JeffatTireBalls
(Wheeler)
03/24/12 03:01 PM
Re: Tach Crisis — Raider Conversion to Diesel. Help!
Jeff, according to Dakota Digital, your set-up should not be working (don't scientists say a bumblebee should not be able to fly?). Here's what Dakota Digital told me when I used the DSL-1 converter that you've connected to your injector pump:
"The DSL-1 is not designed for a low frequency pulse like the fuel. It is designed to read a high frequency off the alternator. While it is sensing the signal, the output is too low to make your tach work. You should be using the SGI-8 for the hall effect sensor."
Go figure. Is there someone out there who can clear this up?
Their wrong, mine's been working great for 8 months. I can even shoot a video of it running and working if they don't believe me.
Generated in 0.003 seconds in which 0.001 seconds were spent on a total of 4 queries. Zlib compression enabled.
