Peabody
(Wheeler)
06/17/12 03:22 PM
Re: No Power above 3000 RPM
I was able to piece together a patch for the corrugated hose using a 2.5" coupling for exhaust pipe. The OD on it 2-5/8", which is about the same ID as the corrugated section of the hose. So I cut out the split sections of the hose and used the coupling to splice everything together. I had to rearrange the hose pieces to get everything to fit without straining, to include the MAF body. I'll post a pic soon so you get a better idea of the layout. But it did the job - the intake hose is sealed now and my Sporty runs like a champ again (no P0171 codes)! This patch-up is temporary. Now that I have found a good layout, I'm going to order some parts so it seals better and looks a little more "presentable". Yep, a good split in that hose can be a real headache...
Generated in 0.005 seconds in which 0.003 seconds were spent on a total of 4 queries. Zlib compression enabled.
