PartyPaj
(Need a Spot)
03/19/06 04:26 PM
Re: Bodylifting ī91 Pajero (17 pics)
Phil: This one has 4.875:1
greaglecrawler: This "kit" is homemade. I just had a metal supplier cut down a 60mm diameter poly rod to 80mm pcs. There are 12 of them. The I added the 80mm to length of the original bolts and got 170mm bolts, 10 pcs and 190mm, 2 pcs (the rearmost bolts are longer).
The only problems so far are:
I will have to lengthen the shift linkage for the automatic transmission and the transfer case shift lever.
I had to look out for the brake lines, but there was so much excess line from the factory that it wasnīt a problem.
I will have to check the fuel tank a little better out but I donīt expect any problems with the hoses there.
Now I just have to raise the bumpers and put the fender flares on. The flares will be put on this week. (I will also get a new boot/trunk door as this one was hit with a flying hook from my Trooper when getting it unstuck in snow slush last spring and that incident left a beautiful looking hole)
P.S. Hereīs a pic of my Trooper that Iīm selling.
Regards from Iceland, PartyPaj
