heathdogg
(Mudrunner)
07/06/12 01:37 PM
Re: GenI CV Axle Issue
Are the T-bars cranked and/or other mods done?
Someone should try shorting the Pass side shaft so it can slip in on the drivers side so that you can have bolt on axles for both sides. Hell, make the both like a chevy rear so you have a thick clip holding them in so it can't pop out. Down side is you would then have to remove the cover to pull them out, but hey no axles popping out then. Just musing of a un-normal mind.
