Dave Scott
(Trail Leader)
12/28/07 03:16 PM
Re: rear axle shaft lock nut
probably, or one similar, like the D44, but then you have to cut off the back end of it and slip it over the axle tube and crank on it with an oil filter wrench or weld a pipe to it or something.
to be honest, i always thought rear non c-clip shafts had PRESSED-ON bearings with PRESSED-ON collars, not nuts.
Generated in 0.004 seconds in which 0 seconds were spent on a total of 4 queries. Zlib compression enabled.
