Quote: How would Pep Boys know what he needed? Quote: Last time I took the compressor out of a '89 4runner I did it all from the top, but I had the radiator and the air intake tube out. You'll need to remove the discharge and suction hoses which are on the top, though you can probably get them from below. The accumulator is out in front of the radiator behind the grille. You'll need to remove the grille first. If you live in some nice climate like California you might be able to get the accumulator fittings apart (17mm flare wrench). The accumulator is the one item that really needs to be replaced, but be careful. If you are in a corrsive environment all the fittings out front may be beyond repair, which means you'll be looking for a new condenser and maybe a liquid line and a discharge hose as well. The liquid line is the the aluminum line with all the bends in it that runs from the evaporator to the accumulator and the discharge hose is the one that runs from the compressor to the condenser. They run about $50 and $100 each. I hope you have an easier time than I did. Good luck. This is a shot of an '89 4runner rust bucket partsmobile The lines are a little more complicated than in the drawing above which is for the pickup. -- Matt
