Winston
(Rock Warrior)
08/29/05 03:54 PM
Re: 02 Montero spark plug replacement
I would like to hear how it turns out. $600 from the dealer is outrageous. I believe you need a new intake plenum gasket. Also, while you are doing the work on the top end it would be a good time to clean the IAC/ISC motor. It is attached to the throttle body. Another source for plugs is;
www.sparkplugs.com
I think the Denso's listed are the same as the OEM mitsu plugs.
