got the sender done today ...
here's what I had to do ...
first I made the top , just cut it out of some 12G scrap I had ..then I drilled the mount holes ..
trimmed , and finished to a perfect circle (well maybe NOT perfect .
I had a few difficulties figuring out the support .. because the hole on the tank is so small .. there was definatly some "grey matter working " but I got er' figured !!
the mount support , off-set to fit into the smaller hole
and with a little "massaging" I was able to finally "roughly" mount the sender , and stuff it into the tank .
once I was able to fit it .. I needed to support it .
so I made some little brackets , and drilled and tapped the support holes .
this is a pic of the sender as it came out of the /99 is tank ..
and after cutting the original mounts and ground off .. heres what I have now .. with the new clips new ground wire and main support I made .
and all together
and mounted and tested .. it works YEAAAAAH !!!!
so now I want to send it out for anadizing .. then I will seal the wires ..
CJM
05/28/09 08:20 PM
installing the SUPERCHARGER ... finally ..
finished ..
supercharger WHINE .. is so cool ....
but I really have to put some coolant in , so I can run it ... this weekend for sure !!!!!
kewlynx
05/28/09 09:44 PM
Dang Corey, I'm excited for ya. Gotta be killer doing it with what little spare time you have. Way to stay with it!
drainsbe
(Wheeler)
05/28/09 11:59 PM
Freakin awesome build... Thanks for sharing all of your progress.
wsquaredodie
(Rock Warrior)
05/29/09 09:44 AM
Looking at your last pic brings up a suggestion I have used on both my 93T's. Instead of the chintzy plastic clip for the hood hold up rod, put a small piece of velcro in the appropriate place. Never rattles, never wears out. And you do not have to lean on a piece of plastic if your are under the hood.
CJM
05/29/09 10:31 AM
thanks
and wsquaredodie , the 79-83's actually have a metal screw on , prop rod hold down .. low profile , much nicer (in my opinion) then the plastic ones that always break .
wsquaredodie
(Rock Warrior)
05/29/09 11:06 PM
Sounds like a good idea - but laying your big belly on velcro is much better.........
CJM
05/30/09 08:23 PM
I wasnt going to , but I decided to finish wiring the fan .. and hook up the cooling system .. The last things I had to do , for a running unit .
I have had many times when I have done wiring (not my favorite thing) thought I had it all good .. taped and loomed only to have to take it all apart again because of some stupid mistake .
so this is why I wanted to get it running perfectly before I took it apart for the last time ,and , taped and loomed it all up .. I'm glad I did .
Today I finished the plumbing .. all clamped .. also buttened up the fan wiring . filled er' up with some coolant and flashed her up ..
I have 4 problems ...
1. the temp guage went to hot "right off the bat" wiring issue maybe .. not sure just yet .
2. amp meter dosnt work ..
3. check engine lamp - checked with my OBll reader , and have only 1 code
4. since I put on the supercharger , its running rough and really low idle ~600RPM , I think I have a vaccuum leak maybe .
I wasnt able to look into any of these just yet , but obviously will !!
wsquaredodie
(Rock Warrior)
05/30/09 09:07 PM
Might want to verify god ground on the electrics
CJM
05/30/09 09:44 PM
I will ...
CJM
06/10/09 07:32 PM
so wee bit of progress today ... had an hour , so I was able to figure the temp sensor .. IT works now . you were right , I had unsuspectantly removed the ground wire from the combi. meter connector .
check engine lamp is still on , but now I can run it .. and did so today ..
found it running rich and I still have air temp control code .. which I believe now is the IAC valve .. iratic idle and rich .. hopefully I can check that out tomorrow .
and still have the AMP meter not working ! and that is it .
wsquaredodie
(Rock Warrior)
06/11/09 09:18 AM
Amp meter only works if the circuit is complete. Look for a bad connection somewhere
Greg_Canada
(Roll Me Over)
06/11/09 10:07 AM
SO wait, do you have an ampmeter, or a voltmeter? An ampmeter has to be hooked up inline in the positive battery cable (in series).
Voltmeter would be an easy hook up...
wsquaredodie
(Rock Warrior)
06/11/09 06:36 PM
Mine's (as most) is an volt meter. Not very accurate, of course. Still, if the amp meter is not working you have 2 choices. Bad meter, bad connection. After checking in my stolen 1963 Stockel Auto Mechanics fundamentals book from Spencerport High School (yes, I AM that old), volt meters are connected in parallel with a circuit. Ammeters are connected in series with the circuit. Therein may be your problem. ps, ohmmeters are connected in parallel with the load with the negative side of the load unconnected to the power source. If you want, I can make a copy of this info and forward via email. If everyone wants, I can figure out (again) how to post the book info on the site. ps, this book is so old it SMELLS old.
CJM
06/11/09 08:58 PM
so little more investagation today ..
checked out the IAC today .. and all within spec. .. so I had a chat with one of the local toyota techs today , apparently the air intake sensor is incorporated into the MAS .. tried to clean , and no go .. so i'll replace , and try again !
also .. brain fart it is a volt meter ..
wsquaredodie , your welcome to post up some info on wiring !!
wsquaredodie
(Rock Warrior)
06/11/09 10:05 PM
Copied the book info to a
word file. Any idea how to get it posted?
Bill
CJM
06/12/09 10:40 AM
not sure , but I believe you have to upload it to a host site first , I use photobucket for my pics , but not positive on a word file ?
CJM
06/12/09 10:11 PM
so no luck so far ..
I'm hesatent to run for any length of time , as its running very rich .. and I'm worried about piston melting !!
I tested the MAS today .. and very close to spec. but just off a bit .. I'm wondering if it's my OHM meter ? I dont know ! The OBD11 code suggests otherwise .
I phoned Darren at White Valley Collision , where I originally bought the engine package , and he has willingly "stepped up to the plate" to replace the piece . AWESOME service !!! and a GREAT guy to deal with !!
new/used MAS is on the way ..
this is basically the LAST thing before I can tear it down for paint .. Paint is here , so I'm wanting to get this wrapped up !!!
CJM
06/16/09 08:56 PM
worked on it for a few mins today .. my buddy Paul came over to help ..
replaced the MASS .. and no change .. checked olm values .. and both the same ..
After Paul left , I ran the Trekker up to temp .. .. even got the new fan "pushin air " .. I'm very pleased with that aspect .. as engine temp. stayed @ 1/2 guage . I assume it's 195* but didnt actually check .. I did check heater opperation , and both front and rear were blowing HOT .. so all is good there :)
so basically I'm stuck here ..
My "rich" running engine either boils down to a harness issue .. or computer issue ...
my OBD11 reader has =
getting a code P0110 Air Intake Temp. sensor 1 circut ... which from what I understand this sensor is incorporated in the MASS ..
I replaced the MASS with another .. and same symptom , same code .. cleaned both .. same thing with both .
I have also pulled out code P0172 = system running to rich bank 1 . and P0100 Mass or volume air flow A circut .
so I'm totally confused now ?
I'm going to check harness integrety , dont think this is it , but I will check it to the computer plug .. then the computer is the last option , but ... no test -- correct ? just replace ?
talked to Daren (white valley collision ) and he dosnt have another computer .. I really hope I dont have to spend another G note for a computer !!
kewlynx
06/16/09 11:43 PM
Presuming you'd use the same ECU as the US, wring that one out before looking for another one Corey.
Remind me again which engine is in there now please. The 'bank' thing has me thrown off.
Greg_Canada
(Roll Me Over)
06/17/09 09:02 AM
Might be a question to ask over on customtacos or yotatech, alot more 5vz users over there.
Is the MAF and the ECU all from the same truck?
CJM
06/17/09 10:35 AM
yes ALL the "stuff" is from the same year = /99 (or so i'm told). engine was originally an ATM from a 4Runner . everything else was from a /99 Tacoma MTM . only thing I have done to the engine , is swap the ATM harness for the MTM harness , and add the supercharger , and of course the crossover ..
I'll have to hit toydiy and start comparing part #'s as well .
Greg_Canada
(Roll Me Over)
06/17/09 03:31 PM
toyota changed MAF's and o2 sensors in 1999. The MAF pinout may be wrong. Gadget at URD knows all about it, try asking him.
CJM
06/17/09 08:51 PM
Thanks Bro ... i'll try .
CJM
06/21/09 09:42 PM
so i'm running out of options ... and I still dont know what is wrong !!! VERY frusterating .. and I dont want to do this anymore !!!!
I spent about 3 hrs today on the "check engine" and I'm almost ready to admit defeat ..
I have talked to a buddy of mine (All Toy , in Kamloops ) and he got a rig in there shop , basically with the same symptoms .. he asked me to let them know whats up !!
anyway ..
I got the new/used MTM O2 sensors .. and as I suspected . the wire length is different .. so hence the part # change .. (I guess) installed = NO differance .
checked wire harness integetry between MASS and computer = contenuity OK on all 5 wires . Harness is good .
also checked computer values as per "diagnosis" in manual ..THA + E2 pins .05~3.5ohms @20*C all with in value .
suggest pins are ok .. I didnt get to operating temp. and check values .. lost hope here >
I'm realy lost here now .. and almost ready to give up !!
considering removing the check engine light bulb , and compensating the TPS .. or something stupid like that !!!!
I dont get it .. everyone elses swap seems to go so simple .. what the hell !!!!
Greg_Canada
(Roll Me Over)
06/22/09 11:57 AM
It wont run 100%. Why dont you take it to the toyota dealership? It's all stock computer, they should be able to diagnose it.
CJM
06/23/09 09:47 PM
ohhh it runs awesome ... just rich ! and that dang check engine light is on !!!
I got the manual now , time to get er' fixed !
CJM
07/01/09 07:52 PM
YAHOOOOOOoooooo !!!!!!!
finally got it figured . Code PO110 (in my case)
started with replacing the maf with another .. no change .
checked wire integrity with my ohm meter .. continuity , good
also checked values on the computer , everything checked out !!! system OK ... still had the check engine .. anyway , you guys know the story ...
I decided maybe something happened to the computer , so I searched Canada for a MTM /99 computer . found 1 .. after thinking about it , for a while and considering the MTM computer , for this year , is a rare bird .. (9807-9908 only).. so I decided to buy it .
well got it today , and plugged it in ... I was bummed when there was no change , and still "check engine" with a code ...
I have been checking my wiring thoroughly .. as this is the only direction I could go .. lots of wire checking , head scratching and reading the manual , when I turned the page , and saw a picture of a MAF, that was not the one I was using .. Toyota is usually pretty good with there descriptions , and not usually generic with there pictures .. this was it ... I had the 2000 MAF from my supercharger purchase , hooked up the intake and plugged it in ..
PRESTO ... NO CODE
runs awesome ... I'm so happy !!!!!
turns out I had the wrong MAF supplied to me with the original purchase of the engine conversion "kit" ...
man the time and MONEY I spent on this is just crazy !!! and now I have way less hair @!! but i'm happy it's done and running awesome .
also talked to Darren today , and he has offered to send me the correct parts via Greyhound prepaid ... to correct this misshap ..
so now ... it's VID time !!!!!
COMMING SOON
Greg_Canada
(Roll Me Over)
07/01/09 10:28 PM
Eh, eh, what did i say! Told you they changed the MAF's alot! only 95.5-98 interchange, the newer ones are all wacky.
But for mine, i got a supra twin turbo MAF,
Greg_Canada
(Roll Me Over)
07/01/09 10:29 PM
However, all the MAF's will work with all years, but you have to move pins in the harness.
CJM
07/02/09 12:18 AM
yeah .. silly me .
Greg_Canada
(Roll Me Over)
07/02/09 12:46 PM
Good to hear tho. I'm almost getting ready to drop my 3.4 in. Just waiting to get the cams back from the grinder and the short block assembled. Then, throw it together, and drop her in (cant wait).
Then, we can duel (haha). Yours is still gonna be much cooler than mine.
Oh, so, are you ever going to start doing replacement floors for the 1st gen 4runners? I might be one of your first customers.... (or i go to cali and buy a rust free truck and drop my drivetrain/interior in it).
CJM
07/02/09 09:24 PM
where the heck is your build thread ????
how come I cant find it .... Dude !!
I fear the floors will be a no go .. as Toyota owners just dont want to spend the money and our reasearch .
quote from another board
[quote=slacker;51172821]biggest problem we run into .. and please dont take this the wrong way ..
toyota guys are cheep for body repairs !! they just dont want to pay for quality body pieces .. WAAAA it's a 25 year old truck , YET , they will pay thousands and thousands to the marlins, and trailgears for suspension stuff ... but , when we did our market reasearch for "stamping" new floor pans .. for instance.
toyota owners whom wanted them .. only wanted to pay $25.00 ea. real market production costs and min. mark up suggested an ea. price "volume" cost of $125.00 . for a quality product . quite a differance !
hence ... we wont be doing it untill the market changes .
I would love to build them .. but unfortunatly .. not enough of a market .
Greg_Canada
(Roll Me Over)
07/03/09 11:22 AM
No thread yet, i want to wait till i get the engine back from the shop, as it's been idle for me for weeks. I've also been really busy at my dads shop as he moved last month, it was a big job, just finishing up loose odds and ends now.
Floor pans? Sheesh, i'm willing to spend a good $750 on (good) floor pans... i figure it's reasonable. But, understand how it is.... Not everyone wants to do that. Then i go see my cousin drop 20,000 for a new stroker engine for his vette, like money aint a thing... lucky bastard... lol.
CJMT100
(Rock Warrior)
07/03/09 08:53 PM
125 bucks, thats cheap! Making your own out of whatever is more money in the long run b/c you have to shape the things. Not everyone has the roller to do it.
Fiberglass is good stuff man..
CJM
07/03/09 09:08 PM
yeah guys .. I kind of thought 125 ea. was a VERY reasonable price myself . Thing is though , not every one does !
We have to have them "stamped" in volume .. thousands of dollars in out lay for the initial purchace , and to have to inventory the "pile" in the shop for 20years , dosnt make sence to me .. not a good investment !
we wont be doing them .
Pyroboy
(Mudrunner)
07/03/09 09:09 PM
Congratulations! Would be great to see the truck and I'll be in Penticton for the next week. Sent you a PM.
As for the floors, I would gladly have spent $200+ on pans to avoid the work I had to do to properly replace the driver's toeboard/ floor in my truck after a leaky winshield left it rusty.
CJM
07/03/09 09:16 PM
PM back at ya !!!
your always welcome foo
CJM
07/04/09 06:19 PM
rewired the /98 MAF today .
and a VID :)
wee bit of belt squeek , but i'll get to that later .
RatLabGuy
(Rock Warrior)
07/05/09 10:53 AM
Very nice.
I hoipe you had a nice long cold one after that.
Greg_Canada
(Roll Me Over)
07/05/09 01:38 PM
Now that's the kind of whine I like!
CJM
07/05/09 08:29 PM
thanks guys ...
little work on the dash today .. got the clutch start switch and "spare" switch cover mounted on the left side ..
had to cut out the old dash piece , make a new "cluster" mount and suport piece for the underside .. welded it all in , and got the dash partially back together
CJM
07/06/09 11:23 PM
so continuing working on the wiring , and getting the dash all layd out ..
continuing on the dash
got some of the swithches in ..
lamp reostat , hazard switch , and clock ..
started working on the heater bezzle and broke it .. D@#B !!!! so I now need to find another one
kewlynx
07/06/09 11:56 PM
Damn- that just made me tingle. WOOOOOOOOOO!!!! We're very proud of you Corey.
Just saw a 98 engine FS in the Sunday paper; needs rebuilt; $200.
And I just picked up a 2004 Taco.
bkg
(Roll Me Over)
07/07/09 09:41 AM
Must be the angle of the pictures as it appears the bezel is crooked?
CJM
07/07/09 10:52 AM
center one ? it's not actually "screwed " in place .. it just "placed" in it position .
I do see what you mean though , wierd , must be the angle .. it is square .
CJM
07/07/09 06:56 PM
so as it turns out ... it was crooked .
I guess from my pulling it in and out of the truck with the suports cut out , bent it .
the whole left lower section was "bent" over about 1/2 inch . once its bolted in the truck , should be good .
RatLabGuy
(Rock Warrior)
07/07/09 07:46 PM
diggin the stereo ;-)
CJM
07/07/09 09:39 PM
yeah !!! sterio will be a motorized 7" touch screen , including GPS .
I'm still not "sold" on this "cluster" set up though .. having second thoughts ...
CJMT100
(Rock Warrior)
07/07/09 11:14 PM
^ If you covered it in say plastic, leather or something it would be a whole lot better. Maybe that faux wood paneling you can buy at the orange depot-it sticks on.
CJM
07/07/09 11:24 PM
yeah .. I was thinking a "wood grain" of sorts .. to make it "stock like" in appearance ..
sometimes with so much on the go .. it's hard to focus on 1 thing ..
Greg_Canada
(Roll Me Over)
07/07/09 11:25 PM
I'd be flipping the stereo/clock with the HVAC controls if i were you, with your way, you cant use the ACC with the stereo! come on corey!
CJM
07/08/09 12:23 AM
good point ...
But I cant .. cables are specific, as well as the controles , room is also an issue , as the heater box would be in the way . sterio cant be moved as well , because it needs the "room" for the motorized head .. this is my "best case senero" and i'll just have to deal with the critics or choose another sterio
RatLabGuy
(Rock Warrior)
07/08/09 01:16 PM
^^ he raises a very good point.
And maybe more importantly, you're going to be reaching waaaay over to teh right to fiddle with your radio whie driving.
I get annoyed enough with the stock location on teh 2nd gen trucks, being pretty far down low in the center of teh dash, I feel liek I have to really move my attention away from teh road when changing stations, loading a CD etc.
If I were designin ga dash from scratch, I'd mount that sucker high and and close to the wheel as possible...
CJMT100
(Rock Warrior)
07/08/09 07:40 PM
FWIW Im not a big fan of the motorized head units, I had 2 of them break in my old camry and no longer open/close and I didnt do a thing. They were $$$ Pioneer, replaced under warranty then that one broke so I said F it and bought a regular old HU.
Had another idea, could build up the dash with fiberglass and bondo and paint it with plastic paint. It will come out very nice-but its alot of work.
CJM
07/08/09 10:13 PM
seriously .. it's not much of a reach .. it's basically the STOCK location and I dont think interups my "attention" to much .. so really I dont think it will be an issue .
gotta remember .. I'm trying to keep this stock "style" so I kind of want to keep it "factory looking"
thats some good info .. I was really wanting the motorized head unit for "status" ... but I'm really re-considering now .
as for the fiberglass dash .. not on this one , My 2WD build http://toyota2wd.proboards.com/index.cgi?board=allgoes&action=display&thread=18 I'll be going all out , but not on this one !! want is "kind of "stock " looking
Greg_Canada
(Roll Me Over)
07/09/09 10:32 AM
Yeah, that was another reason, i would never suggest a pop-out screen to anyone. I'd rather have a stock HU.
BUt if you can modify it for double-din, i would put in a 6.5 or 7" touchscreen in any day.
CJM
07/10/09 09:14 PM
GPS was the main reason for the flip up screen ...
Greg_Canada
(Roll Me Over)
07/10/09 10:24 PM
No way at all you can install a double din to mod the dash?
CJMT100
(Rock Warrior)
07/10/09 11:35 PM
FWIW things that do more than 1 function never seem to work that well imho.
I have a garmin GPS I use for work, NUVI 750 model. Mounts to the windshield or w/e you want pretty much. Works EXCELLENT since I use it every single day driving a truck all over the place.
Just imho..
CJM
07/11/09 01:19 AM
I have been looking at the Kenwood DV4100 .. or a "potential sponcer" has suggested ..
we'll see I guess ...
Greg_Canada
(Roll Me Over)
07/11/09 12:30 PM
That is just a nav unit that locks on to the head unit, you still need a screen.
My cousin has an older one it works pretty good. Updated maps are pretty expensive tho.
CJM
07/11/09 08:33 PM
ok .. so basically done today .. just have to locate the sterio , (still not sure on which one I'm using ) and "finish " of the dash bezzle .. I have been thinking of a woodgrain type covering/paint .. to simulate the original , maybe the "inferno Red " paint , I was even thinking of covering it in carbon fiber ... anyway not sure
here's how it is now ..
CJMT100
(Rock Warrior)
07/12/09 02:11 AM
I vote woodgrain. If you go to orange depot you could get some awesome paneling that would work really, really well.
RatLabGuy
(Rock Warrior)
07/12/09 01:03 PM
Just imho..
I tend to back this idea, recently lookin gfor a new HU for my wife's car, i really wanted a multi-function deal too. In te hend I found that it was just more cost effective to buy two seperate units, not too many options for all-in-one that really do a good job of everything without being super $$$. IMO you'll want a GPS from a good company so you can reliably get new maps... in the end, that's what they're really about, the maps/service.
That said, since you're building teh dash ground-up, you could probably easier make a nice mount for the GPS unit and a seperate lareg screen if you wanted that.
Oh and carbon-fiber coverin gwould be bad-ass... but not real fitting for the age/style? I guessst he quetsion is, are you going for new & stylish, or classy?
CJM
07/12/09 10:41 PM
I think I'm "swaying" to a wood grain "finish" , as I think this BEST fits the overall project .
CJM
07/17/09 09:02 PM
so some mock up on the dash ...
I have been working with a "wood guy " ... and here is so far what we have come up with ... please ... this is NOT the final position of any of the components .. so dont look at that !! just the color is what i'm interested in !
It's a Cherry wood vaneer .. no varnish yet , so it will look a little "glossier" once done ... but it kind of gives an idea ...
I think it will really bring the INFERNO RED exterior into the interior .. I'm considering some door panel incerts as well :)
what do you think ?
also looking at a "tiger wood " incert as well ... so !!
CJMT100
(Rock Warrior)
07/18/09 12:59 AM
I think the tigerwood would be better imho.
CJM
07/26/09 08:06 PM
so it finally "cooled" down to 33* C (90*F) outside ... and was able to get some work done ..
as mentioned .. I decided to change the dash again .. so I welded up the clock , hazard, and dimmer hole .. and cut the NEW gauge holes .
the frame of the dash had also been butchered by the previous owner ..
so I cleaned it up , and started to make some new supports . I have more to do , to get the sterio supported .. but I wanted to make sure everything was going to be ok before I did all the work .
also , now had to RE-mount the heater controls
so , now I'm happy ....
and "installed"
Greg_Canada
(Roll Me Over)
07/26/09 09:57 PM
Nice i like this setup.
What gauges are you running? Boost AFR EGT?
kewlynx
07/26/09 11:17 PM
Now this dash I like a lot better too.
Are those a pair of cig lighter ports for toys at the upper right above the stereo I'm seeing? If so, that's a nice upgrade the boys will appreciate.
CJM
07/27/09 12:39 AM
Thanks bud ..
gauges are .. volt o/p and boost ..
and I will be adding ,W/T, F/P , and EGT .. in ther center console :)
thanks girl ... yep .. those are the 12V ports ...
got one in the back 40 as well :) ..
Ralph
(Wheeler)
07/27/09 02:26 AM
Gauges in the Dash.
Stereo in the center console .... sorry....
CJM
07/27/09 08:22 PM
I really wanted to .. but just couldnt do it . The heater box was in the way , there was just no room to do so
CJMT100
(Rock Warrior)
07/27/09 08:39 PM
I like that a heck of alot better!
rany
(Need a Spot)
07/27/09 10:02 PM
holy smokes! you rock!! nice.what a build.....
CJM
07/29/09 09:21 PM
thanks guys ...
I'm going to build a center console as well ... I have A few more guages , as well as the clock and such going in there ..
dknight
(Mudrunner)
07/31/09 04:21 PM
I didn't see a spot for the arb switches
CJM
07/31/09 08:10 PM
speed bumps dont need ARB's ....
CJM
08/28/09 09:11 PM
ok .. so back to work ...
enough with the "holidays" :)
got the tranny tunel sealed ..
did some wrecker searching today and found just what I wanted ..
mock up
holes drilled and "Nut certed"
installed
CJM
08/29/09 08:54 PM
and on to the center console
mock up time for that ..
cardboard ..
so far , so good ! :)
CJMT100
(Rock Warrior)
08/30/09 12:19 AM
No dual t-case?
Greg_Canada
(Roll Me Over)
08/30/09 04:56 PM
Don't need dual t-case's for speedbumps
CJM
08/30/09 08:50 PM
yep .. not a crawler , it's my tow rig for my 2WD 400HP supracharged "hotrod"
CJM
09/05/09 07:48 PM
got some work done on the console today ..
started with removing my template ..
I picked up some 3/8" fiberboard , to make my "plug"
started with the sides of the console , clamped them and sanded untill they were exactly the same .
and started to cut and install the panels , using the patern from my "template"
and started to round the edges
and the first coat of filler ..
thats it for today :)
CJM
09/10/09 08:33 PM
Wee little more today ...
sealed .. and first primer
gettin close to building my mold
CJM
09/14/09 08:18 PM
ok .. so , I took yesterday off sunday the 13th , as it was my B-day .. and " I wasnt aloud to go to work :) "
so today .. I popped out the new pieces ..
I cant wait to get them on !!!!!
consol is in the booth having the mold made :)
kewlynx
09/15/09 03:22 AM
Niiiiice! Good to see you don't mind pimpin' your product on your ride there Corey!!!
CJM
09/16/09 07:57 PM
yep ... opps .. sorry .
I should have known better ... but I guess it saves me havin' to answer "where'd ya get it from "
CJM
09/16/09 08:17 PM
so just to let every one know ..
I "peeled" out the "plug" for the console .. I now have a "basic" mold :)
I still have to "wet" sand ... and wax and polish .. but if all goes well , I should have a NEW piece by the weekend
CJM
09/18/09 07:37 PM
so pulled the piece today ..
trimmed it up , and "roughly" did the cutouts to fit it ...
fits like a glove :)
still have to put the guages , cupholders and such in .. but this will give you an idea
CJM
09/18/09 10:31 PM
also ...
just to let ya all know .. I destroyed the mold ..
so this is a 1 off ..
CJMT100
(Rock Warrior)
09/19/09 12:20 AM
Why would you do that man, all that hard work and you dont want anyone else to have one?
CJM
09/19/09 10:54 AM
it was my temper I got mad at it .
CJMT100
(Rock Warrior)
09/19/09 12:32 PM
I see.. Scary stuff man.
CJM
09/19/09 08:34 PM
once in a while .. ya just gotta "vent" ..
inanimate object's are ok in my eyes !!
CJM
10/08/09 08:58 PM
sorry for the slow progress ...
but today I have a wee bit of an update .
started the drivers door panel , I have to re-pin the hinges , so I will be sure to post that as well .. (hopefully this weekend) but for now , this will have to do
started with removing the door and hinges
Next .. with the grinder "clipped" the edges
and off comes the skin .. there is a few spot welds , expecially for the vent window supports .. but easlily dealt with ..
New skin goes on .. and time to make it stick !!
I didnt have a mini rasp, have to go buy one .. so I called er' a day ..
kewlynx
10/09/09 01:10 AM
Shakes head in awe....wow.
CJM
10/09/09 08:35 PM
got the flanges cleaned up today .. and got the POR15 on them
also "cleaned" up the inside , and got it POR15'd
trimmed up the holes for the handle and lock
and installed and ready to "bond"
CJM
10/10/09 07:23 PM
ok continueing on ... In order to "attach" the fiber skin .. you need to scuff the panel , where it will contact the metal shell , for as the say in the industry "tooth" , meaning .. something for the epoxy to stick to
fiber panel
metal shell , back to bare steel .
The epoxy I use in my shop is 3M panel bonder .. it's expencive , but if done propperly , it will never come apart , and they guarentee it !!
so now .. epoxied .. and clamped .. just has to cure ..
CJM
10/10/09 07:43 PM
so now the door is "curing " ...... time to address the hinges ..
lots of play , so time for some new hinge pins .
had the hinges sitting in a pot of deluted hydrofloic acid over night
so it make sandblasting a little easier and heres the works ..
had to cut the pin , and punch it out
next , I had to drill the old hinges to fit the new bushings
both sides have to be done because , the pin is a little larger . File the " burrs " and install the new bushings .. The pin also has to be trimmed , because it was to long .
I "plug" welded the bottom of the hinge , for safty .. and a little primer ... DONE
just have to wait for the epoxy to cure .. and I can mount the door :)
CJM
10/11/09 07:14 PM
all excited , I went in this morn. to get the door mounted .. removed all the clamps , and connected up the door handle , bolted on the hinges .. and got the door back on
Marked the position of the mirror , drilled and "nutcerted"
and put the mirror back on
Very happy with the way it turned out .. when I trim the fiberglass panels , I always trim them LARGE .. so there is enough panel to make my own panel gaps . it's always easier to remove material , then to add it . So when I do the "final" body work , I will be able to sand down the door edges , to make perfect panel gaps
matts
10/12/09 01:24 AM
Are you making door skins for sale? 84 - 88? Tell us more about the hinge pins too. -- Matt
CJM
10/12/09 08:40 PM
Matts ..
yes , they are on the website + the 2nd gen door skins are comming very soon .. I have some rear 89-95 hi-clearance box skins hitting the market next , install comming soon !!
hinge pins are a "generic" set .. about $5.00 per .. and the should be avaliable at your local parts store
1986xtracab
(Mudrunner)
10/16/09 05:00 PM
how well do those nut-certs work? I have been interested in them for a while but don't know anyone that has used them.
CJM
10/16/09 08:53 PM
I love em' .. I have been using them for just about 30years now ..
so as mentioned .. center console is now mounted .. got the gauges in .. also started to re-do the dash again !!! I think this dash has been the hardest thing of all .. you look at it all the time , and I'm trying to get the "best" aesthetic value I can ..
I hope this is the last time !!!
CJM
10/17/09 07:42 PM
so .. done , well "rough in" anyway :)
I'm very pleased , and will be able to look at it for a long time .
I went with the /83 ashtrey , and the /99 lighted , cig lighter .
K_Raider
(Rock Warrior)
10/17/09 07:51 PM
I thought you were leaving the ashtry out? It looks great.
CJM
10/17/09 08:49 PM
I was .. and thanks by the way .. but since I removed the guages and installed them into the console , I had to fill the space with something !! .. I'm satisfied with the look now (3rd time), so I can now move on
RatLabGuy
(Rock Warrior)
10/22/09 08:19 PM
Ash trays are great for loose change and random screws anyway...
CJM
10/24/09 08:25 PM
thats what I figured as well !!
got everything in the dash "mounted" today .. made all the little clips and mount brackets .. and welded them all in place . so now they can easly be removed , but wont be falling out . :)
I have also changed my plan for the dash .. I wont be doing the woodgrain .. I'm going to paint the main dash and center console the "inferno red" , same color as the outside , with the cover/pad being grey leather to compliment the interior all the dash trim is going to be painted black
I now just have a few little dash lamps and such to wire , and I believe then , I am ready for the tear down
CJM
10/28/09 08:14 PM
passenger door "epoxied" and curing overnight .. also got a little more done on the wiring .. had to add and move a few plugs for the lighter and such also got all 4 accessory ports wired .. drilled and set into place . I want to add the cup holders to the console , and maybe a "pocket" as well ..
have some pics up tomorrow
CJM
(Body Damage is Cool)
10/31/09 08:02 PM
ok .. so I believe I'm all done the wiring now :) .... Finished up the guages (now green) almost time to sauder all the cinnections , and tape and loom .
also did the new dome lamp in the rear ,
and a "walk-in " lamp wired to the auto shut off lamp system , I will install it down in the foot area when the time comes .
kewlynx
11/01/09 12:09 AM
Nice- I like the gauge lighting. How is your parallex view for them? Looks like they're flushmounted instead of tilted?
Those other lights going under the dash then?
CJM
11/01/09 01:26 PM
very well actually .. I can see them perfectly .. the face of the gage in the housing is slanted a bit not flat and also the lens is convex making them much easier for this old guy to see :) . and the lamps for the rear .. very rear is a dome lamp , and the other is for the rear passengers , it will light up the foot area in the back , untill the door is closed , then in 15 seconds goes out .
CJM
11/03/09 08:34 PM
Re: sold the first one .. so this ones mine ... Trekker Build
Dash epoxied and ready for the final bodywork :)
CJM
11/05/09 09:17 PM
so today the dash bezzles .. hi-solids primed twice .. and sanded once. .. I'm STOKED .. so far , they look awesome !! :)
i'm hopin' to shoot some black on them this weekend ..
CJM
11/14/09 08:19 PM
dash is basically ready to go for paint and trim . I still have to finalize the gaps yet .. but basically done :)
here are the pics ....
also .. trying to get all the little things done , I built the console arm rest , got it hinged and front latch , also the limit strap done .. and now also ready for trim/covering ...
also working on the shifter boot mounting .. bent up a coat hanger into a square , and got it welded today .. figured out how I'm going to mount it .. just need to make some small clips ...
CJM
11/17/09 08:23 PM
so some pics of the shifter boot mount ..
here is the "ring" with the clips .. the shifter boot will be sewn to the ring , and the held down with the clips .. on to these studs .
kewlynx
11/17/09 08:52 PM
That's a clever little bit of fab dere!
CJM
11/17/09 11:04 PM
tks... gotta get all the "little things" looked after as well
CJM
11/26/09 09:29 PM
so .. not much going on .. but I have been collecting some parts .. got my front bumper finally :P .. (thanks to Adam )
also got my rear seats (thanks to Darren) I also picked up a stock 89 4Runner roll bar i'm goin to try incorporate in to the build .
also finally got my stock wiper blades and mudflaps (thanks to Paul)
thoughts for a rear bumper are leading to a 4Runner as well .. it has a straight bar with ends .. It has the "winch hole" .. but i'm thinkin' If I can get a banged up one .. I can weld up the unwanted holes , and have it re-chromed ..
and I think I have the rear licence plate lamp worked out .. I hate to think of it , but the 2008 Nissan Pathfinder has my perfect solution .
anyway .. thats where I'm at !!
CJM
12/05/09 09:16 PM
so I was able to get to the shop today to work on my own stuff (finally) ...
pulled the top off . and the outer fenders ... got the fender inners all cleaned up , and ready to repair the cracks and add the tail lamp pockets .
also figured the placement of the rear seats and then pulled the tub off
ready to start cutting that up
also started on the rear seats .. pulled the seat covers off of the bottoms , and got everything measured and figured .
the factory 4Runner width measures 51" .. max trekker width I'm going to make work is 42" which means I'm going to cut the tub and the seats to fit .
I have measured the seats and had to cut 4.5" out of the frames .. 2.25 on each side , 3" in .
got one done today
CJM
12/06/09 07:51 PM
started re-sizing the other side
so got it done ... this pic gives you an idea about the size i'm going for ...
and cut the tub , but didnt want to cut to much out in "one shot" .. so this way I can glass it back up and regain some rigidity
and a "test" fit
also .. started on the backs of the seats .. removed the covers and foam
and readied them for cutting .The backs are a different cut pattern , as they have the headrests .. I will still need to remove the headrest supports , and re weld them in the correct position .
CJM
12/08/09 08:05 PM
so had a little time today .. and got the seat backs cut and tacked also removed the headrest supports and the lock support ..
got the foams cut and glued
also was able to start on relocating the lock support ..
and cutting out some of the rusted old supports
CJM
12/09/09 07:45 PM
got the seat backs mocked up .. and i'm stoked :) ..
lines are perfect .
I'm hoping to have them work like the 4runner , with the bottoms lifting up , and the backs folding down .. so far so good .
also got some work on done on the fenders
repaired all of the cracks and lower lip + the holes previous owners have put in .. also got the new taillamp pockets in
RatLabGuy
(Rock Warrior)
12/10/09 10:57 AM
Wait - so this thing dosn't have a flip-down tailgate?
Seems that would be annoying to get things in/out.
Greg_Canada
(Roll Me Over)
12/10/09 07:33 PM
If you ever sell this thing... i think i'll have to buy it...
CJM
12/10/09 08:49 PM
I will sell it ... but not cheep 10's of thousands ...
actually , it's not so bad , as you can walk right up to the back of it and get stuff out , and not have to wory about reaching over a tailgate .. it really nice actually .. But i'm going to be building a small tailgate anyway , because I want to also make the roof removable like the 4Runners .. so I want to have something to continue the body line .
CJM
12/10/09 08:50 PM
wee bit more today ...
got the mount strips rienforced , and added a memorandum (my biz card) glassed in place :)
also got the seats all welded up .. with the locks
cut the top seat glass out to expose the rusted steel rienforcement strip .. and did some POR-15 to help prolong longjevity . hopefully i will get it glassed up tomorrow
CJM
12/12/09 12:36 AM
so .. postin the good with the bad !! (ugly pics)
continueing on , and almost done with the cutting ...
removed the wheel well and relocated it 2" up and removed 1" from the rear , and moved it forward , which will do 3 things ..
1. remove that .. n ... hump in the middle of the wheel well (stock seat ketch bracket)
2. create an armrest for the rear passengers instead of the stock 2" arm rest pad
3. allow a 84-89 4Runner roll bar to fit
CJM
12/16/09 08:06 PM
lots of grinding and sanding , gettin close to a finished piece .
wheel wells are now basically finished , little bit more to do . added/replaced the steel hatch support pieces , and glassed the old roll bar supports
also braced the floor as it looked like a washboard !! layed down a 24oz layer of woven roving , and then topped it off with a layer of 1.5oz mat .. floor should be flat again :)
kewlynx
12/16/09 11:07 PM
OOowwweee-- that's a lotta dope Corey. Lookin' good tho'. Bet the boys hope to see this thing in your will!
CJM
12/17/09 08:59 PM
yeah right !!!
CJM
12/17/09 08:59 PM
I was able to cut the 4Runner bar to the correct height
and test fit
also made up the base plates .
conserned about mounting the fiberglass tub to the frame and possably creating water leaks or even stress cracks i have decided to make a "flexable" mount . Poly performance makes a kit for this (thanks for the link Robb)
http://www.polyperformance.com/shop/Cage-Tie-In-Kit-p-433.html
but of course I will be making my own
kewlynx
12/17/09 09:04 PM
yeah right !!!
I figured that would tweak ya.
CJM
12/18/09 09:26 PM
yeah right !!!
CJM
12/18/09 09:27 PM
so .. my version ..
just now will need to weld the "feet" to the roll bar and then the frame supports
RatLabGuy
(Rock Warrior)
12/21/09 12:39 AM
So Corey I'm curious about something.
Given how much you have custom-fabbed thus far - why mess w/ a stock 4Runner rollbar, which you had to modify anyway, rather than making your own cooler/stronger one that may be a little less instrusive in that space?
Pyroboy
(Mudrunner)
12/29/09 11:02 PM
Awesome work, Corey! Haven't checked in for a while so it's great to see what you've done. Can't wait to see the Trekker on the road.
CJM
01/02/10 09:39 PM
so .. as we know .. the Trekker was the "proto type" vehicle for the 4Runner .. i'm trying to stay somewhat true to that , but with more emphasis , as we now have actual used 4Runner pieces to use . building one would be easier , but I actually want you to be able to look at it , and say .. "thats a 4Runner roll bar "
hope that makes sence ?
thanks bud .. got your email while I was on holidays .. I will try to answer asap
CJM
01/14/10 08:31 PM
been going threw withdrawls not being able to work on my Trekker , so I have been going back after the shop has closed , to get some work done ...
so working on the rear tub as well , I "attached" a 2x4 to the outside to level the mounting flange (substraight)
re-glassed-- adding 2 layers of 24oz woven roving + 5 layers of 1.5oz mat .. basically , this will make it stronger then the original steel that was in there + it should last and not rust out like the stock one !
2x4 substraight removed and flange trimed
and now the sides and topper back on for body line adjustment ... OMG sometimes I even amaze me .. it's perfect and need NO adjustment .. i'm super happy with it ....
kewlynx
01/14/10 08:58 PM
ooooooooooo baby; it's startin' to look like a TRUCK!!!!!
Nice way to head into the weekend!
CJM
01/14/10 10:05 PM
yep .. thanks ...
Workin' on it this weekend ...
hope to finalise the rear cab suport and "tack" it into place
this is my goal !!!
CJM
01/16/10 07:34 PM
got to work on the rear floor crossmember today :)
welded and bent up the pieces I need , and got it "built"
Tacked into place for now , untill I "blow" it all apart again for paint , I will then finish all the welding .
if you compare the previous pics of the seats , you'll notice the seats wernt level .. but now with the rear floor support in , :)
and Now .. I can finish the rear tub !!!!! ;D
heres the start
CJM
01/17/10 07:41 PM
yippie .. I have a floor ;D
some essential pieces for the mock up ..
corrugated plastic , an LGD , and the fiberglass trany tunnel I made way back when ....
and some fiberglass
CJM
01/18/10 09:24 PM
mock up today of the rear seat area .....
rear seats "loosly" fit in to place .. time to start on seat belt location + some extras ....
seatbelts and roll bar are going to be tied into the support frame (all trekkers have em) that I will be custom building .
a look at the rear seats in position as well as the new wheel well/arm rest .
Staceman
01/19/10 08:55 AM
Makin' progress now! Coming along fantastic !!
CJM
01/20/10 09:58 PM
rear backs are now installed .. I want to still make them lay flat .. easy fix .. and that will come soon , but for now ..
trcdrunner
(Mudrunner)
01/20/10 10:30 PM
AWESOME build...
Wish I had the time, the resources and the SKILLS!!!
CJM
01/24/10 08:50 PM
thanks
CJM
01/24/10 08:50 PM
little bit done today
started on the frame to support the tub , and tie into the roll bar and seat belts
started with building the main supports .. and yes the tops are NOT level . This is due to the uneven fiberglass floor .
ready to go (4 built )
starting to "piece" it all together
drivers side
passenger side is different , because of the fuel filler tube .. had to be routed over top .
all sectioned together and ends plugged ...
I have too very strong mounts
and mounted
still have to build the cross bars ... But it will have to wait till after I pull the tube off for rienforcing ..
the glass will add to the thickness of the tub , so I cant build the final floor support untill the tub is done ..
CJM
01/30/10 10:59 PM
excellent day ...
got my check list done...
feet welded on the bar
and my goal today was to have the seats basically done..
I have welded the locks and covers .. (you can see in the pic)
lock button supports welded
headrest supports welded
seat back cushions "carved" and fitted
also got the roll bar mounts done.. well tacked anyway ...
I decided I didnt need the "swivel joints" anyway .. the sub frame is mounted on rubber bushings , and the whole tub will flex as a unit .. good to go !!
also started work on the rear tub member ... I dont think the thickness of the glass will be a problem , as the underside on this section is almost done anyway ..
still have to weld it ... but heres were I finished up the day at
sorry for the crappy pics... my "good" camera took a dive for the worst .. so i'm dealing with my phone for now ..
CJM
02/03/10 08:24 PM
got a wee bit of work on the rear lower seat hinges today ..
I took the original 4Runner lower seat hinges and cut them down
then welded up 1 of the brackets .. tacked them on .. and did a test fit .. COOL !!! it's going to work awesome :)
CJM
02/05/10 08:10 PM
1 more thing buttoned up today ...
made some "pockets" to seal the seatbelts from the elements ..
how the seat belt fits !!
and installed
CJM
02/07/10 07:43 PM
some work on the seats today ....
got the hinge holes welded up , ground and sandblasted again :)
all welded to the seat frames ....
and installed
and working awesome :)
also built a "locking" post for the seats .. so they will work like factory
and installed
and working great ... took some time to build this and make it work properly ..
I also started the new front kick panels .. little sneek peek
Staceman
02/09/10 08:44 AM
Coming along great Cory
CJM
02/11/10 08:45 PM
CJM
02/11/10 08:46 PM
ok .. so a little work on the door today ..
got the old original unit stripped and in pieces
some measurements for location refferance
and the main frame re-welded and sandblasted
also while the frame was in sandblast .. I worked on polishing the window alum. piece .. as some may remember .. I'm going with a strong chrome theme :) . ....
CJM
02/12/10 08:39 PM
got some epoxy on the steel .. and some hi build on the plastics :)
i'm going to make a mould of the inner plastic trim .. fiberglass will be stronger and easier to repair if necessary .. I dont know why Winnabego didnt do this in the first place ?
anyway .. a pic
CJM
02/17/10 08:04 PM
one of the last pieces I have to make .. kick panels ..
so I have now done a little bit more work on them .. because of the body computer on the drivers side , and the computer on the passenger side .. stock would not sufice any more , so as in the previous pic , I made a template , and built it to fit .. primered , and being sanded .. almost ready for moulds ..
RatLabGuy
(Rock Warrior)
02/18/10 09:40 AM
Corey, what substrate do you use for making those molds? is that clay?
CJM
02/18/10 10:29 AM
nope it's gelcoat ..
made a flat fiber piece as shown a couple of posts up , glued some wood pieces , and filled with bondo .. and gelcoat to sand ..
CJM
02/22/10 08:34 PM
so a little time for a wee bit of work on the last bits ..
I have finished the moulds for the kick panels .. hopefully tomorrow , I can start making me a set ..
also working on the rear hatch trim panel mould ..
CJM
02/25/10 08:20 PM
so , kick panels are done.. I was only able to "fit" one side because I need to finish up the wireing ..
but here's what they look like ..
and installed
and I also decided to get a NEW hood .. just because everything else is new :)
Staceman
02/26/10 09:55 AM
This rig is gonna be Gorgeous! Can't wait 'till she's finished.
CJM
02/26/10 08:45 PM
thanks .. actually gonna start the teardown for inner paint tomorrow .. gettin' close :)
Bent_85
(Getting the Wheeling Fever)
02/27/10 02:07 PM
Excellent Build!
Can't wait to see when its done!
PS I'm the 33333 viewer!
CJM
02/28/10 09:21 PM
and so .. The body work begins ..
started at the front .. with the bumper .
becuse of the 1" body lift .. the front bumper didnt quite sit right .. so I made some 1" extension brackets and welded them to the bumper supports .. legthed some spacers for the other mount .. and viola .. front bumper done ..
CJM
03/03/10 10:17 PM
body work has started ..
little time today to work on the valance..
I wanted a custom piece .. reasons are .. well I just have sooo much time !!!!!
the original center mount is no longer there , so holes would be mute and I dont like the transision between the side mounts
so the plan is .. to use a 2WD valance .. (it has a deeper center and also lines up with the grill ends .. beauty body lines ) The 2WD valance mounts differently , and is also shorter , and also has a center support ..
so .. heres the start ..
cut off the center support .. and "bent it" to fit better ..... :)
I will also get rid of the mounting bolts .. and have a "smooth" trasition between the valance and the fender .. hammered a new piece to fit ..
CJM
03/05/10 08:50 PM
continueing on with the valance ..
I finished up welding the end pieces on , and a little bondo .. and a first coat of primer .. still lots of sanding and finishing .. but you get the idea .
I will be making a mould for it ... as the fiberglass will be less flimsy
also finished up the rear hatch cover finished today :)
VERY happy ... and WAYYYYYYYYYY stronger then the flimsy plastic piece
kewlynx
(Toyota & Classifieds Moderator)
03/07/10 08:28 PM
Am just goin' 'wow' all the way Corey. Holy bats!
CJM
03/08/10 10:04 PM
so continueing on with body work and finishing ..
I took apart the rear seats and readied them for new covers .. and "buttoned" up the modifications to the supports and levers .
cut and welded .. and sandblasted , and zinc'd .. ready for some color
also tore apart the front bumper that took me a year to find..
got the supports and underside of the filler panel sandblasted and cleaned up .. ready for some POR-15 to seal .
and done
also cleaned up the inside of the bumper , and scuffed the chrome , and zinc'd
and polished and buffed , and waxed the front ...
almost ready to put it back together , just need some color on the topside of the filler :)
CJM
03/11/10 08:50 PM
popped the new valance out today ..
I like it ...
also POR-15's the fender/valance mounts , as well as a bunch of other stuff .. but here's those pieces
Teardown is continueing
time to remove the wire harness
CJM
03/12/10 09:24 PM
started working on the doors and inner trim panels .. got the inner of the doors cleaned up , and just about ready to prime .. also started on the trim panel
started with a flat sheet of fiberglass
marked it and trimed it to fit
I was going to have it 2 seperate pieces , like the stock panel , but my "mid speakers are to big :) ... there is a small "step" in the door panel anyway .. so cutting it and re glassing it will achieve a perfect fit with NO rattles .
starting the "mock up" for speaker location :)
CJM
03/13/10 08:52 PM
so .. waiting in the shop today (my day off) for a customer to show up for some pieces .. I decided to clean up the headlamp buckets and mounts ..
dissmantled them .. and did some sandblasting
and all the regular cleaning .. and such .. and some POR-15 on these as well .. also while I was at it , I polished up the headlamp rings and hardware :)
CJM
03/14/10 08:29 PM
not much to add ...
got the headlamp bucket and pots back together
and the power went out ..
ended my day early
CJM
03/16/10 09:17 PM
got a little work done on the door panels the last few days .. building the speaker enclosures has been the most time consuming , but should pay off in the long run .
Instead if just cutting a hold in the door and mounting the speaker on top , I wanted to "enclose" the speaker in it own "pod" so the sound coming out of it is just that much better .. so I was thinking on how to do this .. building custom moulds would take to long .. and i'm really wanting to press on !!!!
so I decided to start looking for a mould already build which I could utalize .. started pulling bowls out of the cupbords and measureing for size , looking at all kinds of things I could use , even went to wallmart and searched for aplicapble forms . I ended up going to the dollar store , and finding a perfect size plastic dog dish for $1.50 and a smaller cat dish for $1.25 .
started making my pieces ..
so I have 4 mids and tweeters going in .. 2 front 2 rear .
I needed 6 bigger pieces , and 4 smaller pieces ..
so after I figure the speaker placement .. started to fit it all together .. cut the door metal to fit the "pods" and glassed the rear portion into place
cut down and prepped the new set of moulded pieces to fit the speakers
and all mocked up
ready for some foam and leather to finish !!!
should rock :)
CJM
03/17/10 08:54 PM
did a little clean up on the wiper motor at lunch time today ..
pulled it apart and cleaned everything up
didnt have to paint anything .. except the alum. housing.. and the assy. screws.
acid diped and then bead blasted .. and then clearcoated
all back together ..
CJM
03/23/10 08:50 PM
little work on it today
I was able to start stripping everything out of the cab .. prepping to remove the cab for inner paint ..
Wire harness is also now out .. so I can finish with saldering the joints and loom/tape .
and a little look see of the pieces stripped from the truck
RatLabGuy
(Rock Warrior)
03/23/10 09:20 PM
So what is your plan with the rear topper? It's not really designed to come off, is it? Will youglue/glass it in, or make it removablle 4Runner style?
CJM
03/24/10 10:58 AM
I was going to "make" it removable .. but i'm running out of time .
RatLabGuy
(Rock Warrior)
03/25/10 10:12 PM
Running out of time?
it's already been, what, nearly two and a half years? What's the hurry now?
CJM
03/25/10 11:19 PM
3 years ..
this is the "time limit"
unfortunatly , I have not had the time to do some of the things I wanted to do ..
I have other projects in the "line up" waiting to get there time in the shop as well .. so it's time to wrap the trekker project up and move on
CJM
03/26/10 08:33 PM
so the rear tub has now been removed , so I can now finish the glass work .
Tub support also removed , and I was able to finish the welding on it some POR 15 and it'll be done and ready for reinstall
engine bay is almost stripped ..
cab is almost ready to come off :)
CJM
03/27/10 02:04 AM
so friday night TV .. no good shows and board so back at er'
a pic of the tub .. ready for the final cut outs and glassing..
also POR'd the rear frame support and other goodies :)
and started on the wire harness ..
CJM
03/29/10 08:43 PM
some work on the weekend I neglected to post ..
wire harness is comming along :)
also today , I got the tub trimmed up , and basically finished the topside ..
bkg
(Roll Me Over)
03/29/10 08:52 PM
Corey -
Been wanting to ask for a while. How is the 'glass box attached to the cab? What will keep it from flexing at that joint and cracking?
thx!
CJM
03/29/10 10:11 PM
as with the winnabego mounting .. it will be "mechanically" fastened .. the differance is in the rubber mounts and the frame I have made , The rubber mounts are a soft /flexable "puck" which will allow the rear tub to flex with the cab ..
however , only "real time" testing confirm ( I hope I'm right :) )
CJM
03/30/10 08:23 PM
got the speaker holes sealed , and the seat belt covers on ..
also got the bottom of the steel rienforcement exposed .. cleaned and POR-15'd
built the jack, tool and GPS box built .. (hidden under the seat when done)
and will be ready for FINAL glassing tomorrow ..
CJM
03/31/10 08:24 PM
yaah !!!
got the tub all done today ...
floor is rienforced w/24oz woven and a couple layers of 1.5 oz mat
storage box is also done ..
also got the floor welded .. and now I can remove the cab to finish up all the grinding and welding underside
I want to get the body work VERY close to completion .... so I want to keep the cab on for a bit yet
kewlynx
03/31/10 10:37 PM
Solstice run for the maiden voyage Corey!!!
CJM
04/10/10 09:06 PM
dont know !!
CJM
04/10/10 09:07 PM
got the front valance mounted ... now I can do the final body work on it ...
also got a bunch more new pieces .. outer door handles and locks .. I will be sending the locks out to be all re keyed to the ignition .. so I will have 1 key.
also continueing on with the harness ..
looking good , although you probabally cant tell by the pic ..
getting close to being finished ...
CJM
04/17/10 10:54 AM
so finally got the rear tub mounted ..
I used bolts for now (mock up) .. and I will be replacing them with elevator bolts for the final product . just like these
heres the floor
and the side wall
i'm also mostly done the body work , so now its time for the cab to come off :)
stock87
04/17/10 02:32 PM
It may be a little late for this, but might I suggest adding a removable panel under the back seat for fuel tank access, like the later 4Runners have? Seems like it might save some headaches down the road.
CJM
04/17/10 08:40 PM
dang dude .... thats an awesome idea , I wish it would have been suggested it earlier
Thanks , I'm gonna still try incorperate that idea ..
CJM
04/17/10 08:43 PM
more work on the harness today ...
Finished up the main dash harness ... and ready now for install
here's the rest of the pin-outs and scrap I further stripped
and now 1/2 done the engine harness ... :)
CJM
04/18/10 08:26 PM
front engine harness is now done as well :)
also started on the vent windows..
i'm tinting the windows , so while I was at it , I figured I might as well clean up the frames (there was a little rust)
so all sandblasted , and ready for some epoxy
CJM
04/30/10 08:02 PM
ok .. so cab back off.. and now almost ready for some color :)
just some welding and prep. first
CJM
05/01/10 08:55 PM
continueing on .. and excited for it's coat of color ...
I welded up a bunch of unwanted holes on the firewall and got all the new nuts installed to make the pieces "boltable" .
also working on the tranny tunnel ..
got it cut and ground
also started to attach some of the "hold down studs" for the emergance brake cable .. still have to do the rear heater line hold downs .. I used these pieces , and just drilled holes to plug weld them in place ..
got lots of the welding I wanted to do .. but I still have a bit more ..
CJM
05/03/10 08:38 PM
got my tank filled today .. and continued on ..
got lots done .. but was slowed on finding 11x1.25 mm nuts for the seat belts .. crap , I forgot all about it !!
I ended up spendin 1/2 the day looking for these stupid little nuts , finally I went to the wrecker and "knocked" some off with a hammer and chistle ..
so anyway .. made some backing plates for the seatbelt and seattrack bolt down nuts ..
and got them welded ...
just about ready to seal up the underside and give it some BLACK ...
CJM
05/04/10 09:30 PM
I have finally finished up the welding .. another tank of ARGON was spent finishing up .
just a little body work left to do .. and off to inner paint ... :)
hope to have it in the paint shop by friday
kewlynx
05/04/10 10:06 PM
To your tenacity Corey!!
trcdrunner
(Mudrunner)
05/05/10 01:04 PM
Still gotta say.. WOW!!! Cant wait to see it finished... SO whats the other projects in line??? Anything this big??
CJM
05/06/10 10:59 AM
almost ready for inner paint ...
yes , i do have another project in the wings .. I actually started it before the Trekker , so I'm very anxious to get back on it ..
full custom frame
CJM
05/06/10 07:49 PM
still prepping for paint ..
got the firewall all cleaned up .. found a wee bit of rust , but soon got that dealt with
cleaning up the firewall
all wire wheeled , and cleaned
scuffed and zinc'd
also got the underside scuffed and zinc'd
the topside and bottom side wil be "sealed" in the paint booth ...
ant last but not least .. I POR-15'd the inside of the rockers , cab corners , and cowl ... I was able to scuff the rockers and cab corners when I had them apart .. the cowl I was not able to ..
I dont know how well the POR will work in the cowl , but I figured It would be better then nothing
and YES .... tomorrow it goes to paint the inners :)
RatLabGuy
(Rock Warrior)
05/08/10 01:03 PM
OK.... so "tomorrow" is over, I'm dying for the pics!
CJM
05/08/10 08:28 PM
your gonna have to be patient ..
CJM
05/09/10 11:39 PM
buttoned up the Power steering lines today .. but found my return line just a few inches to short .. I'll have to replace that !!
originally , there was /is a bracket for the Main power wire for the starter , housed in a white plastic surround , just around the face of the oil pan ... I wanted to keep it , so I made up a new bracket for the wire casing to "clip" to .. as well as a support for the P/steering line
CJM
05/10/10 08:38 PM
pic I forgot to post ...
anyway , the last thing i had to do before the inner paint .. was the new windshield washer nozzles ..
now located on the hood ..
holes cut
and nozzles installed
I also finished the underside , I made the holes for 3 washer hose clips ..
and thats it for now ... deliverd for some color
matts
05/11/10 01:24 AM
Is that your second gen xtra cab? The one with the grey doors and the white bed? Man I love those. I just retired mine and I want another, but the '89 4runner and the '93 xtra cab are all the Toyota 4x4's I can justify right now. Someday though. -- Matt
PS Nice work.
CJM
05/11/10 08:52 PM
yep .. it's the shop truck + my curent DD .. used and abused :)
not much to add ..
couple of little things .. + got the P/S return line replaced ..
trcdrunner
(Mudrunner)
05/13/10 10:26 PM
I remember the part supra part mini truck... all monster.... Still cant wait for the trekker thou... BTW U R A MAD MAN
- Nice work
CJM
05/14/10 08:45 PM
thanks .. me to .. I'm stoked to get the trekker finished ..
so a little bit today ... now that the cab is in the paint shop .. I needed to paint some pieces myself..
satin black
CJM
05/15/10 08:41 PM
and the dash bezzles :)
same satin black
CJM
05/20/10 07:58 PM
I checked in on the paint today .. and it will be " hi-build" primered tomorrow :) and then inners will be colored next week I hope ..
CJM
05/23/10 08:09 PM
so a little bit more today ...
got the alignment done , and locked down .. steering damper is also now attached ..
replaced the spark plugs with a heat range lower and platenum tipped ($80.00 bucks) and also a lower temp 170* gates # 33867 thermo .
front drive shaft is now in the works ..
some cleaning and POR15 in the works ...
on the front part of the drvshaft .. under the u-joint , there is a plug ... I have misplaced the size /part #
anyone know it ?
kewlynx
05/24/10 02:01 AM
Plug or a zerk fitting?
CJM
05/24/10 11:27 AM
plug ..
CJM
05/24/10 08:25 PM
got everything back together today . I checked some of the aftermarket stores today, for the dish style frost plug and had no luck , most wern't open today because it was a holiday , so I ended up taking the plug out of an old shaft I had from another truck that I parted out ... I "miked" it .. and was 34.25MM .. if anyone is ever interested..
anyway .. I install the plug , and cleaned and washed and prepped for the POR15 coating ...
Chassis is now complete .. (once I bolt on the front shaft) ... only thing left to do is the Gear oil ...
everything is done :) and ready for the cab
CJM
05/27/10 08:49 PM
ALL gear oils changed today ...
also picked up the locks .. ALL were re-key'd to match ..
i'm ready for the cab !!
CJM
05/29/10 01:03 AM
worked on the rear door today while my boy was at ball practice ... no I'm not coaching this year!!
fit the new inner cover .. and also glued the rear door skin back on to the frame ..
also painted the shifters ..
cab should have been primed today .. I guess I'll see on Monday
CJM
06/05/10 11:30 PM
well I was able to slip down to the bodyshop to snap some pics today before my sons double header ball game ..
pics dont really do it justice , but I will say , it's looking real good so far , and the time I spent makin' sure things were "right" , are paying off I think .
little bit of and issue with the drip rail area , as when I welded and did the "prep" work , I squared it off , instead of rounding the edges .. and when we looked at is in the body shop , I asked him to "round" them , so it would match the rest of the truck .. well when he did , he ended up grinding threw some of the welds creating pin holes , so then he had to weld them up and continue from there .. all and all ... I'm STOKED !!!
and now just a "scuff" on the inners .. and some color .. I made him promice me , done by TUESDAY ... :)
and on the way home from ball ...
a little 2 point buck in velvet "picking" in the front yard gardens .. my boy and I followed it all the way up the block ..
kewlynx
06/06/10 08:14 PM
Corey, is that a white or cream color? Looking like a nice paint job so far.
Healthy-lookin' critter there.
CJM
06/06/10 08:29 PM
it's a light GREY , hi-build primer .. it "blocks" down to 320 real nice , and ready for a "wet on wet" INFERNO RED
you'll see !!!
CJM
06/08/10 07:27 PM
no call on the cab yet , but I am expecting it any day now .. so I have been continueing on with other stuff anyway .. I sprayed some hi build primer on the console , sanded and prepped , as well as the dash and rear hatch cover ... got them in FINAL color today .. :) All ready to install
(Roll Me Over)
06/09/10 10:03 AM
This is damn cool. The anticipation is killing me...
CJM
06/10/10 08:28 PM
thanks ..
checked with the painter .. still NOT done , I was BUMPED again !!!
RatLabGuy
(Rock Warrior)
06/10/10 11:15 PM
thanks ..
Did you tell him there are people spread all across N America waiting to see this finished?
CJM
06/14/10 09:16 PM
I did , but hes just small business guy like me .. and I know just how it is .. I really hate to pressure him .. so i'll wait .
so I stopped in today and he has them now all "scuffed" .. and suggested color either today or tomorrow .. I guess we'll see
Greg_Canada
(Roll Me Over)
06/14/10 10:17 PM
So it may be painted by friday is what you're saying (lol)...
I can't wait to see it.. should be great... i really wanted to shave the drain rails when i did mine but no time for it... i swear if you have yours done before mine... LOL....
CJM
06/18/10 08:24 PM
so my customer showed up , and I "wrote up" his truck for the work he had booked .. after his truck was in , I drove him to the bus depo. for his ride home .. I decided to stop into the bodyshop as it's real close to the bus depo and lookie what I saw :)
I caught my painter in the booth shooting some color ...
he was just finishing up the color , and came out .. we chatted for a bit and hes asked if i wanted a better shot of the color .. NO clear in these pics , cuz he was just doing it ... and I couldnt wait
It'll be cleared now , inners all done and ready for me to pick up ...
CJM
06/19/10 05:17 PM
so out and about today , I had to stop by and see it with the clear on .. and out in the sun showing off :)
Greg_Canada
(Roll Me Over)
06/20/10 07:55 PM
Looks beauty but... did he miss painting the cowl and windshield frame?
CJM
06/20/10 08:33 PM
thanks .. and no ..
these are just the inners !!
so now I can put everything back together .. and THEN shoot the outside in color .. you'll see :)
CJM
06/24/10 02:21 AM
got the bottom undercoated and my "custom" heat shield on
kewlynx
06/24/10 08:16 PM
OOOOooooo-weeee, you weren't kiddin RED.
That'll getcha pulled over!!
CJM
07/01/10 08:49 PM
so ratzzz .. I forgot today was a "holiday" so no sound deadner and no fork lift .. but I did get a couple of things bolted ..
stock87
07/02/10 12:41 AM
So what product do you use for the heat shield/sound deadening (foil stuff)?
kewlynx
07/02/10 01:43 AM
That looks like Reflectex to me; you can get it from Home Cheapo. My questions:
How do you have that adhered on there?
You've got the core support set up to unbolt it, rather than grind the welds off now, correct? If so, stick a couple arrows on there so we can see how you bolted it on.
I see ya got a pile o' $$$$$ sitting to the right there.
Good for you Corey!
CJM
07/02/10 07:25 PM
it a "specific" product from DEI or DEA or something like that ... I just spent 1/2 hour trying to find the post .. its there some where, where I bought it , I just couldnt find it for you .. but I will find it .
It's a special piece of heat shield 2' X 2' pieces was ~ $24 bucks .. I cut it , using my own template , and with its "self adhesive " backing .. just peal and stick .. little tougher then it looks .. this took about 3 hours to do :)
Good for you Corey!
yep , big pile of cash sitting right there :) .. all ready to crate .
only the center "triangle" un-bolts .. you can see the new hardware in the pic .. 1 to the hood latch , 2 to the lower rad support ..
CJM
07/02/10 07:57 PM
yahoo .. cab on :)
CJM
07/03/10 01:00 AM
DEI .. some of there other products I bought .. I used this tape to wrap some heat sensitive wires ..
CJM
07/03/10 08:49 PM
here is is on the frame ..
got all the brake and fuel lines hooked up also did some looming today ..
(Roll Me Over)
07/03/10 10:48 PM
Truly a work of art! I can't wait to see it finished.
CJM
07/04/10 08:30 PM
thanks .....
got most of the engine bay buttoned up ..
hopefully the sound deadner will show up soon .. as I now cant go any further untill it does
Greg_Canada
(Roll Me Over)
07/04/10 11:07 PM
Lookin good corey, that red is gonna look killer.
BTW some nice sound deadening is made by "Second Skin" and they offer deals sometimes to diymobileaudio.com members...
CJM
07/05/10 09:08 PM
thanks bud .. but alread have the product "happening" ..
went with your former recomendation on the b-quiet product ..
Greg_Canada
(Roll Me Over)
07/05/10 11:15 PM
Cool, i hear the b-quiet is nice for the price, and it's made in canada. cant wait to see this thing put together, probably the nicest trekker on the planet....
RatLabGuy
(Rock Warrior)
07/06/10 08:28 PM
How much of it is still Trekker?
CJM
07/06/10 09:56 PM
it's now a Precision Trekker ... but will still carry the winabego decaling
CJM
07/06/10 10:00 PM
well I finally got my sound deadner .. and got a bit done .. WOW , this is maticulas work , and takin' alot of time !!
and now have the pedals back in so now i can finish up the engine bay
CJM
07/08/10 09:10 PM
finished up with the sound deadner (firewall area) .. so now I can finish up the dash and engine bay wiring
CJM
07/09/10 09:57 PM
one of the last things in the engine bay "to do list" is the front emergency cable ..
got it all cleaned up - put together
and installed :) with final connections .
also started on the body harness .. got it in place .. and now installing the little circuts lke the door switches , dome lamp ect..
engine computer ..
and body harness
almost ready to start looming the wires ..
also got my dash pad back from the upholster , I'm very happy with it and now very excited to get the dash in place :)
69442
(Rock Warrior)
07/10/10 12:07 AM
If they were only built from that factory that way!!
Nice work ...
CJM
07/10/10 09:00 PM
Nice work ...
thanks ...
so continued working on the wiring today ..
got the passender side all wraped and sorted .. and fit the kick panel :)
Drivers side kick panel also installed after cleaning up the rats nest :) + the hood release cable
and also got the main wire bundle loomed
wired and loomed the underside
and ready now for the heater box and main dash body :)
Rodgertheshrubber
(Rock Warrior)
07/11/10 08:34 PM
this is really amazing! your attention to detail goes WAY beyond my level of comprehension! Awesome, awesome job. i am really inspired to try not to take so many short cuts on my rig in future projects! thanks a million for posting all of this. where are you going to post the build for the next project?
CJM
07/11/10 08:55 PM
thanks a bunch .. glad people are getting something from it .. this was the point , as well as letting people know of my company and what I do :) http://toyotafiberglass.com so - you to can restore your truck
2WD PROJECT(and comming soon) will be posted on my Trekker board as well as my 2WD specific board .. I know this really is not a 2WD board , but, I will most likely post here as well if people want ?
CJM
07/11/10 09:04 PM
so wanting to install the heater box today .. and looking at it , thinking - "I cant install it this dirty" , so I decided to clean it up ..
so I dismanteled it carefully
and started cleaning
heater core was very dirty and full of leaves and bugs .. so I'm glad I did this ..
got everything cleaned and painted .. and ready to put back together
and some new foam tape
and it goes back together
and ready to install ..
and installed ..
RatLabGuy
(Rock Warrior)
07/11/10 09:09 PM
It's an old Toyota truck, seems fitting enough for me!
If the build is anything like this, I'd love to watch.
kewlynx
07/12/10 01:19 AM
Corey, there is no question in anyone's mind that your build, talent and work ethic all going into this keeps us inspired.
Thanks for sharing your spare time with us!!
Rodgertheshrubber
(Rock Warrior)
07/12/10 06:33 PM
if you decide not to post the 2wd project here, can you post a link to where it will be? thanks again for sharing this with us
CJM
07/12/10 09:47 PM
thanks guys and GAL .. I will .. when i get going on the 2WD again , I will post it up here
CJM
07/12/10 09:49 PM
continued on the heater and dash ..
got the rest of the plastic vents cleaned
and all installed
installed the dash and some other pieces ..
and then installed the new cover .. i'm not happy with the fit now though , as the "gluing" of fabric undernieth has made the dash pad "sit up" higher then it is supose to :-/ .. I just need to talk to the upholstry guy , but i'm pretty sure I can now trim the excess fabric undernieth off now , and make it "fit" as it should ..
CJM
07/13/10 10:28 PM
couple more pieces done today ... :)
painted some satin black and some interior grey
cleaned the last of the heater pieces and re-foam taped the seat area .. and installed
also re assembled the mid vent .. and installed
and had a few more mins , so I assembled the center console and decided I really wanted to see it in place :)
Andy87
(Wheeler)
07/17/10 01:33 PM
The scope of this project is amazing. Most of the time I check this board it's simply to see updates on your truck. Keep up the good work... it's looking awesome so far.
K_Raider
(Rock Warrior)
07/17/10 08:50 PM
Same here. Looking great.
CJM
07/18/10 07:13 PM
wow .. thanks guys .. encouraging words
87Montero
(Trail Leader)
07/20/10 10:28 AM
This is great watching this come together, keep up the good work. We're all watching.
CJM
07/21/10 09:09 PM
yippi !!! ;D got the tub on PERMINANTLY ..
did a bit of undercoating.. easier , and (I think) better job to do it now ..
and the frame and supports
and mounted ..
anyone need a G58 ? :)
CJM
07/22/10 10:10 PM
little bit more today .. I'll let the pics do the talking
Now i get to "map out" the sterio and GPS + rear back up camera + finish up the dash :)
CJM
07/23/10 09:55 PM
little more today .. some "finishing up" ..
got the roof done in the sound deadner ..
also , although they will not be seen or anything .. I sealed up the bare metal of the seats .. heres the backs
also .. got he dash pad back from upholstery guy ..
fits much better , and got the dash and switches and such in ..
I wish the glove box door would fit these units better .. I might just take the door off and "build it up" to get that gap better ..
Upholstery guy is comming next week to install the new carpet
so , now , tomorrow I have to lay out the wiring for the sterio , GPS and such ..
CJM
07/24/10 09:11 PM
so pulled the sterio stuff out today , and started the "layout"
and unpacked , and set in position
and ... seriously ? wiring again !!
still have most of the GPS to do , and I didnt get my back up camera yet .. but gettin close to done with the other stuff ,
gonna start the sub box next week
RatLabGuy
(Rock Warrior)
07/24/10 11:11 PM
Why not put the amps under the seats so you don't lose the cargo space in the back?
CJM
07/25/10 11:32 AM
not enough room , + here in the summer , i'm positive they would overheat . building a box , and with the rockfords I got , it is a min size box necessary so I can put the amps , fuse block , and crssovers all on the box .. box dimentions are 40" X 12 " X 8" wide .. so all in all , I wont loose to much space
Greg_Canada
(Roll Me Over)
07/25/10 12:47 PM
My amps overheat if i cover them up (unless i run cooling fans)... under teh seat would be OK if there is enough flow over them... but when they're in the sun they'll overheat
CJM
07/29/10 07:37 PM
so as I mentioned .. steering wheel is in ..
I also bought one of those cheep car covers off of ebay .. it's suposably for a 4Runner .. its basically a generic cover , but I figured with the interior and electroncis going in , and my shop being so dusty .. It might be a good idea ..
also .. got the SUB box mostly done ..
bkg
(Roll Me Over)
07/30/10 12:20 PM
any idea how much weight was added with the sound deading material? curious only.
CJM
07/30/10 09:15 PM
shipping weigh bill says 38 LBS ..
CJM
08/02/10 08:37 PM
so with today being a long weekend I was able to get a little more done on the sub box .. Friday I gel coated it .. about 40mils thick .. so I could sand it down smooth .. this will "seal" the wood , so I can continue with paint..
sanded , and prepping for some "hi build " primer
shot with the hi build , and ready for some sanding
and finally .. I decided to go with the interior grey of some of the interior plastics , dash base , center console ...
should be all cured and ready for the subs , amps and crossovers tomorrow :)
CJM
08/03/10 08:39 PM
and put together
front side
and back side
masheen
(Need a Spot)
08/06/10 08:52 PM
Just curious Corey, but from the pix you posted, I don't see any air ports in your speaker enclosure. As far as I know, speakers gotta breathe. I built 6x9 enclosures for mine and drilled a 3/4" hole in the side of each. I have no idea what size hole is best suited for a given speaker size. With my stereo cranked up, the air that gets pushed through the hole is pretty substantial! Yours will push much more and if there's no where for the air to go, your speakers won't move like they should and the sound will suffer. Just my opinion, but I could be wrong...... I'm with many others here; great build and awesome documentation on your build! You could write a book!! LOL
Elbow_Greese
08/07/10 09:04 AM
What Corey has there are sealed enclosures. Makes for a tighter bass, cleaner sound, but as you know, not as loud.
As long as the volume inside the box is correct, should sound very nice!
CJM
08/07/10 10:44 AM
correct .. not going for "loud" .. but crisp nice sound , something to listen to or my passengers can watch a DVD , on those long trips to the car shows :)
I measured up the box and took it into my "sterio guy" and the subs are what he recommended for the box/volume .. no ports , no partitions
I do have to remove the power block from the box though , as it is to close to the crossovers on the l side , I'm sure it will create unwanted noise if I dont
Greg_Canada
(Roll Me Over)
08/11/10 11:15 AM
Speakers you want to be sealed up (will make the lows sound better and give them better power handling).
Subs can be either or, i've got mine in a ported box right now but i dont like it that much, want to go sealed.... it sounds odd at certain outputs...
Power Block isn't in too bad of a location, You should... be fine.
masheen
(Need a Spot)
08/15/10 08:31 PM
Thanks guys, you educated me! I'm gonna get a couple of 3/4" plugs for the port holes I made and listen for the difference in my system.
CJM
08/15/10 08:33 PM
so yippieee ...
carpet install started ...
underlay down , and finished ..
and carpet started
and now removed for sewing ..
should be back in tomorrow for good :)
(Roll Me Over)
08/16/10 02:05 AM
So, THAT's how it's REALLY done...
That's talent!
chpfx
08/18/10 07:22 PM
Hey Cory the treker is coming along great, however I was wondering why didn't you have the bed blasted and painted before mounting as you did the cab?
CJM
08/18/10 09:00 PM
Thanks guys ...
chpfx - I didnt "blast" the bed because it's fiberglass . Sandblasting fiberglass is never a good idea as the media has a tendancy to imbed it's self into the panels .. i'm going to mechanically strip the old paint on the rear ..
As I have mentioned , I didnt paint the out side , because of my shop conditions .. not enough room .. I already have to scraches on the primed surfaces .. I would be real choked if the scraches were in the paint !!
CJM
08/18/10 09:08 PM
sorry for the delay on my posting .. I took a day off :)
anyway ..
my Uhpolstery guy .. Tony .. finished sewing up the carpet , so time to install ..
still a little more to do .. but almost done the carpet
sorry for the crappy pics .. one day I'll get a real camera again !!
Greg_Canada
(Roll Me Over)
08/18/10 10:01 PM
Looking good.
About the blasting, the guy i use says he can do / has done fiberglass (corvettes) and it comes out great. He doesn't use sand, he usually uses baking sodas, but uses something with even less grit for the fiberglass, and apparently it turns out great. Do you have any soda blasters in your area?
CJM
08/18/10 10:44 PM
yeah .. soda works great , but the water involved in the spraying is not a good choice .. If you must , walnut shells are your best bet , and the ONLY thing I would use .. but holy crap $$$$$$$$$$$$$ .. so mechanical stripping is my choice
kewlynx
08/19/10 09:11 PM
I think Corey's well-passed that point with this job.
CJM
08/21/10 07:35 PM
so with the dash back together , I just had to set the center console in place to see what it looked like ..
i'm kinda liken' it :)
chpfx
08/22/10 03:03 PM
Hey Cory, Thanks for clearing that up for me, somehow forgot that the beds on the trekers were made of glass. Can't wait to see the truck finished, what an amazing job you've done sofar. Between your self and Greg I've gained motivation and a new respect for the work and patience it takes to do it right. Joe
CJM
08/22/10 09:38 PM
Thanks Joe , and not a problem , glad to help where i can .. now get on your project !!!!
CJM
08/22/10 09:38 PM
back at er' today .. working on the rear section
hopefully finishing up tomorrow ..
chpfx
08/22/10 09:57 PM
Thanks Cory, Been working on the ol'girl a little at a time. Got some body work done,almost ready for painting.Last week put a new standard clutch in next is to replace the head with either an EB rv head or the crawler havn't made up my mind yet. I hope to get some pics posted soon, as you know finances and time are hard to come by these days.
CJM
08/22/10 10:35 PM
yeah , I know ..
I have been saving $$$ for years and years for this one .. I totally know what you mean ..
day by day
CJM
08/28/10 08:51 PM
so still waiting for the uhpolstery guy to finish up the carpet .. so I decided to finish up the interior paint ..
everything is now painted and awaiting install
CJM
09/05/10 08:08 PM
so waiting for the uhpolstery guy to finish the carpet .. he was supose to be into day , to finish up ... but again , didnt show up .. ??? .. I dont get it !! he complains to me that he dosnt make any money doing uhpolstery , but yet I cant get anything done !
anyway .. while I was waiting for him to show up , I did some more sound deadining
and both done
I was "tapping" on the door skins before and after, what a huge differance ... before it was a tinney type " ting ting" and after .. it was a low tone "bomp bomp" , best I can discribe it .. I think it will make a very big differance , and i'm now really happy I did it
EtienneNavaar
(Need a Spot)
09/08/10 08:16 PM
Can someone who lives close go and mow Cory's grass so he can work on the truck? I'm having update withdrawl.
Staceman
09/09/10 10:01 AM
Cory, with all that sound deadener, you need to keep a close eye on all mirrors. I deadened my little tin can of a mini truck, (floors, doors, rear of cab, even the CEILING!) You do not hear basic traffic noise around you. You'll know what I mean when you sit at an intersection, stereo off, windows up, and just watch the cars go by silently. It is nice, but a little eary at the same time. That said, sirens are not heard until they are on top of you. But overall, the deadening is really nice
CJM
09/09/10 10:17 AM
if all goes well , fingers crossed , he has agreed to finish it up tonight ...so we`ll see :)
good point .. I will definatly make a note of that ..
CJM
09/10/10 08:28 PM
so one side done ..
on install , Tony was pulling so hard he ripped the seam , so .. he had to take it back to his shop and sew it back up ...
heres what the one side looks like anyway
CJM
09/12/10 08:30 PM
so not much to add ...
as the other side has still not been done !!
but .. I decided to install the speakers on the the one side anyway .. so mid and tweeter now perminantly installed ..
CJM
09/15/10 08:33 PM
so got the doors and front fenders on.. ;D
kewlynx
09/15/10 08:37 PM
OOOOOOOOOeeeeee!!
CJM
09/18/10 08:57 PM
started working on the rear bumper ..
I decided to go with a 84-89 4Runner rear.. stock Trekker bumpers are no longer avaliable , and I wanted chrome anyway ..
so here's what I did .
I got a "mock up " bumper from a buddy , so I was able to set it up on my jack stands , to get a good position ..
tucked well into the body , it fits great ..
I'm lovin' it ..
so with it set in position , time to make up some brackets
mocked up with cardboard first .. and transfered to steel plate , and cut
cleaned up and bent with 70ton press
got it welded , and then prepped for the POR-15
also while I was there , I needed to make my support bracket for the rear camera ..
and got it all por-15'd ..
CJM
09/25/10 08:24 PM
finally the other wheel well is done ..
so now I can finish up the wiring , wire the sub box , fill with fluids .. and hopefully have a vid soon of it moving on it own power :)
CJM
09/26/10 07:09 PM
so got a little done today ...
cooling system full
clutch blead
brakes blead
and P/S system full .... so with all the fluids in , time to finish up some little things before I can "fire it up" again ..
center console shifter boot installed , as well as the arem rest .. including the "map pocket" .. just waiting for the custom "limit" bracket I made from the chromer to finish off the consol e , other then that , all done ..
also got the sub box fully wired ..
(Roll Me Over)
09/26/10 11:38 PM
Damn, you do some nice work!
kewlynx
09/27/10 03:04 AM
Cory, the center console is a work of beauty; nice touch with the map pocket too. Ver' nice.
CJM
09/27/10 07:40 PM
thank you , thank you :)
so got the "bright" work today ;D
and just had to install a couple of pieces ..
I'm VERY happy with the color and the chrome..
and the console limit strap
CJM
10/02/10 01:06 AM
test drive today :) :)
http://www.youtube.com/watch?v=qxhLs9tSQg8
http://www.youtube.com/watch?v=wovftK0p6cA
Staceman
10/02/10 10:23 AM
Cory,
HUGE congratulations!!!!!
This rig is a true beauty, even as it sits now. Now the fun of re-assembly begins. I, sir, am extremely jealous. I can't wait to see this finished, like everyone else, like you
RatLabGuy
(Rock Warrior)
10/02/10 11:29 AM
Yeah.... I can't imagine the size of your grin getting to drive it the first time. So happy for you!
And - nice door latches, lol.
allochris
(Rock Warrior)
10/02/10 11:33 AM
Yeah! 3 years - 2 months of accomplishment coming together good! It looks huge compared to the Mazda Van passing by!
CJM
10/02/10 08:51 PM
thanks guys .. I'm stoked .. it runs awesome and lots of power .. it'll brake loose easly in first at anytme !! and It STOPS as well .. I cant wait to get it completed and on the road
Greg_Canada
(Roll Me Over)
10/03/10 05:03 PM
Jealous!!!!!
What exhaust / muffler are you running? Sounds nice.
chpfx
10/03/10 07:08 PM
Wow Cory it's awsome, good job. I can't wait to see the finished product, I see everyone else is as jealous as I am. By the way my parts arrived Monday from Todd. When the weather clears up I'll get some pics and get them installed. New RV head and cam and front end kit, man hope it stops raining soon my garage is full of all the kids stuff! Anyway, great work!
kewlynx
10/03/10 09:52 PM
Blue Honeymoon toast to ya Corey!!!!
Sounds awesome. I'd just leave the stereo off!!!!
Congratulations!
CJM
10/04/10 07:50 PM
Jealous!!!!!
flowmaster 40 w/offset with 2 1/2" pipe .. no tail pipe yet though .
aw thanks .. I'm pretty excited ..
Congratulations!
Thanks girl .. .. i'm very happy .. but I will keep the sterio on , playing a DVD for my passengers
CJM
10/08/10 08:34 PM
so finally .. I believe this is the LAST thing I have to "fabricate"
the canopy ..
as you can see it's in really bad shape .. it's fixable , but for the time I would spend fixing it (and it has been done at least once before) I figure I might as well make a new one , with NEW and ADVANCED products .
RatLabGuy
(Rock Warrior)
10/08/10 10:23 PM
Holy cow please tell me you aren't going to just make a whole new top too...
CJM
10/08/10 11:32 PM
guilty ..
(Roll Me Over)
10/09/10 12:19 AM
Cory, I should bring you my FJ60 so you can chop the top and make me a REALLY big Trekker...
I can't wait to see the finished product!
allochris
(Rock Warrior)
10/09/10 11:21 PM
guilty ..
I'd like to have a fiberglass top version for my pop=top camper too!
CJM
10/11/10 08:50 PM
wouldnt that be cool !! a 60 with a removable roof .. sweet , I would love to do that !!
hmm hasnt that been done ? i'm sure I have a picture here somewhere !!
got the rear seatbelts installed , also finished the install of the GPS , finished wiring the rear camera and the rear lower seat locks .. also the roll bar is now installed ..
I was working on the jack and tools install , but was interupted , and had to take it for a little ride again around the compound ..
talked to the interior guy and the seats are in the works :)
JAVYPRO
10/21/10 02:12 PM
This is awesome, truly awesome.
About the aluminum foil and the fiber glass, I am going to try that one. I want to build a scoop for my upcoming turbo project and you have inspired me.
Javy
CJM
10/21/10 09:01 PM
thanks .. always glad to inspire ...
CJM
10/22/10 10:17 PM
some progress , notice no more sag on the roof .. :)
sanded , and very first primer .. good from far !! lots of work yet to do to make it right ..
(Roll Me Over)
10/23/10 01:29 AM
Let me finish school and recover from my V8 swap fiasco, and we'll need to talk...seriously. I'll need some kind of ballpark figure to consider, so please think about it. I think I've convinced myself that the roof rack won't be going back up there.
You do good work, and that cap you just posted pics of looks AWESOME!
CJM
10/29/10 08:29 PM
continuing on with the roof ...
My boy and I blocked out the second primer
filled ,sanded and primed now for the 3rd time ..
it's finally time to wet block :)
CJM
10/30/10 08:59 PM
so out and about today .. I was driving buy my interior guys place , and I thought I would stop in to see if any progress on the seats ..
yes .. :)
a little sample of the NEW seats ..
(Roll Me Over)
10/31/10 12:49 AM
Good stuff! I can't wait to see it finished!
Macka
(Rock Warrior)
10/31/10 10:05 AM
very nice, this is giving me ideas.
CJM
11/02/10 08:56 PM
I picked up some plastic "dip" from a local supplier on Monday .. looking at doing the battery hold down in some what of a factory finish .. + I just wanted to try it :)
I took the J bolt and sand blasted it and dipped it ..
turnd out well ..
also .. got the roof wet sanded .. almost ready to go
RatLabGuy
(Rock Warrior)
11/02/10 10:44 PM
OK so did you seriously just go and make a whole top from scratch? With something that big - how do you do that? Made a template/form from the old one? Have any pics of that process?
Macka
(Rock Warrior)
11/03/10 06:15 PM
yea he owns a custom fab shop. I'm putting my sheckels together so I can get some work done.
CJM
11/03/10 08:03 PM
this is still the old roof .. still getting it ready to build the mold , almost done ..
I wont be posting a "how to" but here is a great wright up on making BIG parts http://www.hotrodder.com/32Blowpar/page8.html
stock87
11/04/10 01:10 AM
Corey, one thing I've always wondered is how hard/is it possible to modify existing fiberglass items? I've always had a love/hate relationship with my camper shell since it's color matched, but the dimensions are for a Ford Ranger bed, so the rail portions are about 3 times as wide as the Toyota bed rails. I've often wondered if it would be possible to make a new mounting portion to neck it down the little bit to the Toyota bed dimension, or would that require re-doing the whole shell (making it much more economical to just get a different one, obviously)?
Sorry for the hi-jack.
CJM
(Body Damage is Cool)
11/04/10 08:42 PM
no worries ..
personally .. I would find a new canopy !
BUT , if you really need to do it
best fix would be to cut the canopy right in 1/2 (@ the middle) and take out the section to make it fit .. then find the correct rear door , and enlarge the front window ..
CJM
11/04/10 08:43 PM
little bit more work on the roof today .. but I mostly concentrated on the seat tracks ..
got them all cleaned up , (wow , lots of work) and painted ..
and dropped them off at the uhpolstery shop .. and wow .. the front bottoms are done :) I love em !!
TexJeff87
11/04/10 09:14 PM
too cool...
there was a guy in Houston with an 81 on craigslist...2900. wishing i had not had to pass.
waaaay jealous.
Greg_Canada
(Roll Me Over)
11/04/10 09:40 PM
Re: sold the first one .. so this ones mine ... Trekker Build
Those seats look great!
CJM
11/07/10 08:37 PM
thanks guys ...
project is progressing !! :)
CJM
11/09/10 08:46 PM
so I decided to build a "production mold" afterall ..
one less part to build when I do the other pieces for the trekker body . which means , YES ... anyone with a 79-83 pickup SHORT BOX .. will soon be able to build there own Trekker !! :)
(Roll Me Over)
11/09/10 09:53 PM
Oh, for Pete's sake. You're making me feel like a lazy b-tard...
Lookin' good, man!
CJM
11/13/10 06:35 PM
finished up the mold today :) ..
poped the old roof out
trimmed the edges ,
a little bit more work to "prep" the new mold for maufacture , but basically , I'm now ready to make my new roof
K_Raider
(Rock Warrior)
11/13/10 07:27 PM
Sick man. Just absolutely sick.
CJM
11/13/10 09:15 PM
thanks ..
CJM
11/19/10 08:39 PM
shop was full with customer vehicles for the last couple of weeks .. so I havent been able to do much on my own ... but the weekend is comming :) .. I have been doing some little things ..
I did manage to get my battery hold down finished .. Plastic dipped , and installed
CJM
11/21/10 08:31 PM
started work on my headliner today ..
I had previously made a flat piece of fiberglass sheet .. and cut it down to size ..
I then proceeded to cut it down to size .. and get it fitted ..
trcdrunner
(Mudrunner)
11/29/10 05:05 PM
AWESOME... purely AWESOME
CJM
12/01/10 10:36 PM
thanks ..
CJM
12/17/10 08:32 PM
so .. finally .. mold is ready to produce .
New topper comming soon :)
Macka
(Rock Warrior)
12/18/10 10:02 AM
What will the new topper cost? it will fit on the early 4 runner correct?
CJM
12/18/10 10:41 AM
nope its TREKKER specific .
I plan on doing the tub and rear fenders as well , so eventually , you will be able to convert your 79-83 short box into a "Precision" Trekker
CJM
12/19/10 06:15 PM
started again on the headliner today, got the interior all covered up , and ready
all glassed/rienforced to hold the shape
will be all cured up for tomorrow .. when I can remove it , finish up the trimming , and add 1 final layer ..
then final prep for the uhpolstery ...
CJM
12/23/10 10:12 PM
should have the roof done tomorrow .. it's been a lot of work .. Chop strand mat , hand layed + rienforcement in stratigic points ..
I used mutipul layers , stagering the weave , *Kevlar and 4oz woven for the hinge and rear vertical areas (winnabego used wood type stuff ) also the main roof struts/strengtheners have been filled with fiberglass foam sheet (fiberglass specific) for ultamate strength and flexability .
hope to "pop" it from the mold maybe late tomorrow ..
CJM
12/24/10 08:25 PM
so , I believe this is the VERY newest NEW Trekker canopy in the world :)
and out of the mold ..
trimmed and washed
chpfx
12/24/10 08:48 PM
Wow Cory awesome the top looks great. Merry Christmas
Greg_Canada
(Roll Me Over)
12/24/10 11:21 PM
Very nice!
(Roll Me Over)
12/24/10 11:33 PM
Looking great as always, Cory! I'm a dummy regarding fiberglass. How do you finish it? Is there a gel coat or something, or do you just prime and paint it?
Merry Christmas!
CJM
12/26/10 08:21 PM
thanks guys !!
best of the hollidays to you all !!
Merry Christmas!
the white "gloss" finish is the gel coat ..
there are always a few touch ups .. if you look around the window area you'll see a couple of areas where the gelcoat has "chipped" from trimming and pulling it from the mold .. so a little filler will fix that up .
also for finishing up for paint .. it needs to have the "shine" scuffed off , so paint will "stick" so I'll take some scotch brite pads . and "take the shine off" .. then it'll be good to go !!
CJM
01/03/11 09:49 PM
not much happening on the Trekker right now .. I have been focusing on other things ..
but rest assured .. there is Progress and I still WILL have it "driving" this year ..
headliner "pad" is done and ready . I still have to mount the topper/canopy , and build a "transition cover" between the headliner on the cab and on the canopy .
Canopy progress is on going .. and hope to have it done this week ..
blocking the gelcoat , and prepping it for paint
CJM
01/07/11 08:37 PM
so got the roof all prepped and ready for some color ..
I decided to "set" it in place to see what it will look like .. I'm happy .. I still have to perminantally mount it so some of the gaps are not correct , remember , it's just sitting there
RatLabGuy
(Rock Warrior)
01/08/11 11:26 AM
Sooo... after all the other custom fabbing you've done - why permanently mount the top? Why not make it removable lie the 4Runner?
CJM
01/08/11 08:39 PM
it will be removable .. I just doubt I will ever have it off again
CJM
01/19/11 08:27 PM
so .. not been able to do much ... but getting a little bit done ..
I started cleaning up the inner alum. trim plates , stripped the powder coat and got one into zinc ..
I still want to paint them "satin black" (same black as the rest) .. but heres what I got so far ..
also making a new "transition" moulding for the cab and roof seam .. the old cardboard is just not usable again :-/ .. so with some carefull measurements , I trimmed up a 2X4 , to use as a mould , rounded the edges .. and made a fiberglass piece
fitting it is next on the list ..
CJM
01/20/11 09:34 PM
installed the headliner "backing plate" today .. and "prepped" for the cab/canopy transition ..
I used the original Trekker "cab rienforcement" roof piece .. as a "transition" for the canopy/cab fabric headliner
CJM
01/21/11 09:40 PM
worked a bit on the Trekker today ..
got the "transition" headliner piece , cut and fit ..
glassed it up , and
should be cured for tomorrow ..
CJM
02/05/11 08:31 PM
well again , I am waiting for the uhplostery guy to do the headliner .. he was supose to be here the previous week , but did not show up , then he finally showed up last week to take measurements , to order the material ..
so I guess because of the snow storm back east , he didnt get it , and it's supose to be here this comming week .. I hope so ..
so I have just been "tying" up some loose ends ..
got the other canopy strip , stripped and both of them painted
also finished up the tail lamps ..
Ordered new lenses , because the old ones were ... well old and 1 was broken ..
The Mojave Chrome lamps i'm using have the back-up lamp chrome surround and the new lenses just have the black ones .. So I proceeded to drill out the mount stems and remove the black surrounds as well as the chrome ones
removing the chrome ones I noticed there were both marked R .. huh !!
and got the pieces swaped
and tail lamps installed
just got to get the canopy on now !!
(Roll Me Over)
02/05/11 09:57 PM
Bitchen!
Staceman
02/08/11 11:08 AM
X2 what Jon said
CJM
02/11/11 08:50 PM
thanks guys ...
so good news ...
my headliner material is in .. Talked to my uhplstery guy and It looks like a sunday install :)
I had to "level" the roof strips and install a couple of "tack strips" .
Because the headliner wont be 1 piece and will have to be sewn ,
We decided to follow the body line , to give it a "subtle" custom look .. also I added a rear dome lamp mount ..
CJM
02/13/11 09:00 PM
well .. sunday has come and gone ..
another bust on the interior .
started off all well and fine ..
trimmed out the centersection , cut and fit , and Tony took it back to his shop for some sewing ...
well I guess his sewing machine took a turn for the worst , and decided not to work . Broke all of his needles , so I guess he has to order some parts and fix his machine :'( ..
one day I might get this done !!
CJM
02/27/11 07:30 PM
well finally got the rear roof headliner in ..
and new dome lamp installed
and set the roof on to "check it out"
flyinhawaiian
03/01/11 01:45 AM
Coming along real nice.......Man those speakers are huge....Are you considering a stated value insurance policy when you're done??????
CJM
03/01/11 09:26 PM
thanks .. yeah it rocks :) ...
Yes .. provincial insurance "value" is avaliable where I live .. I just have to have it appraised (with receipts) and I can get FULL coverge
I absolutly plan on having this coverage
(Roll Me Over)
03/01/11 09:55 PM
Hell, yeah, Cory! Keep rockin'!
CJM
03/05/11 08:22 PM
roof is on ;D
Pyroboy
(Mudrunner)
03/05/11 11:54 PM
Looks sweet, Corey!
CJM
03/06/11 08:25 PM
Thanks Sean .. cant wait to get your rig in the shop :)
well a little bit more today ..
"mocked" up the rear hatch , and drilled hinge holes in the new roof
I think she's ready for paint
CJM
03/13/11 09:36 PM
ok .. I lied !!
I had to do 1 more thing before paint ..
I had to build a moulding/cover for the transition between the roof and cab
started by building it in Pieces , and then glassing it together ..
trimmed and "snapped" into place ..
still a little finishing , and some uhpolstery to do .. but you get the idea ..
kewlynx
03/14/11 12:03 AM
Right on; bet it's nice not to have to shove it around now that she runs!!!!
Greg_Canada
(Roll Me Over)
03/14/11 01:27 PM
What more can i say.
Also, how does your rear e-brake work?
CJM
03/14/11 08:59 PM
everything works and runs great .. E brake works as stock .. pull and she holds .. eventually I would like to replace with a "custom built " rear cable , but this one will do for now .. I still want to do some heat shields for the exhaust .. but for now , I'm done .. she's off to paint on Wednesday
I must say I'm very impressed with my braking system overall .. with some speed , stompin' on the brakes it stops awesome .. I havent got it "to speed" to test them , but i'm VERY confidant everything will work as planned .. stops on a dime with 35's :) very happy !!
CJM
03/17/11 08:37 PM
off to paint
she's gone ...
MnMsToY
(Mudrunner)
03/17/11 09:44 PM
Its been a year or so sense I've checked in. I must say it's coming along.
Mike
masheen
(Need a Spot)
03/17/11 11:25 PM
Corey, on pg 9 of this thread, you were working on the differentials. Did I understand your report correctly in that you're using the stock 4.10 gearing for the 35's you're using?
I run 33's on mine. After doing the math, I came up with a gear ratio of 5.01 to fool the drive train into thinking it was still turning the stock 27" tires that originally came on my truck when I bought it new. If this gear set were actually available, the truck would accelerate as it did stock and both the speedometer and odometer would once again read true and fuel mileage should also increase. In reality, only 4.88 and 5.29 gear ratio's are the only viable choices available. The 4.88 gears are spot on for spinning a set of 32's whereas the 5.29 set are much better suited to turn 35's; 34.84's to be exact.
So why aren't you using 5.29 gearing? Strength shouldn't be an issue with that ratio. 4.10's are just way too high a gear for running 35's in my opinion. I also didn't see any mention of positraction units although I may have missed something somewhere. I like how you compensated for the use of lifting blocks between the springs and axle housing by fabricating the shock setup to help prevent spring wrap.
Here are two big thumbs up for an excellent build and for sharing it with all of us!
Greg_Canada
(Roll Me Over)
03/18/11 10:36 AM
