Quote: The side plates in red are 1/4". Originally 3/8", but this was turning into an anchor quick and 3/8" seems rediculously overkill... In the following pic, the lower tube is welded to the front of the frame rails. It'll have a small gap between it and the front crossmember and I'll add a few stringers between them, and probably overlay the frame/tube joint with some fish plates on top and bottom. The side plates extend back overlapping about 6" of the frame rail. As far as I can go with the steering box. It's not shown, but I'll try to run some angled braces from the upper tube (middle one in the pic) down and back as far as I can to the top of the frame rails. The plate in this area is about 2" taller than the frame rail so I can run some more braces down from the top of the plates. ![]() I'm actually more worried about the frame rails themselves. They thin down substantially at the front where they arch up. I wish now I would've beefed them up a bit during the SAS or engine swap. Quote: I believe yours is mounted through two hitch tubes right? It's been a, uh, well, a *while* since I've seen UZI Thanks for the vote of confidence.--Dan |
