OOP'S
(Roll Me Over)
01/15/11 09:44 PM
Re: BRAKE BLEEDING PROBLEMS
yes, that is the order that I'm bleeding the system.
So you think that the LSPV could be bad and would cause the system to need bleeding every few weeks - Is there a way to test it before dropping $250 for this dealer only part?
Thanks
I really do not know how you would test. It seems like if it were bad it would be leaking. I would not spend that much on something that I was not sure if it were bad or not. Which wheel are you getting the air out of?
As far as the LSPV I would go to a P-N-P and see if you can find one or an adjustable proportioning valve, that is what I did when I put the disk brakes on the rear. Dave'z Offroad Performance. has a complete set-up for a pretty good price. The only other thing you will need is a plug for the "T" fitting that is in the PS front wheel well. You remove the return line from the LSPV and replace it with plug.
Dave'z web page:
http://www.davezoffroadperformance.com/
This is what it looks like and where to find it on his web page.
http://www.davezoffroadperformance.com/forum/viewtopic.php?f=3&t=52
