hazy_daze
(Roll Me Over)
10/19/10 09:36 PM
Re: To rebuild or not to rebuild, that is the question... *PICS* Update
After visual inspection and some test light and meter probing, I found 3 blown fuses, 2 burnt thru wires, a bad relay and a fuse panel that was damaged from melting. Replaced the fuses, repaired the wires, replaced the relay and fuse panel and voila. I have headlights back and my Autometer gauges register. I had a couple wires backwards somehow, which had overloaded a few circuits causing the aforementioned damages. I guess all's well that ends well.
Still need to figure out O/D and check if the base timing plug still arcs or not, but I'll save that stuff for tomorrow night...
