(Unregistered)
01/21/02 12:55 AM
Re: Help me with YJ & Wagoneer Axle Track Width?
I did this exact swap myself. You can see my articles in the tech section here:
http://www.rightcoastcrawler.com/LloydC/Jeep.html
but in response to your question regarding TRACK width, I'd say the waggy axles are basically about 2 inches wider than stock. The spring perches are 1 inch wider, so you have to move each one in 1/2 inch (on the front, on the rear just cut em off and reweld them where appropriate), which I did in a slightly different manner than the ones noted in the above articles. But the axle itself is wider, so it will have a wider track width, all other things equal. The difference is minimal, though, but if it really matters to you I don't see any reason why you couldn't make it up with different offset wheels if you really wanted to, but personally I don't think the difference is going to be that noticable.
Chad
Generated in 0.003 seconds in which 0.001 seconds were spent on a total of 4 queries. Zlib compression enabled.
