Kevin C
(Trail Leader)
11/04/07 01:45 PM
Re: VIBRATION From Engine?
Also look for any cylinder ballance problems. All it takes is a missing vacuum fitting at one port or a small leak to get one cylinder to run lean enough to make the motor shake.
I have put a scope on the O2 sensor at idle as a way to pinpoint a vacuum leak. You could see the blip in the voltage as the one lean cylinder fired. Turns out I forgot to plug a port vor the cruise control on the intake manifold that was located in front of cylinder #3.
A compression test never hurts just to be sure.
Kevin
Generated in 0.004 seconds in which 0.002 seconds were spent on a total of 4 queries. Zlib compression enabled.
